Old December 8th, 2017, 19:44   #286
keaton
keaton's Avatar
TDI(s): 2005 Mk5
can you update the thread & post an load the photos on here? since photobucket changed their 3rd party hosting rules all the threads have dead photo links.
2015 MK6 Jetta S TDI w/DSG
2005 Chevy Corvette, 1-7/8 long tube headers, 3" Catless X-pipe, NPP Dual mode mufflers, tuned.
1996 Chevy Silverado, Headers, tuned
1960 El Camino (project)
keaton is offline   Reply With Quote
Old December 13th, 2017, 10:20   #287
eddie_1
eddie_1's Avatar
For chrome there is a plugin fix.
https://chrome.google.com/webstore/d...giikdkpmcpkaon
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old December 14th, 2017, 21:01   #288
keaton
keaton's Avatar
TDI(s): 2005 Mk5
Originally Posted by eddie_1 View Post
no FF?
Old December 15th, 2017, 19:49   #289
Exenos
TDI(s): 02 Golf
Theres one for Firefox as well. A quick Google will find it.
EDIT: https://addons.mozilla.org/en-US/fir...t-fix/?src=api
Exenos is offline   Reply With Quote
Old December 21st, 2017, 10:36   #290
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
I did a few runs today ..just like yesterday and the day before that.
I think we are at a good point with almost stable rail pressure till 5k, 2.6-2.7 boost and some decent IQ.
Car seems fast and traction is an issue
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 13th, 2018, 01:00   #291
Macradiators.com
This is where i am now, 290-300hp probably
. Car runs ok but due to egt limiter 930deg power is cut 2 times, you can here it in video, for 1-1.5 seconds i can feel the car not accelerating.
Waiting for new turbo to push it further. I think its time for a day on dyno to test some stuff and close this project with some big numbers.
After this is done, it's time for a 3.0 450hp project.
https://www.youtube.com/watch?v=A-l3TXZZTlA
CP3 Upgrade
Old January 13th, 2018, 07:14   #292
Turbo Z
what turbo do you abuse to 930 degrees Celsius!?
Turbo Z is offline   Reply With Quote
Old January 13th, 2018, 07:40   #293
Macradiators.com
Gtb2265vk with bmw 4650mm tw This is as far as i want to go with this one. Waiting for new unit from Finturbo to go further.
CP3 Upgrade
Old January 13th, 2018, 12:06   #294
xjay1337
Very hot. But it's ok for short periods eg 1/4ml and sensible street use. Not for track or you will have a bad time hah
My egt limiter is 880c . After this fuel is cut smoothly.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old January 26th, 2018, 23:56   #295
Macradiators.com
880 deg for 340hp at 4700rpm sounds a little hard to believe with a turbo smaller than mine
For now i stopped testing. There is no point going further with this one.
CP3 Upgrade
Old January 27th, 2018, 04:18   #296
Rub87
Almost sounds like the time u where measuring spring pocket depth lol
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 27th, 2018, 04:46   #297
Macradiators.com
I measured them right, didn't i?
Still have to see one cyl head with equal pockets. Not saying there isn't one, but people i know measured have it identical to the 3 heads i have here.
Anyway if something good happens i'll post it here.
CP3 Upgrade
Old January 27th, 2018, 18:44   #298
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
the pockets are in fact uneven. Mac measured correctly. Tried six different heads....
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old January 28th, 2018, 06:59   #299
Rub87
I dont say he measured incorrect. I say some head have even pockets..
Old January 28th, 2018, 08:59   #300
xjay1337
Must be an incorrect dyno
Different kind of CR turbo build ibexlatham TDI Power Enhancements 66 September 26th, 2018 17:51
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 22:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 14:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 06:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 10:56
Page generated in 0.18308 seconds with 10 queries
[Output: 134.63 Kb. compressed to 112.57 Kb. by saving 22.05 Kb. (16.38%)]
