Old November 23rd, 2016, 08:50   #16
Exenos
TDI(s): 02 Golf
Originally Posted by greengeeker View Post
http://forums.tdiclub.com/showthread.php?t=410054
I'd say the fabrication is the easy part. Tuning them to do what you want proves to be the more difficult [read: time consuming] proposition. Foukhest build would be a prime example of this....top notch fabrication (I actually have his compound manifold setup now ) but never dialed in the tuning. Ended up parting out and moving onto something else.
That's what I was meaning, apologies if I was misleading with the "setup" part.
Exenos is offline   Reply With Quote
Old November 23rd, 2016, 08:53   #17
FraggyTDI
TDI(s): 04 Jetta
Ok, after evaluation I think my new path will be:
Acquire BEW engine
Bore out for BHW Pistons
Lower horsepower goals
This allows me to build a very stout engine with the potential to eventually go dual stage if I so please at a later date.
FraggyTDI is offline   Reply With Quote
Old November 23rd, 2016, 08:56   #18
turbovan+tdi
turbovan+tdi's Avatar
Subb'ed, sort of on the same path, just not 250 worth,
If you buy used BHW pistons, which I did, rings are impossible to find, I had to have some made but still miles cheaper than the dealer, which wanted $800 for rings,
Old November 23rd, 2016, 10:02   #19
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Aye - why not start off with a complete BHW to begin with seeing how cheap you can buy whole donor cars close to you??
You can swap the whole BHW engine and move over some parts from your ALH, e.g. oil pan, etc. Jimbote did a thorough write up here:
http://forums.tdiclub.com/showthread.php?t=308134
The complete swap will be much simpler if you have a donor car because you'll also need the ECU and engine harness, not just the longblock, to operate the PD injection system. If you're putting on an ALH head, it's easier from the ECU standpoint and you also move over the injection pump bracket and crank position sensor wheel from the ALH.
Originally Posted by FraggyTDI View Post
When you use the BHW do you just use the short block with pistons and crank? Then mount a BEW or ALH head on it? Or do you swap in the whole engine and ECU?
Old November 23rd, 2016, 10:36   #20
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
@FraggyTDI, if you sell your 11mm pump, you'd be already well on the way towards buying one of the Passats listed with the BHW engine. Put in suitable injector nozzles, GTB2060VLKR or GTD2060VZ turbo and a remap and you can be at 250 HP without any engine internal upgrades!!
Old November 23rd, 2016, 11:11   #21
FraggyTDI
TDI(s): 04 Jetta
Yup this is the path I'm going down at the moment. I have the VNT 17 up for sale, the pistons and rods block and 11mm pump. I should be able to get the whole car using all that money. I'm going to try and low ball the 800 passat since i would have to tow it back.
But I'll probably still rebuild all the internals so I can choose to step up at any time.
Would you do a balance shaft delete? I know this was a thing on the audi 2.0t's but usually had issues after the delete.
Old November 23rd, 2016, 12:03   #22
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Yes, do the BSM delete.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old November 28th, 2016, 11:36   #23
FraggyTDI
TDI(s): 04 Jetta
Sold enough parts to go buy a passat. Anyone want any parts from it?
Old December 8th, 2016, 14:08   #24
FraggyTDI
TDI(s): 04 Jetta
Good news everyone! Got a 05 passat for $550 with 200k miles on it!
Old December 8th, 2016, 16:41   #25
greengeeker
Local?
- Nick -
Old December 8th, 2016, 19:04   #26
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
Nardo Grey is my favorite color as of late. I would consider wrapping mine, but I'm a car detailer and I put SO MUCH work into my 2004 paint (to demo my skills to customers), so I can't wrap it. I've gotten most of my business from people stopping me on my car.
VincenzaV is offline   Reply With Quote
Old December 9th, 2016, 08:59   #27
FraggyTDI
TDI(s): 04 Jetta
Local?
Duluth, Car went up on craiglist 2 days ago. Guy needs it gone or city is taking it.
I keep going back and forth between wrapping it or painting it. I love the color, it has so much depth I guess you would say. It's matte without being matte if that makes sense.
Old December 9th, 2016, 11:39   #28
greengeeker
Score!
- Nick -
Old December 10th, 2016, 20:21   #29
turbovan+tdi
Dammnit, just bought PD150 injectors and an exhaust manifold.
Old December 11th, 2016, 11:33   #30
purediesel
Pretty much my exact build.. I'll be keeping an eye on this. Keep it going!
purediesel is offline   Reply With Quote
thanks- clean intake-- zippy like new Indigofarm TDI 101 2 November 18th, 2009 06:53
Come on folks-Zippy needs our help!!!! Time running out for calendar orders!!! tdidieselbobny TDI 101 9 July 30th, 2007 07:38
Zippy's Trek Xcountry! Zippy_car Road Trips 36 May 1st, 2007 22:07
Thanksgiving day GTG @ Zippy's! Zippy_car Eastern USA 9 November 28th, 2006 06:07
Zippy's Twin, Russellville, Arkansas thermographer Sightings 0 November 22nd, 2005 09:21
Page generated in 0.17866 seconds with 10 queries
[Output: 132.92 Kb. compressed to 111.50 Kb. by saving 21.42 Kb. (16.12%)]
