Old December 23rd, 2017, 13:24   #61
specialed1995
Since the weather is turning colder I've had some spare time to start working on this project again.
I extracted the broken bolt that snapped off many months ago after soaking it in penetrating oil several times and working it in with the air chisel. It finally broke loose and came out turning it with a pair of pliers.
I also removed the factory belt tensioner and sawed off the boss that it goes through on the front to make room for the new tensioner mount I need to fabricate. As I said before I’m using jimbote’s setup which retains the A/C compressor but deletes the power steering pump. I’ll have to do some calculations and figure up exact how everything needs to be.
I removed the side motor mount as well (the one right in front of the turbo), as I’ll be fabricating mounts similar to CFM’s designs and won’t be needing it. Will probably end up selling any leftover VW parts I end up removing on this conversion.
The intake manifold was very gunged up after 335k miles so I removed it to get it ready to clean. I plan on soaking it in diesel fuel and scrubbing it with a brush etc. to loosen and remove the carbon. There’s also a bit built up inside the cylinder head, so I’ll rotate the engine around until the intake valve for the cylinder I’m cleaning is closed, and clean and scrub the port with a brush and blow it out with compressed air, plugging the other open ports of course. If anybody has any tips or suggestions about doing this please let me know.
I’m going through the wiring harness now and labeling all the connectors to see what I need to keep and what can be gotten rid of, and I’ve run into some trouble. The 24 pin connector that goes to the engine wiring harness won’t come unplugged, and I need to get it unplugged to replace the glow plug wiring harness, as it has dry rotted and fallen apart.
What’s the trick to undoing this connector? I slid the plastic ring that goes over the rubber seal back, but try as I might it wouldn’t come apart. I could see no locking tabs anywhere so I suck a flathead screwdriver around the base and lightly pried on it thinking it was stuck. I didn’t want to pry too hard and break it so I stopped and decided to ask for some help. If anybody could offer a tip on how to unplug it I’d be grateful!
More work on this project is coming after the holidays!
specialed1995 is offline   Reply With Quote
Old December 23rd, 2017, 16:45   #62
ToddA1
Fuel Economy: Dismal
The large side gets rotated CCW.
When I replaced the GP harness on a recently purchased Jetta, it was frozen. May never have been disconnected. Rotating CCW, broke one of the tabs on the engine side connector.
Support it with some large slip joints, if possible. I had to use them to tighten down properly, and it’s a tight area. I also used some silicone grease on the threads.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old December 28th, 2017, 16:23   #63
specialed1995
I've figured out almost all of the wiring on the ECU harness, but there are a couple connectors I can't figure out what they go to.
1st connector (4 way)
Pin 1 - T68/10
Pin 2 - T68/33
Pin 3 - T68/56
Pin 4 - T68/33
2nd connector (2 way)
Pin 1 - T68/27
Pin 2 - T24/9 (VSS Pin 1)
According to all the wiring diagrams I can find, ECU Pins 10, 27 and 56 are listed as "not used", so I have no idea what they are for.
Cleaned up the intake manifold a little bit yesterday by soaking it in a drain pan filled with diesel and scrubbing with a wire brush. It removed a good bit of the carbon, but it could still be better so I plan on doing it again tomorrow.
Old March 6th, 2018, 17:20   #64
specialed1995
Been a few months, but I've made some progress with the project.
Since I last posted, I've finished cleaning the intake manifold and also cleaned the intake ports on the cylinder head as best I could, making sure the valves were closed before knocking anything loose. I then blew everything out with compressed air and reinstalled the intake using the old gasket coated in copper spray on both sides (Was this a good idea?)
Also replaced the rubber fuel return hoses on the injectors with 3mm braided diesel vacuum hose. I purchased a new end cap for the last injector, but I've misplaced it and have to find it so I can put it on.
Removed the transmission ends on the Saturn axles so that just the splined shaft remains, hopefully that will make it easy when measuring the axles. That way I can just slide them where they need to be and weld everything up.
Purchased some 3/4 x 2 1/2 aluminum stock in order to fabricate the custom belt tensioner bracket for my serpentine belt setup that will bolt to the alternator bracket. Once it arrives I'll be working on that.
More work is still to come very soon. Would like to have a complete drivetrain that's ready to drop in by the end of summer.
Old March 7th, 2018, 05:32   #65
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
I would get a new intake gasket - they are cheap, and compress during their one-time-only use.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 9th, 2018, 16:43   #66
specialed1995
Got the serpentine belt tensioner bracket fabricated today, it looks pretty crude but the principle works. I turned the engine over via the crank bolt several times and everything seemed okay. In practice it remains to be seen whether it will work long term, but all tests point to good!
Will post side by side comparison of my application and jimbote's, who gave me the design.
Will also be purchasing a NEW intake gasket and installing it shortly, as it is much easier to change with the engine out.
Looking into doing the timing belt and water pump next, just another thing I'd rather get taken care of now rather than later on once I have the project car. As I've said I want everything as ready to drop in as possible before I get the car.
Saturn TDI Conversion CFM TDI Conversions 279 September 29th, 2017 05:32
saturn clutch greenskeeper General Automotive 0 January 10th, 2012 14:26
Saturn VUE conversion TDI candidate Sand Bag TDI Conversions 2 August 11th, 2009 03:57
tdi into 04 saturn? Toby_B TDI Conversions 37 October 18th, 2007 18:13
Saturn matt1 General Automotive 26 September 21st, 2006 14:00
Page generated in 0.13998 seconds with 10 queries
[Output: 79.13 Kb. compressed to 69.90 Kb. by saving 9.22 Kb. (11.66%)]
