Old September 28th, 2016, 12:58   #31
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Many years ago the same things were being said of the older engines...then the tuners finally figured out all the tricks. I suspect this is the same. It takes time to learn the tricks.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old September 28th, 2016, 13:00   #32
xjay1337
you can't trick a mechanical object into flowing more air or pumping more fuel.
there are tricks to get past some restrictions but it's like saying pd130 injectors will do 350bhp, just an impossibility.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old September 28th, 2016, 13:12   #33
mrchill
mrchill's Avatar
Perhaps you missed where I said tuning. Hardware helps a lot as well. And the hardware part is trivial. The primary power dam on these cars is the tuning. No one needs to add more hardware until the tuning is perfected. There is no reason why these engine with stock internals cannot reach 300hp. Will it last forever at that level? Who knows? Have to get there first.
Old September 28th, 2016, 14:25   #34
xjay1337
Stock fuel pump on the CR engine will not provide enough railp or fuel for 300bhp. For the 5000th time. No matter what amount of tuning wizardry you do on the ECU side.
Neither does the head flow enough air to allow you to add more fuel! You just end up smoking away...
Old September 28th, 2016, 14:37   #35
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
stock pump 278hp 2 weeks ago in NL freakin famous tuner, stock pump 282 from top 3 tuners in Italy and 284hp from Manuele Ceci
facts not words on proven dynos, all independent professionals
means the "creme de la creme" from Italy, NL and Ro are all charlatans because 3 guys on a forum never vent over 270 never mind the reasons why
Macradiators.com is offline   Reply With Quote
Old September 28th, 2016, 16:44   #36
mrchill
mrchill's Avatar
I remember when most folks believed that the 8 valve Tdi would never pass 180 hp because the head would not breath enough and the pumps couldnt deliver enough fuel. There are examples of 300 hp 8 valve rotary pump tdis....so dont you suppose that a 16 valve common rail tdi with a bit more than double the fuel pressure should do at the very least the same? And mind you, many of the strengthening techniques we add to the older engines are stock on the new ones. The hardware could use some improving...in fact, I said 6 or so years ago that these heads flow poorly...but still...they can do 300...even without the improvements.
Old September 29th, 2016, 01:38   #37
xjay1337
Well, no clearly it doesn't do more the figures you expect.
We know the 8v heads flow limits around 260-270 without porting or putting cams in to help. And it turns out the cr heads are pretty much the same, maybe a tad lower. How many times do we have to say 1.1 lambda is no more air available! Thats a headflow issue.
Im getting fed up of repeating myself. The stock cr pump wont do those figures. I know this because i have tried it! Hence why we are now on a cp3 fuel pump upgrade. And while we no longer have railp or inj quantity issues we are into headflow.
To say stock fuel pump can do 1750bar at 4k and injecting over 90mg iq is impossible.
I am not aware of any car anywhere injecting higher fuel IQ than me.
The true measure of speed is 1/4 mile terminal speed and claimed 280+ bhp cars are no faster than my car at 255bhp. Go figure.
Old September 29th, 2016, 04:15   #38
mk1-83
Fuel Economy: 1:15
Yes end speed at 401 mm say a lot about engine hp
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old September 29th, 2016, 07:15   #39
mrchill
mrchill's Avatar
Terminal velocity is a factor of power....weight and aerodynamics. If the weights are identical, then power and aerodynamics are the deciding factors. In terms of some making 300 hp or so...and others making 250, its either a difference in skill, or a difference in measurement. Its a shame that there isnt a place everyone would be willing to go to measure speed over distance, dyno and for good measure, have a scale. This way, there would be no question. However, it seems no one is willing to prove themselves in this way. As a result, there will always be argument.
Old September 29th, 2016, 21:59   #40
[486]
TDI(s): 02 golf ALH
mass doesn't matter when you're going flat out
it matters for acceleration
[486] is offline   Reply With Quote
Old September 30th, 2016, 10:17   #41
flee
Fuel Economy: 40-ish
This is only true when you have an unlimited distance to reach Vmax.
In the real world you only have so much time before you have to begin braking,
so mass will come into play particularly with higher power levels.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old September 30th, 2016, 12:36   #42
turbobrick240
turbobrick240's Avatar
I see what you are saying, but it does not require unlimited distance to reach Vmax. The distance is dependant upon many factors including mass, power, friction, etc.
Old October 4th, 2016, 05:23   #43
Rub87
sneak preview, in my car atm I have for instance 100 mg with lambda 1,2 at 3500 rpm with 2.2 bar boost. this is with emp:boost ~1:1 with ported head and state of the art camshafts.
in a stock head car with 2260 u need for same lambda 96 mg and 2.4 bar of boost. go figure.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old October 4th, 2016, 05:31   #44
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
You have just ruined the WR attempt
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
Bobby Singh is offline   Reply With Quote
Old October 4th, 2016, 05:34   #45
Rub87
nah, im not there yet, need to sort some issues with the staging, time is my worst enemy
Different kind of CR turbo build ibexlatham TDI Power Enhancements 44 Yesterday 21:29
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 21:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 13:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 05:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 09:56
Page generated in 0.17321 seconds with 10 queries
[Output: 134.55 Kb. compressed to 112.91 Kb. by saving 21.64 Kb. (16.08%)]
