Old December 29th, 2016, 15:56   #31
Bigtoy302
Originally Posted by BleachedBora View Post
I have two brand new CR170 complete motors in the back, haven't even listed them yet. Also ECU and wiring harnesses. Might be an option?
We're also only 90 minutes from you...
Maybe. What engine code? Depends on price. I can get CJAA's complete for $1200-1500 all day.
Bigtoy302 is offline   Reply With Quote
Old December 31st, 2016, 12:00   #32
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
If you want HP you must start already with the lowest CR available of 16.5, can find that on the 170hp euro cars.
For my 350hp goal will now lower it more than that.
Jamie in UK already has the big turbo cp3 setup and the car is very fast.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old December 31st, 2016, 17:50   #33
dieselherb1
I have all the components now to build a 300+ HP Cr engine. Got all the parts from a buddy in Newport News. He had everything in an A3 Audi made 297 HP 578flb torque.
dieselherb1 is offline   Reply With Quote
Old January 1st, 2017, 01:17   #34
Macradiators.com
Any dyno of this 297hp and 783Nm? Torque seems impossible imo
maybe its 578Nm not ftlb
CP3 Upgrade
Old January 1st, 2017, 11:48   #35
jos_br
jos_br's Avatar
TDI(s): Audi TT>TDI
This is what we have build to try with the pump of a V6 239hp engine.
Engine has now (stock HPFP) 250hp with a 2260, Darkside manifold, Wagner intercooler and JD Engeneering software. No larger nozzles yet, just to try how this works. Engine is running very good. There are modifications made to this engine like a ported head, Dblias cams, FIN-turbo, and nozzles from the 240hp cr Passat.
Jos.
jos_br is offline   Reply With Quote
Old January 2nd, 2017, 05:35   #36
mickyTDI
mickyTDI's Avatar
Jos.
CR240 injectors fit straight swap into CR170 head?
2017 VW Passat 2.0 BiTDI 288.4bhp CUAA
mickyTDI is offline   Reply With Quote
Old January 2nd, 2017, 05:37   #37
mickyTDI
mickyTDI's Avatar
You could use the Euro CR 140 CFFB also same compression ratio, the engine is identicle to the CR 170 CFGB only difference turbo was smaller on the 140.
Old January 2nd, 2017, 06:24   #38
dieselherb1
Engine as dynoed
Old January 2nd, 2017, 06:28   #39
dieselherb1
How can the ALH engines brag about 200 and 300 HP. But people doubt same with CR engine. Is had 22/60 turbo and CP3 pump
Old January 2nd, 2017, 10:22   #40
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Your pic didnt show. Commonrail engines can create a ton of power...its just no one has done it. The reasons why are well documented. And it has nothing to do with pump or turbo.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old January 2nd, 2017, 13:08   #41
Macradiators.com
Aiming at 340-350 with the mods i have now and pretty sure ill get close.
A few people have good results close to 300 but dont stay on forums bragin' about it
CP3 Upgrade
Old January 3rd, 2017, 06:46   #42
mrchill
mrchill's Avatar
I agree. Often those making the most power are too busy experimenting to get on the forums and prove any point. My point to the other poster was that no one has really shown power in the levels he had mentioned.
Old January 4th, 2017, 00:01   #43
Macradiators.com
Indeed it's hard work and lots of money. But it will worth it! My head will be back next week from porting job.
CP3 Upgrade
Old January 4th, 2017, 09:11   #44
mrchill
mrchill's Avatar
I agree. Its expensive and tedious...but very gratifying.
Old January 9th, 2017, 15:40   #45
dieselherb1
I enjoy driving-racing a sleeper.
DSG/Common Rail Help!?!?! mxracer291 VW MKVI-A6 Jetta Sedan (~ 2011+) 16 July 1st, 2016 08:46
common rail F/S ronbros TDI 101 7 August 23rd, 2012 05:11
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 06:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 20:33
PD vs common rail Sacha TDI 101 3 September 14th, 2001 06:48
Page generated in 0.15074 seconds with 10 queries
[Output: 130.51 Kb. compressed to 108.83 Kb. by saving 21.68 Kb. (16.61%)]
