Old July 31st, 2016, 08:11   #16
hotpocketdeath
hotpocketdeath's Avatar
Originally Posted by Diesl View Post
In the mean time, testing a PID accessing 06B2 will give you an updating soot load display, but it is kind of inconvenient to get to (back out of real time - settings - settings - manage extra PIDs - select PID - edit - scroll down to 'test').
There's an easier way.
In the Realtime display, you can add a "Push Button" (in display menu) and set it to "send OBD command". Just click it and put in the PID and it will send back the info you want.
hotpocketdeath is offline   Reply With Quote
Old July 31st, 2016, 17:05   #17
Diesl
I tried that, but nothing came back.
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old August 19th, 2016, 12:07   #18
Diesl
Default Soot level is in Torque beta now
I am happy to report that reading of the (estimated) soot level is working in Ian's latest beta version of Torque!
Old August 19th, 2016, 16:03   #19
hotpocketdeath
Excellent
What kind of changes are there to allow you to pull the data? I have a feeling that there's more than just pulling byte "B" or byte "C".
Old August 20th, 2016, 10:18   #20
Diesl
Ian (the Torque author) changed something internally in Torque to allow access to the mode 6 data from the equation handler. For now this only works in the beta version. There's probably more work to be done before it can make it into the production version of Torque; for example, a floating widget can not yet display these data.
Old August 31st, 2016, 09:52   #21
unixb0y
I was looking at version 1.8.106 release notes and saw:
* Mode 6 replies can now be read by user PID
Is that what is needed?
unixb0y is offline   Reply With Quote
Old September 1st, 2016, 14:28   #22
Diesl
Yes .
Old October 31st, 2016, 06:54   #23
zaphod99
Is this working now with the latest (I have 1.8.140b) Torque?
If so, what is the PID formula?
zaphod99 is offline   Reply With Quote
Old October 31st, 2016, 18:30   #24
Diesl
Default Soot formula
Oops, sorry, I never posted that.
The formula is ((R49<8)+R50)/100 . The PID is 06b2, the unit is g, and for max and min 100.0 and 0.0 will work.
Old November 1st, 2016, 10:11   #25
bud_128
Fuel Economy: ~45mpg (imperial gallons)
So Am I right in assuming that this needs to be read with the key on and engine off to be close to accurate? I know running down the road I got it to read as high as 200g
bud_128 is offline   Reply With Quote
Old November 1st, 2016, 20:03   #26
Diesl
Nope. It's stuck for about 50 miles after the end of a DPF regeneration at the value before the regen, but you can read it whenever you want. Sometimes the computed soot load moves a bit down, otherwise it seems to be a pretty stable estimate, increasing (for me) about 0.1 g / mile.
Old November 2nd, 2016, 05:06   #27
hotpocketdeath
I totally flaked out and forgot all about this.
You wouldn't mind if I added that to my CSV would you?
Old November 2nd, 2016, 07:00   #28
Diesl
Default Good idea
Of course not - you should probably also post your current link.
Old November 2nd, 2016, 15:38   #29
hotpocketdeath
Thanks.
https://www.dropbox.com/s/vt48ogul9lgs650/VW.csv?dl=0
Good to see that Dropbox hasn't messed with the link for a while now. I'll try it out, but I think the max value might be a little high.
Old November 3rd, 2016, 07:47   #30
zaphod99
Unhappy OBD2 adapter disconnects from Torque
I'm experiencing odd behaviour after adding the "soot" gauge to Torque.
The gauge seems to work ok (reading 70g), then after < 1min, Torque disconnects from my Bluetooth OBD2 adapter (cheapo aliexpress ELM327 clone) and will not re-connect until I power cycle the OBD2 adapter. If I remove the "soot" gauge all is back to normal, and no more disconnects. Weird.
Any idea what might be causing this?
I think I have a different OBD2 adapter laying around, which I will try and see if it behaves the same way. My phone is a Nexus 4, if that makes any difference.
Water Level Sensor False Reading vwfern VW MKIV-A4 TDIs (VE and PD) 6 November 24th, 2013 21:10
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 12:44
Messing with the Air Flow Meter Reading for tuning and to help combat soot? Possible? pietch TDI Power Enhancements 2 September 14th, 2008 03:57
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 05:26
SOOT LOADING LEVEL IN TDI OIL SkyPup Fuels & Lubricants 27 November 24th, 1999 11:19
Page generated in 0.19313 seconds with 10 queries
[Output: 130.54 Kb. compressed to 109.52 Kb. by saving 21.02 Kb. (16.10%)]
