Old February 1st, 2018, 02:22   #316
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Dyno is a lottery ..who gives bigger numbers, like d:ck measuring with different scales. Be real.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old February 1st, 2018, 02:39   #317
Jukums
All depends on HP plot in dyno sheet, make turbo spikes+fuel will give you much hp, but 100-200km/h car will be slow, because 80-90% of time there will be much less hp.
Jukums is offline   Reply With Quote
Old February 1st, 2018, 05:41   #318
diffas
diffas's Avatar
Thats why you have gearbox to run car proper gear for maximum acceleration. These tdis usually have quite large maximum powerband compared some gasoline engines. You may have max hp 90% available over 2000rpm wide window.
diffas is offline   Reply With Quote
Old February 1st, 2018, 09:27   #319
xjay1337
But you were going crazy when Italy tuners were doing 290hp on stock pump stock head
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3” Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old February 1st, 2018, 12:00   #320
Macradiators.com
I discovered an ugly reality Jamie, where impostors pass as great tuners and numbers are created by magic on
Thats why now i tune my car on the street, real load, air friction, stress on components.
Not sure 10s is something possible on this one but trying.
Talking numbers, JD just did another 445hp biturbo on the superflow. LOL
CP3 Upgrade
Old February 1st, 2018, 12:58   #321
raffshore
Said the guy with the world record 3.0 lol
You are being ridiculous about the youtube video i posted. Its as real as it gets.
Jamie a 360hp gti does 10.36s , a 410hp one does 8.9s ..same weight as our cars. I guess i need to publish the time slips for you to believe.
2 cars rated at 350hp on same dyno, different tuners, can go totally different on track, with huge differences between them.
I am the one being ridiculous? I hail the king
raffshore is offline   Reply With Quote
Old February 1st, 2018, 13:53   #322
xjay1337
Exactly how my car is tuned then. We just use dyno to confirm figures
JD dyno must be very happy.
Old February 16th, 2018, 23:02   #323
Macradiators.com
Took advantage of the nice weather to take down old turbo.
Also a few minor mods to do and ready to start again towards my goal.
CP3 Upgrade
Old February 16th, 2018, 23:32   #324
adamss24
Fuel Economy: 35-45mpg
Where these ugly welds produced with that Fronius welder I see in the back ground ? Such a waste of a good tool...turbo looks good, what was the spec ? I take it it wasn’t a stock gtb2260vklr ?!!
adamss24 is online now   Reply With Quote
Old February 17th, 2018, 07:33   #325
Macradiators.com
Manifold is made by a bulgarian company profidiesel..
Served me well for 12k without any problems. The one i put in the car in a few days will look much better made in poland by Bizon Garage.
Turbo is not stock, should be good for burning lots of fuel at 800 egt lol
CP3 Upgrade
Old February 18th, 2018, 00:28   #326
adamss24
Was The turbine upgraded at all ? Any fancy ceramic ball bearing cartridge in it ? Take no offense but the welds on that manifold do look like they were made by a beginner...hence why I asked if they were made with the fronius ! If it works well then, it did serve it’s purpose...I have friend with a vklr turbo fitted on a dark side manifold and that cracked a short while after being installed. In the end we made a cantilever bracket with rose joints in order to stop it from cracking. Dark side advised against it but it did work although Vlad bought an m3 twin turbo so the 2.0 tdi doesn’t get used much !
Old February 18th, 2018, 00:35   #327
adamss24
I also cannot see any flexi joint in your downpipe, i am surprised it’s not cracked yet ! I need to send you a pm, I too work on a gtb2260vklr turbo to fit on my seat exeo tdi however I need to buy a flange with round ports to suit my CR engine...I have the manifold built already however i made it to fit a Ve/pd engine so it will need alteration ! I also want to install a cp3 pump at some point and a few more bits and bobs !
Old February 18th, 2018, 11:10   #328
Macradiators.com
The flex part is 250mm long and is connected by the vband you see to the second part of DP.
I modified the DP and made it 2 piece connected by vband so i can easily remove it, happy with how it works. I removed the DP from the top in 2 minutes .
Drop me a pm on fb and we can talk about it.
The manifold has no cracks after 2 years of service, yes, it could be made better for sure, that is why i sold it and waiting for new one. Will post photos when it arrives. For 500€ this one worked just fine.
I dont buy overpriced stuff...as there are plenty of choices if you search well enough.
Tomorrow i present you my tool for springs removal without removing the cyl. head from the car.
CP3 Upgrade
Old February 19th, 2018, 03:56   #329
Rub87
If you want I have a whole kit for sale for round port exeo. with normal 2260vk (watercooled from v12 tdi) fits w stock airbox and comes with oil/waterlines and downpipe
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old February 19th, 2018, 18:00   #330
adamss24
Thanks Ruben, I will think about it mate...to b honest the car is high mileage and not really worth the hassle...I have already fitted a bv43a turbo and made an entirely 3” exhaust system with a single motorbike back box. I also have the manifold already built but it’s been made/welded with a ve/pd exhaust manifold flange so it needs a CR flange welded in instead. I might do a new one from scratch along with slightly increased diameter runners ! I have all the ingredients in the garage just need to pull my finger realy ! Thanks for the offer anyway !
Different kind of CR turbo build ibexlatham TDI Power Enhancements 41 March 18th, 2018 19:39
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 21:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 13:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 05:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 09:56
Page generated in 0.19806 seconds with 10 queries
[Output: 136.08 Kb. compressed to 114.45 Kb. by saving 21.62 Kb. (15.89%)]
