Old February 7th, 2017, 10:36   #136
Rub87
Maybe both of you should just measure from inj hole surface down and post dimensions. Then there is the least room for error.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old February 9th, 2017, 04:03   #137
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
38.xx on both inlet and exhaust.
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old February 12th, 2017, 06:33   #138
morpwr
Fuel Economy: 40-60
Question PD vs CR
I found an old post that said the PD 2 litre 4V heads were the same for the 140 and the 170 horse versions. The injectors were different but the heads would take any of the injectors. Is the CR head much different as far as ports and valves go, from a PD head. There also was a post in this thread that said 4V heads are better than ported 2V heads. How much different? Going to England in May, so I was thinking of getting a PD 4V head for my BRM if they are better out of the box. I like Darksides build up of BKD that made 300BHP. Thinking of making some 9mm injectors to get away from large low pressure nozzles.
morpwr is offline   Reply With Quote
Old February 13th, 2017, 01:21   #139
Rub87
Ok, this fits 1:1 with the 2.7 V6 head I have.
Old February 3rd, 2018, 11:32   #140
Bigtoy302
Anybody finish their head and have it dynoed? I have two CJAA's sitting in my shop i'm going to start playing with.
Bigtoy302 is offline   Reply With Quote
DSG/Common Rail Help!?!?! mxracer291 VW MKVI-A6 Jetta Sedan (~ 2011+) 16 July 1st, 2016 09:46
common rail F/S ronbros TDI 101 7 August 23rd, 2012 06:11
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 07:15
common rail 03GOLFTDI19 VW MKIV-A4 TDIs (VE and PD) 8 September 19th, 2003 21:33
PD vs common rail Sacha TDI 101 3 September 14th, 2001 07:48
Page generated in 0.14205 seconds with 10 queries
[Output: 71.56 Kb. compressed to 63.57 Kb. by saving 7.98 Kb. (11.15%)]
