Old September 27th, 2016, 00:15   #16
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
you all forget we are talking about 2.0 CR engine, 303hp is the best result so far until proven otherwise, and nobody came even close to this result
trying to push 320 and 2260vk is more than enough for that, do you all agree?
so in reality i dont need a better turbo, right?
i dont know if my fuel setup will be enough, and i'm talking about injectors here
i am replacing the original with something else
Macradiators.com is offline   Reply With Quote
Old September 27th, 2016, 02:39   #17
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
They are also talking about 2l CR
This 303hp you talk about - do you have any more details? EGT's, smoke any proven 1/4 times?
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old September 27th, 2016, 09:51   #18
Macradiators.com
you have different dyno launches on the other topic, you can see power increase on the same dyno in different setups, and the results are well in line with other tuners from Italy and NL
last setup is 297hp but better torque curve
the car is a DD passat SW not a race car, very low smoke, dont know iq and egt, cant monitor them in torque
Old September 27th, 2016, 13:02   #19
Rub87
Tbh the cars which I know run 2.4 bar and pambda 1.1 at 4k rpm and theyre not doing anywhere near 300 hp. maybe the air is thinner over here lol..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old September 28th, 2016, 00:36   #20
Macradiators.com
what do you want me to say? maybe its down to how competent the tuner is
Eric was working for months on that car, i cant imagine anybody spending so much time on a particular model.
remember the more fuel flowing 2.0pd is good for 360-380hp , there are so many in italy putting out 380hp without wmi
want me to post dyno as well for you to be convinced?
just because you haven't got there "yet" doesnt mean its impossible.
when i tune mine i will also do a run with current setup revo2 and of course final run mapped
to have an idea of the accuracy of the dyno , 2 runs on stock map and tuned one for stock 180KW bmw engine
Old September 28th, 2016, 01:26   #21
Rub87
just FYI. I tuned these cars and no matter what skill, or lack there-of, the tuner has. the engine only flows y amount of air for x amount of boost (considering equal size turbo/emp). no tuner can change that without hardware changes
Old September 28th, 2016, 02:49   #22
Bobby Singh
Goes to show the CR head is not flowing so well actual worse than BKD it seems.
With 2.3 bar i got 1.1 lambda with just under 900deg - on track egt's are approx 930.
IIRC you said these cars with 300hp are running stock rail pressure, would be interesting to know egt's.
BSR
Old September 28th, 2016, 04:19   #23
xjay1337
I agree :-)
Airflow is crap.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old September 28th, 2016, 08:02   #24
Macradiators.com
4 independent tuners from Europe got from 278 to 285 hp with stock pump and injectors
reaching the limit of stock pump
Old September 28th, 2016, 08:08   #25
Rub87
good for them :0)
Old September 28th, 2016, 11:15   #26
Macradiators.com
incredible what you find if you search for it, he even has the DATA to back it up
Originally Posted by MarkoP View Post
Not sure where above information is from, but I have flow tested 2.0CR, which out flows 8v with good margin and flows also better than stock BKD.
TDIsyncro has the flow data of stock CR170 injectors , more than enough for 300hp, told you so!
Old September 28th, 2016, 11:29   #27
Rub87
hmm maybe the cars I tuned with 2260vk of which 1 with CP3 must have had a bad head casting then? putting a head on a flow bench alone also doesn't mean much. there still needs to be a camshaft to open the valves.
What counts is: you have x boost and y airflow. this airflow is hard to understand wrongly because as soon as you hit lambda (measured) of 1.1 you are 'out of air'. its also no rocket science to calculate power even without going on a dyno if you have extrapolated the duration map properly and have a certain amount of logical understanding of specific fuel consumption/brake efficiency at certain engine conditions.
A (healthy) CP4 in all these cars definitely does not flow anywhere above 270hp. this is with no current on the metering unit and stock case pressure regulator at 4k rpm.
in your case it seems hard to understand that for a tuning company posting a dynosheet with pretty numbers is the best and cheapest way of marketing
Old September 28th, 2016, 12:25   #28
mk1-83
Fuel Economy: 1:15
Ruben +1
Yes it's x amount of airflow lb/m that the head can flow at y pr.
With a 2260vk.
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old September 28th, 2016, 12:57   #29
Bobby Singh
100mg = time for pump
BSR
Old September 28th, 2016, 13:27   #30
xjay1337
Go to Italy you can run 108mg on stock pump at 1750bar ..... must be oem cp3 on european cars. :-)
Different kind of CR turbo build ibexlatham TDI Power Enhancements 66 September 26th, 2018 17:51
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 22:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 14:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 06:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 10:56
Page generated in 0.32426 seconds with 10 queries
[Output: 131.97 Kb. compressed to 110.17 Kb. by saving 21.80 Kb. (16.52%)]
