Old December 12th, 2016, 12:11   #31
FraggyTDI
TDI(s): 04 Jetta
Originally Posted by greengeeker View Post
Score!
Car is in stupid good condition. Kind of feel bad tearing it.
Originally Posted by turbovan+tdi View Post
Dammnit, just bought PD150 injectors and an exhaust manifold.
It's an addiction
Originally Posted by purediesel View Post
Pretty much my exact build.. I'll be keeping an eye on this. Keep it going!
Awesome! Maybe we can share notes at some point.
FraggyTDI is offline   Reply With Quote
Old December 12th, 2016, 12:31   #32
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Convert the Passat to a manual and take the project from there (:
Old December 12th, 2016, 13:45   #33
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
or fix it, sell it and buy this:
http://forums.tdiclub.com/showthread.php?t=471046
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old December 12th, 2016, 15:35   #34
FraggyTDI
TDI(s): 04 Jetta
It has crossed my mind, however if I'm going down that road I'm finding a A4 wagon with quattro and using that. Or an Audi Allroad
Eh I'm a built vs. bought kind of guy and my favorite part is building the engine.
Old December 12th, 2016, 18:31   #35
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I have one.
Old December 12th, 2016, 21:46   #36
FraggyTDI
TDI(s): 04 Jetta
I have one.
You're the worst lol. My mind is already playing out plans of building two cars. Basic commuter using the alh engine in the golf and beasty allroad using the BHW built up.
Old January 4th, 2017, 10:34   #37
FraggyTDI
TDI(s): 04 Jetta
Hello all, I'm finally back from the holiday and ready to tear into my new passat I got. I have a few questions though.
Should I have the BHW rehoned or do I just use it as is?
Should I get stronger rods or are stock adequate?
Old January 4th, 2017, 18:39   #38
turbovan+tdi
turbovan+tdi's Avatar
Rods are good for 250-300hp AFAIK-not sure if that's crank or wheel. Have the machine shop check the bores for roundness. BTW, rings for a BHW aren't cheap, dealer are $200 a hole, had to have Total Seal make me a set.
From an earlier post-
@FraggyTDI, if you sell your 11mm pump, you'd be already well on the way towards buying one of the Passats listed with the BHW engine. Put in suitable injector nozzles, GTB2060VLKR or GTD2060VZ turbo and a remap and you can be at 250 HP without any engine internal upgrades!!
2003 GSW, 2.0L ALH, Colt Cam, 1756 turbo, auto, silver, 380k-Wife's.
2003 JSW 1.8T future TDI, silver. 2006 JSW, TDI 5 speed, blue.
Old January 5th, 2017, 08:30   #39
FraggyTDI
TDI(s): 04 Jetta
IDparts has BHW rings $24 a set. So I'm thinking it might be worth getting the cylinders rehoned. However this engine only has 120k miles on it.
Old January 5th, 2017, 09:48   #40
greengeeker
I would leave it alone. Build it to Dave's build spec and revisit the need for more power later (and the subsequent beefing up of the shortblock). I think you'll be more than satisfied with 250hp...especially if you're just commuting with it.
- Nick -
Old January 5th, 2017, 09:59   #41
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Leave it alone! Don't try to fix what ain't broke!
Old January 5th, 2017, 10:06   #42
FraggyTDI
TDI(s): 04 Jetta
I think I will be plenty pleased as well.
Haha good point. I'll just do the balance shaft delete and call it good. Also saves me money.
Old January 5th, 2017, 20:25   #43
turbovan+tdi
You sure about that? I checked his site and nothing. If I missed that, damn it.
Edit, I was right, sort of, lol.
Inidivudual piston ring set for the 2.0L piston (81mm diameter) used in the BHW, CBEA and CJAA engines.
These are special order and come from Germany. Lead time is usually around 2 months.
Old January 6th, 2017, 10:11   #44
FraggyTDI
TDI(s): 04 Jetta
Yikes I didn't see the 2 month part. I think I'll just leave mine as it is.
Old January 31st, 2017, 09:52   #45
FraggyTDI
TDI(s): 04 Jetta
BHW is out of the passsat with the harness tagged out. I've stripped off all the accessories and I'm doing some cleaning on it now.
Question for today is, how well will the passat harness plug into the golf harness as far as the chassis harness goes? I'm swapping over the ECU with the engine so I figured the whole harness should come.
Also do I take the time to remove the un-needed electrical parts like auto related plugs and egr.
Or how much of the golf engine harness would work?
I'm terrible when it comes to harness layouts and have yet to find a decent schematic to allow me to pin out things.
Thanks in advance!
thanks- clean intake-- zippy like new Indigofarm TDI 101 2 November 18th, 2009 07:53
Come on folks-Zippy needs our help!!!! Time running out for calendar orders!!! tdidieselbobny TDI 101 9 July 30th, 2007 08:38
Zippy's Trek Xcountry! Zippy_car Road Trips 36 May 1st, 2007 23:07
Thanksgiving day GTG @ Zippy's! Zippy_car Eastern USA 9 November 28th, 2006 07:07
Zippy's Twin, Russellville, Arkansas thermographer Sightings 0 November 22nd, 2005 10:21
Page generated in 0.10349 seconds with 10 queries
[Output: 138.34 Kb. compressed to 116.60 Kb. by saving 21.74 Kb. (15.71%)]
