Old November 23rd, 2016, 05:35   #31
Diesl
Originally Posted by zaphod99 View Post
I'm experiencing odd behaviour after adding the "soot" gauge to Torque.
The gauge seems to work ok (reading 70g), then after < 1min, Torque disconnects from my Bluetooth OBD2 adapter (cheapo aliexpress ELM327 clone) and will not re-connect until I power cycle the OBD2 adapter. If I remove the "soot" gauge all is back to normal, and no more disconnects. Weird.
Any idea what might be causing this?
I think I have a different OBD2 adapter laying around, which I will try and see if it behaves the same way. My phone is a Nexus 4, if that makes any difference.
Any news on the results with the other adapter? 70g soot seems an implausible value: regeneration should start at about 17g. If I remember correctly, 40g is the upper limit beyond which regeneration on the road is disabled, and 45g is the absolute limit, beyond which even a VW shop can't recover the DPF. I'm not saying that 70g can't occur as a reading, after all the car calculates this number, it is not a direct measurement, but it seems out of the normal range.
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old November 24th, 2016, 06:37   #32
zaphod99
I finally got around to trying my other adapter this morning, and no disconnect issue with this one. However, my readings are erratic and out of the range you described.
At startup, the reading was 63g and fluctuated (up and down) by a few g, and once went wildly up to 166g before coming back down to the 60's. At about 10km into my 50km commute I noticed a regen in progress. At this point the reading was 86g, which held constant during the regen and for most of the remainder of the drive. Near the end of the drive, the reading finally moved off of 86g down to the high 40's to low 50's, with one wild swing to 187g. I'm not sure what to make of these readings.
zaphod99 is offline   Reply With Quote
Old November 24th, 2016, 15:02   #33
Diesl
Happy Thanksgiving! It might be a good idea to double check the formula:
((R49<8)+R50)/100 . A missing or misplaced parenthesis could really screw things up.
R49*2.56 + R50/100 should also work.
Except for the numbers, the behavior you describe sounds similar to what I see:
Constant readout during a regeneration and for a while (50 miles for me) afterwards, then a jump to a lower number (usually 6 to 8 gram for me - haven't checked it that often) and slow increase from there.
The erratic jumps also point in the direction of a wrong math formula, or that your car's computer has gone bonkers. Maybe VW tried a special improved cheating firmware in yours...
Old November 28th, 2016, 08:27   #34
zaphod99
I verified that I had the correct formula. I also tried the alternate formula "R49*2.56 + R50/100" and the result is the same.
Back in post #25 @bud_128 reported readings as high as 200g, so I'm not alone. Maybe both our ECUs have gone bonkers
Old November 28th, 2016, 22:55   #35
Diesl
Mhmm. Maybe that means my formula only works for certain TDIs. Yours is a 2013 Passat, and bud_128 drives a 2014 something. Maybe also a Passat? A 2014 Jetta or Golf should have exactly the same engine as my 2012 wagon (which is really more a Golf than a Jetta, despite what the nameplate says). Bummer.
If you wanted, you could check what Torque lists by itself for Mode 6 ('Test Results') data. Maybe in your car the soot is a few bytes over?
Old November 30th, 2016, 07:32   #36
zaphod99
Absolutely right. I watched PID 06b2 in "test" mode, and although the sequence '7E82736' was not there, it was evident that the 2 bytes of interest were the last byte on line "5:" and the first byte on line "6:". I adjusted my formula to '((R40<8)+R41)/100' and now I'm seeing reasonable values in the 7-18g range. FYI my pre-regen reading topped out at x'0706'.
Old April 18th, 2017, 22:41   #37
Diesl
Update: I had the opportunity to test my torque setup on a 2015 golf wagon TDI, and everything seems to work, incl. EGTs, manifold pressure (requested and actual ), fuel pressure, DPF soot load etc.. In fact, the soot load was 24 gram, as the car had only ever been driven very short distances, and I saw it start a regeneration.
Old August 11th, 2017, 12:21   #38
krambriw
Smile dpf's and more
Hello, just found this great place!
In our family we have 3 tdi's. One of them, the old Golf needed the dpf to be cleaned. I went to a garage where they had a pretty new equipment for this purpose. It took around 3 hours and I was astonished afterwards; the engine was running much smoother, more quiet, no more diesel smell that I could feel earlier, really big difference. The thing was this car had 260.000 km's, mostly on highways, so there was a lot of ash in the dpf. Luckily, we did not have to replace it, the cleaning was enough.
Anyway, this raised my awareness a bit, I decided to look for some tool that could be used to read the soot level. Ended up with an ELM327 and Torque. Besides that I have also tried with VAG DPF.
The communication with the ecu is working fine with all 3 cars but the reading in Torque makes me uncertain. Our A6 shows a soot level around 13-14 when using VAG DPF. Using Torque with the formulas mentioned in this thread gives readings 50 to 70. So I assume the formula is not perfect for the A6 2.0 tdi from 2013.
Is there anybody who could explain what the response in the picture really means? Is the soot level in there somewhere?
Kind regards, Walter
krambriw is offline   Reply With Quote
Old August 12th, 2017, 11:54   #39
Diesl
Hi Walter, would you mind resizing your giant picture so one can still read the text on this page?
The response in the screen shot seems short. If you look at my first post in https://torque-bhp.com/forums/?wpfor...topic&t=7739.0 (the torque forum companion thread), the response I'm getting has quite a few more bytes.
Did you post the complete response to the 'test command', or did it get chopped off?
What are you seeing under 'test results in torque for B2C5?
Old August 13th, 2017, 02:30   #40
krambriw
Hi,
Yes, that is the complete response, the same length from both Audi's. Also there is no data received for command B2C5, same for both cars
If the elm327 adapter seems to be working ok, aslo included a screenshot from VAG DPF below (from the A3)
Best regards, Walter
B2C5 from both
From Audi A6
From Audi A3
VAG DPF from Audi A3
Old August 13th, 2017, 07:28   #41
Diesl
Torque also has a selection in the main menu for 'test results'. It takes a while to fully populate, but that is where I initially found the B2C5 field with a value in gram. What do your cars show there?
Old August 13th, 2017, 08:26   #42
krambriw
I did a test with the A6, waited like ten minutes, this was all that was shown, maybe it doesn't work with my cars ecu's
Old August 13th, 2017, 16:27   #43
Diesl
That's odd. 3 variables is all the A6 provides as mode 6 data?
Is there an A6 subforum here? Maybe they know more. It could be your elm-clone that is acting funny. Does everything else work (built-in torque functions)?
Old August 14th, 2017, 08:56   #44
krambriw
The elm seems to be working ok, a raw display is populating a lot of values, but it might be that something int the elm compatibility is missing anyway (it's reported as ver 1.5). Same result for both the A3 and the A6. It can read fault codes. It's the "test result" that won't play
Anyway, I think I will be satisfied with the VAG DPF since that is working, it was my main interest to be able to check the dpf
Thanks for all suggestions,
Old February 15th, 2018, 15:02   #45
Diesl
Default Soot reading bytes moved after emissions fix
Update 2018-2-15: after getting the emissions fix for my 2012 JSW TDI, the R49/R50 formula showed the same behavior that Mr.Beeblebrox above saw for his Passat, so I tried out his R40/R41 shift, and it works.
Last edited by Diesl; February 16th, 2018 at 08:37. Reason: Confirmed that new formula works
Water Level Sensor False Reading vwfern VW MKIV-A4 TDIs (VE and PD) 6 November 24th, 2013 22:10
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 13:44
Messing with the Air Flow Meter Reading for tuning and to help combat soot? Possible? pietch TDI Power Enhancements 2 September 14th, 2008 04:57
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 06:26
SOOT LOADING LEVEL IN TDI OIL SkyPup Fuels & Lubricants 27 November 24th, 1999 12:19
Page generated in 0.21171 seconds with 10 queries
[Output: 137.86 Kb. compressed to 116.09 Kb. by saving 21.77 Kb. (15.79%)]
