Old October 12th, 2016, 05:11   #61
Rub87
both are possible. I like cp3 more because of the more robust design, if I look to cp4 inside I still wonder myself each time again how this can even remotely work lol
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 29th, 2016, 12:10   #62
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Any results? Cp3 running nicely?
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
Bobby Singh is offline   Reply With Quote
Old October 30th, 2016, 07:07   #63
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
I did not remove the cylinder head on my car because replacement car is not ready, this week i hope to finish it somehow.
Lots of work to do between head work, cp3 , timing, injectors , cams.
Hope to put the cams properly inside the new head as i dont have VAG tools.
And after everything is done, i have the 7speed DQ500 gearbox to fit on the car, and i really dont wanna do that, because i will aslo have to build a new downpipe
For the beginning i'm gonna try to see if 02E remapped holds 550Nm, if not , gonna leave the car in Bucharest to be finished and fly home.
Macradiators.com is offline   Reply With Quote
Old November 7th, 2016, 03:36   #64
xjay1337
Are you keeping 3bar map?
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old November 8th, 2016, 04:10   #65
Macradiators.com
Ordered the 4bar MAP from Bosch, genuine 33€ with discount 03K906051 , usually 50€
STAR diesel quick connect fittings for the CP3 pump
turbo upgrade to 2265 maybe ..still thinking of what to do
Old November 8th, 2016, 06:54   #66
Machineman
Go with a borg warner S3??v
Machineman is offline   Reply With Quote
Old November 8th, 2016, 08:32   #67
Machineman
What is the max power you can get from cr140 injectors? Assuming with a good tuning and a cp3 conversion
Old November 8th, 2016, 09:18   #68
xjay1337
I'm not sure anyone has maxed cr140 injectors
in uk cr170 and 140 are the same aside from turbo.
Old November 8th, 2016, 10:07   #69
Machineman
Ok what has been max from cr170
Old November 8th, 2016, 12:33   #70
Rub87
depends on railp and amount of air u can or can not get into the cylinder.
Old November 8th, 2016, 13:51   #71
Machineman
Assuming those were maxed out as well im thinking of moving on from 8v pd to 16v cr would they outflow my firad 120s ?
Old November 8th, 2016, 14:06   #72
Macradiators.com
probably i'm gonna put a big hole in my pistons in the next few days ..to be continued
on the 303hp tune from what i understand the amarok biturbo injectors are almost maxxed out, not much left (nozzles only mounted on CBAB inj body)
italians also were at the limit on the 03L130855X injectors (identical to mine)
Old November 8th, 2016, 18:40   #73
[486]
TDI(s): 02 golf ALH
are injectors straight in to the head? maybe you could use 24v cummins nozzles or something
[486] is online now   Reply With Quote
Old November 8th, 2016, 22:16   #74
Macradiators.com
we have something that fits , gonna do the install later today just hoping it will go ok.
Old November 10th, 2016, 05:49   #75
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
Some hoping going on here )
Bafta cu proiectul ..
Lucian189 is offline   Reply With Quote
Different kind of CR turbo build ibexlatham TDI Power Enhancements 65 July 5th, 2018 21:49
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 21:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 13:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 05:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 09:56
Page generated in 0.16283 seconds with 10 queries
[Output: 126.74 Kb. compressed to 105.69 Kb. by saving 21.05 Kb. (16.61%)]
