cencarnacion
Working on replacing the timing belt of a non-running 2003 NB that I recently bought. A gorilla must have worked on the car. The large roller bolt is badly stripped as well the small top roller bolt. Since these are critical components that need to be strongly fastened, I want to repair the threads correctly. I am not comfortable with just re-threading using a tap. I've used helicoil before but not sure if it goes deep enough. Thank you for your input.
