Old December 22nd, 2017, 13:21   #121
FraggyTDI
TDI(s): 04 Jetta
Originally Posted by Fix_Until_Broke View Post
I don't know the specific logic - most of them are a sourced input that gets pulled to ground when the switch is closed (pressure is above spec).
That way if the wire comes off/breaks it tells you that you have low oil when you might not rather than the other way around.
Since there is only one wire to the switch it's grounded at some point, I just don't know when.
This is what i assumed as well. That if unplugged it would trigger a light. However Mone does the opposite. As far as the ground goes I assume it does it through the sensor it's self. However at this point I'll just set an alarm on my gauge.
FraggyTDI is offline   Reply With Quote
Old February 7th, 2018, 18:50   #122
FraggyTDI
TDI(s): 04 Jetta
Tonight we achieved Zippy in my commuter. Maybe a little more then Zippy. The tuning process has begun to try and tame this beast and I mean beast. The logs don't really do the joy justice. But we definitely have some work to do on the mapping. But I'm happy to say I achieved what I wanted out of this car.
thanks- clean intake-- zippy like new Indigofarm TDI 101 2 November 18th, 2009 06:53
Come on folks-Zippy needs our help!!!! Time running out for calendar orders!!! tdidieselbobny TDI 101 9 July 30th, 2007 07:38
Zippy's Trek Xcountry! Zippy_car Road Trips 36 May 1st, 2007 22:07
Thanksgiving day GTG @ Zippy's! Zippy_car Eastern USA 9 November 28th, 2006 06:07
Zippy's Twin, Russellville, Arkansas thermographer Sightings 0 November 22nd, 2005 09:21
Page generated in 0.12897 seconds with 10 queries
[Output: 54.85 Kb. compressed to 50.87 Kb. by saving 3.98 Kb. (7.26%)]
