Old October 4th, 2016, 10:59   #46
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
CP3 pump is more than enough for my goal
anyway, we'll see results from JD Engineering in NL before i map mine.
on stock pump they got 278HP on same CR engine, we see what a good pump can bring to the table.
Same dyno, different hardware, let the numbers talk.
If they do 290+ somebody must admit they got it wrong. If they do 300+ , should close shop and find another job
Macradiators.com is offline   Reply With Quote
Old October 4th, 2016, 11:50   #47
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Don't they also claim 450hp from biturbo v6?
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old October 4th, 2016, 12:05   #48
Macradiators.com
Dont know.
Eric in romania did a job on the biturbo with dpf off
Launched the car stock then remapped here is the dyno.
JD i think have full exhaust and wagner IC
Old October 7th, 2016, 04:56   #49
Macradiators.com
Since it's impossible to buy a kit for the CP3 i decided to build it myself, next week should be ready.
I put in 2 hours of work in order to get the measures right an make a prototype on my lathe in order to have the sprocket positioned at the right height so the belt will sit correctly on it.
Tomorrow i will be testing the smaller displacement CP3 pump i just got and will make the final product on EDM machine next week.
Old October 7th, 2016, 05:12   #50
Rub87
strange punp gear you have, looks totally different than mine. what car is it from?
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 7th, 2016, 05:34   #51
Macradiators.com
Sprocket is from CP1 pump year 2011 , engine i think. there are 2 types, the other one is with 3 screws.
since i have this one to do measuring i will use it now.
I must invent something to mount the cams on the new head
Old October 7th, 2016, 06:43   #52
turbobrick240
turbobrick240's Avatar
You should be able to buy a cp3 kit from 2micron, fixmyvw.com, and GDM.
Old October 7th, 2016, 16:04   #53
Macradiators.com
Andrew doesnt have it so i wasted no time , saved myself some nice money also for 2h of work
got 3 pumps, 2 free and 3rd paid 50$ after inspecting it, so the CP3 kit will cost me ridiculous $
Old October 11th, 2016, 09:28   #54
xjay1337
how is it going for you.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old October 11th, 2016, 12:19   #55
Macradiators.com
Took some measures to make the adapter for the CP3 pump, bingo from the 1st attempt
Tomorrow the CP3 mounting kit should be ready.
Old October 11th, 2016, 12:33   #56
Rub87
haha, then the fun part starts
Old October 11th, 2016, 15:12   #57
xjay1337
Good luck mapping :-)
Maybe Bobby can do a remote tune
Old October 11th, 2016, 23:33   #58
Macradiators.com
i'll launch the car with REVO2 sw i have now, then do the tuning so we can compare before and after, then i'm sure the forum "haters" will be unleashed
not all tuners are capable, but we already established that i think
Old October 12th, 2016, 02:20   #59
xjay1337
I know. Only 2 tuners has tuned gtb2260 with cp3
Old October 12th, 2016, 06:09   #60
Macradiators.com
seems like in italy and nl they had better luck with CP4.2 pumps than cp3 tunes.
CP3 kit is almost done, just a few tweaks to do
Different kind of CR turbo build ibexlatham TDI Power Enhancements 66 September 26th, 2018 17:51
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 22:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 14:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 06:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 10:56
Page generated in 0.19110 seconds with 10 queries
[Output: 131.50 Kb. compressed to 109.74 Kb. by saving 21.75 Kb. (16.54%)]
