Old December 27th, 2016, 13:14   #16
Bigtoy302
Originally Posted by turbobrick240 View Post
Very cool to see some injector options. That's $6000 canadian, so they are practically giving them away. Kidding. That's $4500 US, still way too much.
Read their site again. They are not available yet. Still testing. I'm sure they will be priced with the others.
Bigtoy302 is offline   Reply With Quote
Old December 27th, 2016, 13:14   #17
diffas
diffas's Avatar
Now thats what I call price! = There must be a typo.
diffas is offline   Reply With Quote
Old December 27th, 2016, 14:11   #18
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
I see the intake and port entry is piss poor, I am building a new Chump TDI with a CR engine and DSG platform.
My plan is to machine the intake some how to place four tubes in there then make up a log intake to mate using silicon hose connectors. This should give a better shoot in to the head.
If I can build it to do 250HP and close to 400LB I will be very happy with that. If you can get that HP an LB all in a 2500 RPM and pull to 6000RPM on a road course there is not a car out there that can pull this package off the turn . The Beetle with only 180 HP 300LB and all done at 4000RPM ALH weighing in at 2700 LB never got passed in the turns.
The Golf should weigh in at 2300LB track weight.
Originally Posted by Bigtoy302 View Post
I was thinking about milling off the intake portion of the head off to get in there for better porting like they do on the Cummins heads. Then just build a new aluminum intake. Need to get a head and see if there is enough meat to tap some holes for the intake.
My plan is to put the LB7 Duramax CP3 on it. Still need to look into custom injectors/nozzles. There are lots of places that do Cummins, Powerstroke and Duramax injectors so hopefully they can do these. I currently have lots Industrial injection parts on my 12v Cummins in my Ford. Maybe they will be interested.
Are you going single turbo or compounds?
Stock pistons?
I'm guessing your upgrading the rods?
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old December 27th, 2016, 16:07   #19
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
For 250 you only need the big turbo, ic and exhaust. why would you bother touching the head?
Multiple independent tunes all over europe, from 270 to 284 on stock pump
Price is ridiculous at 4500$ for 4 nozzles , you only need to spend 600 to transform your injectors in CZ..they do it if you know the right people.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old December 27th, 2016, 17:21   #20
Bigtoy302
They're not $4500. They just put that price on the website because they are not ready to be sold yet. They're still testing them.
Old December 27th, 2016, 17:46   #21
v8 coupe
Stock pistons?
I am going compounds and since it is being used as a road course track car spool isn't really needed and to make tuning far easier I am ditching the VNT turbo setup completely and going with a pair of well known fast spooling billet turbos a pair of Borg Warner EFR turbos. The primary aka small turbo will be a 6258 with a 0.85 A/R on a tubular exhaust manifold with an external wastegate. That will be feeding into a EFR 7163 with an internal wastegate and a 0.85 A/R V-band housings located likely on the transmission side of the engine bay. The 2 of these turbos should be easily capable of producing 60-70PSI of boost pressure and enough air to produce 400-500hp.
I am not convinced the CP3 is the best option, but I am convinced the stock HPFP is not capable of doing much more than ~250whp it has issues on the stock injector nozzles at that power with maintaining adequate rail pressures. I am going with the GM LBL CP4.2 pump which stock can do ~600whp and that is at 2000bar rail pressure. I would like to try to use that to get to the 2500bar that the CUAA uses to get to it's 240PS rating. I thinking having the shortest injection event time is the key to having more HP without having issues with the valves, pistons, or injectors.
To answer your question yes I am using the stock pistons but in no way am I trying to do this on the stock rods or anything close to them. I have a set of Rostens I-beam rods ready to rock and roll in this engine. I have also ceramic coated the pistons and have a set of the old limit run of H11 tool steel head studs, but they were long so even after being shortened I am having another set made soon.
2003 indigo blue Golf TDI Gone!
81 VW Caddy needing Some love!
91 Audi CQ AKA "Eleanor" my unicorn!
09 Rabbit S now a TDI AWD.
91 200 20vt Avant
v8 coupe is offline   Reply With Quote
Old December 27th, 2016, 18:06   #22
Bigtoy302
CP3's are fine and make 500-600hp all day. Cheap also.
I like those EFR's but they are too big size wise. The are long.
Old December 27th, 2016, 18:41   #23
v8 coupe
Oh I am aware of that, but how do they like running at 2500bar?
91 200 20vt Avant
Old December 28th, 2016, 01:05   #24
Macradiators.com
On Bobby's car the CP3 runs at 2400bar if i remember correctly, but the CP4.2 is also a good choice.
We have a tune on 3.0 bitdi of 440+hp and car run 11.9s , and we havent upgraded the stock pump yet with the one from BMW M55d , always CP4.2 but higher output
CP3 Upgrade
Old December 28th, 2016, 08:18   #25
Bigtoy302
I don't know. The Duramax and Cummins guys run 1800-1900bar. Is 2400-2500bar needed? I'm not sure if it's needed with a pump that can actually flow big volume.
I'm still a learing about the common rail stuff. I run a mechanical P7100 pump cummins 12v still in my tow rig
Old December 28th, 2016, 21:32   #26
v8 coupe
Is it needed? that's very arguable but if I understand all this stuff correctly raising the rail pressure forces more fuel threw smaller holes in less time resulting in a larger amount of fuel in a shorter time. I am using a Duramax LML CP4.2 which runs stock at 2000bar and with larger turbo and injectors these engines are doing ~600WHp before a HPFP upgrade is needed. Using the CUAA stuff will be just like the stock CP4.1 stock where only one of the pistons in the HPFP is coming to TDC for every injection event. I believe VW uses the CP4.2 on the CUAA engine to have the second piston stabilizing the rail pressure at 2400bar. I plan on having a new injection pump pulley built for it the same size as the old ALH injection pump pulley to make it the same size as the cam gear resulting in each pistons coming to TDC as alternating injection events happen.
This is only a theory now, but it should solve a few issues with cutting the pump speed in half high rpm cavitation should be reduced/eliminated and with each piton having more time to refill with fuel before it sends pressure force into the fuel rail for an injection event. If this does work awesome, but if not it'll be back to the stock CR140 setup and see how that works out. I do believe that this is the pump to use for higher HP Common Rail TDIs but the CP3 is my fall back for now.
91 200 20vt Avant
Old December 29th, 2016, 00:43   #27
Macradiators.com
It seems you just want to make things complicated when they are simple , reliable and work well already.
Pump piston and TDC events are not important in multi piston pumps. 2nd piston is always off and this would mean it has no sense, its a parasite.
Instead The entire system works as an accumulator of pressure, i'm told they teach this in mechanics university here where they study this stuff.
Also rotating the pump at half the speed just because you imagine there is a cavitation problem might not get you far.
CP3 Upgrade
Old December 29th, 2016, 10:33   #28
v8 coupe
really they aren't important? Really because on the GM Duramax LML engine that I got this pump from it is setup so 1 of the 2 pistons was coming to TDC as an injection event happened. On the 3.0L TDI that uses a CP4.2 the pump is timed again so each piston was coming to TDC as an injection event happens. The fuel rails are not in any way large enough to store fuel at pressure between injection events. Also try not having the CP4.1 pump timed to have the piston coming to TDC on the injection event guess what the engine won't run. yes on the CP3 pumps it doesn't matter because they are 3 piston pumps not single or double piston pumps.
Yes you are probably correct I am trying to complicate things, but how many people are trying to run their TDI engine consistently at higher RPMs for long stints of time? I am sure 99% of TDI users won't ever have any HPFP high rpm cavitation issues because most might only occasionally see 4-6k RPM I am fairly sure I will see 3-6k a lot more. That is because my engine is being built to take abuse and a lot of abuse at that being a track engine. So yes for a street application the CP3 might be a great option and the CP4.1 pump with the cam and piston from the larger of the CP4.2 pumps would also probably be great, but not for my application. I am also doing quite a bit of "extra" stuff that for many is considered over kill and for a street engine it completely is. I am not trying to build a street engine so over kill is exactly what is needed to keep it from needing to be replaced every month or year.
91 200 20vt Avant
Old December 29th, 2016, 12:32   #29
Macradiators.com
We did not time the CP4.2 on the 2.0 CR engine and runs great, as i am sure it doesnt need any timing on the B8 CUA engine.
JD eng did no timing on the CFG engine and also works great.
It doesnt matter what you think, the entire fuel system works as an accumulator of pressure (rail + fuel pipes, there is quite some volume there).
Now you got me confused. what pump do you want to use? CP4.2 is running great and havent read of failures on the V6 engine.
I've red a few threads of 300+ builds ..not one seen the finish line.
CP3 Upgrade
Old December 29th, 2016, 16:12   #30
nate0031
nate0031's Avatar
TDI(s): 96 B4 Passat
The CP1H pump (similar to a CP3) in the Cruze diesel does not have pumping events timed to cylinder firings, and that's from the factory. The CP3 swaps on our CR140's also don't have pump events timed to cylinder firings. Both systems work just great. I agree with others on here, a CP3 is very reliable, cheap, easily modded, and more than capable of supplying the fuel you need. Now that there's a bolt on kit for our engines, that'd be the way I'd go hands down.
Really interested in seeing what a CJAA with a CP3 and big turbo can do. Also curious about the head flow concerns.
2005.5 VW Jetta - 1.9 Turbo Diesel - 5 Speed
2000 Audi A6 - CJAA Common Rail TDI - Quattro - 01E
2005 Ford F-350 - 6.0L Turbo Diesel - Auto - 4x4
nate0031 is offline   Reply With Quote
DSG/Common Rail Help!?!?! mxracer291 VW MKVI-A6 Jetta Sedan (~ 2011+) 16 July 1st, 2016 09:46
common rail F/S ronbros TDI 101 7 August 23rd, 2012 06:11
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 07:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 21:33
PD vs common rail Sacha TDI 101 3 September 14th, 2001 07:48
Page generated in 0.17603 seconds with 10 queries
[Output: 141.45 Kb. compressed to 119.58 Kb. by saving 21.87 Kb. (15.46%)]
