Old January 13th, 2017, 09:13   #61
Markus L
My 1.9 VE made over 370 bhp with just slightly ported head so why CR wouldn't do big power? These are not naturally aspirated engines so if you want more air just add boost. 2260 is not even near to choke with 250 bhp.
Markus L is offline   Reply With Quote
Old January 13th, 2017, 11:43   #62
xjay1337
I literally give up.
Clearly some people are beyond reading.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old January 13th, 2017, 16:07   #63
named tintin
TDI(s): golf tdi
Not me, i'm still reading, all this is very good info.
You have a very nice car btw... congrats.
I've reread again your build thread, so with your set-up you'r still running on Lambda calculation in the ECU?
The only thing I find strange, is the linear figure of what's supposed to be maxed out, the VE efficiency of that engine is not linear, when there is not enough air, you should have more and more smoke as the RPM increase.
I'll be curious to see VCDS log of the various fueling parameter of your car.
named tintin is offline   Reply With Quote
Old January 14th, 2017, 00:20   #64
diffas
diffas's Avatar
16 valve heads easily outflow even slightly ported 8v heads. Problem with those is valve control when having increased flow on boost and emp. Luckily there is a fix for that. gtb2260vk is indeed good for 300+ hp so plenty of room there.
diffas is offline   Reply With Quote
Old January 14th, 2017, 01:00   #65
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
There is also a 297hp tune in US i think, A3 big turbo audi here on forum with WMI
I imagine a dyno being 10-15 hp too optimistic but 45-50 difficult to believe.
From what i've been told its a matter of fuel atomization, quality of burn and timing and not an air flow question to make hp on the CR engine.
Numbers show it flows enough air, more than any BKD 16v engine, and much more than 8v heads.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 14th, 2017, 02:54   #66
Markus L
Well, this kind of basic stuff like stiffer valve springs should be done before you judge the head is too restrictive. Of course if you ask vendors what to do they recommend head porting and lots of other stuff they want to sell you. I think it's just wasting money.
I'm sure 400 bhp could be done with stock ports.
Old January 14th, 2017, 03:37   #67
Macradiators.com
Van Vught Tuning in Holland , Johan is present on forum ..he can enlighten us if he wants
Following his tunes on FB and seems he does a freakin' good job
IIRC his 2.0 CR Golf has 270hp on stock pump
295+hp and 540Nm
CP3 Upgrade
Old January 14th, 2017, 08:34   #68
TDIsyncro
TDIsyncro's Avatar
TDI(s): Audi/TDI x 2
Fuel Economy: 50-60mpg HWY, depending on speed and wind
Johan has consistently gotten 270 to 280 hp on his cr tunes. He would also agree that 28xhp is the flow limit of the head. You can put a bigger turbo on to try and push more through but emp just goes much to high for gains to be reasonable. The emp will have direct impact on peak cylinder pressure and how long your engine will last before it destroys itself, for those who think just putting a bigger turbo is answer. As already pointed out, head work is necessary. Johan and myself have already test a regrind cam on OEM head and it did not help. There has to be head work done to support the cam grind. Head work includes valve changes.
2001 Audi A4 - New Project - 2.0TDI CR 450HP All Turbo
http://forums.tdiclub.com/showthread.php?t=270527
2007 Canyon w/2011 TDI CJAA CR
http://forums.tdiclub.com/showthread.php?t=415533
TDIsyncro is offline   Reply With Quote
Old January 14th, 2017, 08:43   #69
diffas
diffas's Avatar
Like pointed earlier the problem is not in the head flow.
Old January 14th, 2017, 10:06   #70
MarkoP
Fuel Economy: avg 5.3L/100km
Here is flow measurements I have collected about stock diesel cylinder heads:
http://npsheads.com/index.php/flow-database
http://www.npsheads.com
MarkoP is offline   Reply With Quote
Old January 14th, 2017, 10:26   #71
Macradiators.com
Yeah Marko, great having some number to back up the claims.
3 angle valve job done , camshafts and some head work
CP3 Upgrade
Old January 14th, 2017, 12:52   #72
Markus L
No need for bigger turbo, GTB2260VK is good for 300+ bhp.
It's quite obvious that you don't get any gains with regrind cam if valves are already floating. I agree that a headwork needs to be done; stiffer valve springs are definitely needed.
Old January 14th, 2017, 13:35   #73
Macradiators.com
Is it possible for valve float to manifest on a 5000rpm diesel engine in our case?
CP3 Upgrade
Old January 14th, 2017, 13:42   #74
xjay1337
What is it exactly then?
Thank you.
Im not putting logs up I'm afraid. We have proven headflow is limited, oh well.
People will only blame the terrible tune
We will have special turbo and head built soon.
Terminal speed and 1/4 mile times speak words over claimed dyno figures anyway.
Old January 14th, 2017, 13:46   #75
TDIsyncro
TDIsyncro's Avatar
I think you need to reread my post. Gtb2260 is good for more than 300+hp on lots of engines but not on OEM cr engine. You missed my point.
I have not done the calcs to see if there is float due to emp and imp at those low boost levels. Certainly on my engine it would be a problem without upgraded springs. I am doubtful it is a problem on 280 hp cr. "It's quit obvious..." lol.
DSG/Common Rail Help!?!?! mxracer291 VW MKVI-A6 Jetta Sedan (~ 2011+) 16 July 1st, 2016 08:46
common rail F/S ronbros TDI 101 7 August 23rd, 2012 05:11
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
PD vs common rail Sacha TDI 101 3 September 14th, 2001 06:48
Page generated in 0.18718 seconds with 10 queries
[Output: 137.17 Kb. compressed to 115.40 Kb. by saving 21.77 Kb. (15.87%)]
