Old September 24th, 2016, 01:22   #1
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Default 2.0 CR big turbo build, aiming to set WR
Hi guys!
this is my 2010 leon fr 2.0cr big turbo setup
audi 2260vk turbo with new actuator
profi diesel tubular mainfold setup for GTB turbo
big FMIC, own production 700 x280 x 70mm
new cylinder head + 1.63mm gasket, new bolts to be mounted next week i hope
injectors ..gonna keep this to myself for now, dont know if gonna succeed and improve
CP3 pump to be mounted, mounting kit made in house
I am trying to keep rotating mass as light as possible so i put:
BBK with Cayenne Z18 calipers powder coated on light weight 340mm TTS discs, hawk performance pads
Oz Superleggera 18 wheels
A few photos:
Macradiators.com is offline   Reply With Quote
Old September 24th, 2016, 01:41   #2
diffas
diffas's Avatar
What kind of big turbo you are aiming to use? Leaving 2260 as hp turbo or what?
diffas is online now   Reply With Quote
Old September 24th, 2016, 05:06   #3
Macradiators.com
GTB2260VK is already on the car in the photos, it is more than enough for my goals since the greatest limit are the injectors
a pretty similar setup will be tuned in NL by a good tuner (JD ENG) next week we hope, hoping to break the 300hp barrier as well
Havent decided which way to go with the DSG gearbox, i will get a good remap and probably mount a cooler
Old September 24th, 2016, 05:40   #4
turbobrick240
turbobrick240's Avatar
Looks good! Those are some massive calipers. Maybe a bit overkill, but they should stop the car quickly.
Old September 24th, 2016, 11:50   #5
Macradiators.com
cayenne calipers are much lighter than original ones, big yes, and brakes are now as they should be on a fast car, love them!
Anybody has the COOLING DIAGRAM for my or similar engine? (CEGA-CEG)
I removed the EGR cooler, eliminated the electrical pump and closed the water pipes that went to egr cooler in the back of the engine.
Old September 24th, 2016, 12:36   #6
mk1-83
Fuel Economy: 1:15
Jd engendering jeroen dik do mostly gas cars
You're better of at Vvt , van vught tunning he is Meber turbo Johan
He do a lot of Vag diesels and bmw
I'm living at 25 km away from Vvt so if you're there let me know
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old September 24th, 2016, 13:35   #7
Macradiators.com
I saw VVT has some great results, but client car is already in JD , its not my car.
I will go to bucharest for mapping mine.
Old September 24th, 2016, 13:40   #8
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
One can never have brakes too big. Mine are 8 piston front 4 piston rear. Nice work on the exhaust. I like it!
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is online now   Reply With Quote
Old September 25th, 2016, 07:07   #9
Devilz
Fuel Economy: 38.6 UK MPG
Good job Mac, looking forward to end of project.
Devilz is offline   Reply With Quote
Old September 25th, 2016, 10:44   #10
Macradiators.com
today i deleted the EGR cooler the good but difficult way, removed all the metal pipes going to the EGR , i had to make connection between coolant pump and the 2 main hoses coming from the radiator without going behind the engine
Old September 26th, 2016, 00:41   #11
Rub87
WR with 2260vk- lol
let's say ur're at least 1 turbo behind
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old September 26th, 2016, 08:48   #12
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
Wromanian Record maybe Ruben!
What is the best way to go to get fuel enough for 350hp Rub?
Nice build BTW, like the break setup!
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Old September 26th, 2016, 08:54   #13
Rub87
Dont run silly low lambda and enough railp
Old September 26th, 2016, 10:23   #14
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
Yeah ofcourse, but with what hardware?
Old September 26th, 2016, 11:39   #15
mk1-83
Fuel Economy: 1:15
He needs to go compound turbo setup to set a WR ��
Lupo 1.9 tdi
300+ HP 500 nm
Different kind of CR turbo build ibexlatham TDI Power Enhancements 41 March 18th, 2018 19:39
Not your average big turbo build tooslowtdi TDI Power Enhancements 15 June 28th, 2015 21:33
Golf GTD MK6 big turbo build turbo johan TDI Power Enhancements 40 May 17th, 2015 13:25
CR140 Big Turbo Build storx TDI Power Enhancements 866 August 22nd, 2014 05:57
CR Big Turbo Kit? Tuning? storx TDI Power Enhancements 91 March 16th, 2012 09:56
Page generated in 0.19920 seconds with 10 queries
[Output: 130.13 Kb. compressed to 108.59 Kb. by saving 21.53 Kb. (16.55%)]
