Old July 16th, 2016, 14:21   #1
Diesl
Default Reading soot level with Torque
I asked about it in 2013 (http://forums.tdiclub.com/showthread.php?t=379398), but I'm not sure an answer has ever been posted:
The mode $06 'Test Results' accessible from the Torque app include MID $b2 $c5, which runs from 0 to 50 gram. At or slightly beyond 16.75 gram it triggers a DPF regeneration. I'm now pretty sure this is the computed soot level in the DPF.
If it works, take it apart and find out why!
Diesl is offline   Reply With Quote
Old July 16th, 2016, 20:43   #2
Ol'Rattler
Ol'Rattler's Avatar
IDK, but since anything emission related should be readable with a generic scanner, you are probably on to something.
If you said that you were trying to pull airbag codes or ABS codes say, I would say ah, no way with a generic OBD2 scanner.
If I had a DPF car, I would compare soot levels reported in Torque with soot levels reported in VCDS since I have both and report back.........
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old July 16th, 2016, 21:03   #3
JSWTDI09
JSWTDI09's Avatar
That sounds about right to me. I monitor calculated soot load with a Polar FIS and 16.8g is almost always the trigger that begins an active DPF regeneration. It looks like you found it.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old July 19th, 2016, 12:23   #4
hotpocketdeath
hotpocketdeath's Avatar
Hmm, I'll have to check this out and possibly add it to my PID List
hotpocketdeath is offline   Reply With Quote
Old July 20th, 2016, 04:09   #5
740GLE
Just got Torque Pro that came with the cheap amazon dongle, I'm running it on a kindle 7. I sideloaded the app and am new to adding PIDs, is there anywhere that provides a good tutorial? Or just a list of worthwhile PIDs? Just looking for Boost, EGTs pre and post DPF, and will prob add this soot PID.
Also are the cheaper dongles limited in what PIDs you can read? I grabbed that CSV file hotpocket posted a while back and I'll give it a whirl tonight.
Old July 20th, 2016, 08:02   #6
JSWTDI09
JSWTDI09's Avatar
Generally the more expensive ones main "claim to fame" is their speed. This will effect how quickly readings can be updated. I do not use TorquePro but i did play with it a while ago. IIRC, there is a setup option for high speed. This option may or may not work with the cheaper ones.
The ODBII standards define the PIDs. Any OBDII reader should be able to read any OBDII PID.
Have Fun!
Don
Old July 21st, 2016, 05:35   #7
740GLE
I used hotpockes old CSV file and boom it works!
If I were to add this new PID, how would the format be different that say the DPF delta code?
VW DPF Delta | DPF Delta | 017A| ((B*256)+C)/100 |0 |10| kPa |Auto
Old July 21st, 2016, 07:49   #8
hotpocketdeath
Well, that's the part I would need to figure out. I need to see if using a custom PID will return values, then figure out what those values are and how they are being returned, then figure out the equation.
I havn't had a chance to start on this for reasons, but I'll try and get to it soon. If you figure out anything, please let me know.
And for starters, the 017A is the OBD2 Mode (01) and the PID (7A). So if we are wanting to look at the diagnostic mode, we would use mode 06 and then probably B2 for the PID. Since I haven't started working on it, this is just a guess for the time being.
Old July 21st, 2016, 08:58   #9
740GLE
Ill try updating my CSV file, I'm guessing gr (gram) for unit?
What about the equation for the 4th column, looks like a lot of the others use 256 and variables, not really sure, but I'll take a guess.
VW Soot |Soot |06b2 |B-40| 0 | 25 |gr | auto
Old July 21st, 2016, 09:35   #10
hotpocketdeath
I doubt that formula would work. You usually only see -40 when dealing with Temperatures.
Old July 22nd, 2016, 04:19   #11
740GLE
I tired creating a custom PID using that feature in torque to no avail
I used 06b2 as the Mode and PID, with a scale factor of 1X, scale 1-25, it did register as a "Test Result" in torque but nothing ever registered, just a "-".
Old July 26th, 2016, 19:30   #12
Diesl
Default Update on 06B2 data
The answer to mode 6 queries doesn't seem to be recognized as valid data by Torque. I sent a debug log in, and hopefully Ian is looking into this. See https://torque-bhp.com/forums/?wpfor...topic&t=7739.0 .
That being said, if you define a PID (any PID) using 06B2, testing it should give you an updating display that contains the soot load info in the eighth line, in the two bytes (four hex digits) after '7E82736'.
I just watched it across a regeneration: it topped out at '0699' hex, and then stayed at that value until about 70 miles after the start of that DPF regeneration, when some bytes in the 06b2 data block finally started moving again, and the soot value jumped to about 7 gram (03xx hex).
Old July 27th, 2016, 07:33   #13
hotpocketdeath
Good find. I suspected as much.
I was messing with it over the weekend and I received similar results. Hadn't gotten around to actually posting about it on their forums yet. At least it's good to know we can get access to the data in 06B2, just need to figure out how to convert it into something usable.
Using your data 0699, I'm converting it to 16.35, which looks promising. "((06*256)+99)*.01"
Old July 28th, 2016, 17:41   #14
Diesl
On the next regen the 06B2C5 value topped out at 68B=16.75 gram and then started moving again 55 miles after the start of that regeneration, at 2CC = 7.16 gram. DPF pressure drop at idle at that point was already back up to 7 mbar, a few miles (not immediately) after a regen ends it goes as low as 4 mbar. Somewhere between 10 and 14 mbar idle DPF pressure drop a regen would typically start. I'm hoping the 06B2C5 info will be a more precise indicator of how close the next DPF burnoff is.
Old July 30th, 2016, 23:10   #15
Diesl
No news yet from Ian. In another thread on the Torque forum he sounded like a new version would be happening pretty soon (on a week's time scale), but I'm not sure whether equation access to mode 6 data will be in it.
In the mean time, testing a PID accessing 06B2 will give you an updating soot load display, but it is kind of inconvenient to get to (back out of real time - settings - settings - manage extra PIDs - select PID - edit - scroll down to 'test').
Water Level Sensor False Reading vwfern VW MKIV-A4 TDIs (VE and PD) 6 November 24th, 2013 21:10
Can Vag-Com adjust fuel level reading? shizzler OBD Scanners 3 August 4th, 2010 12:44
Messing with the Air Flow Meter Reading for tuning and to help combat soot? Possible? pietch TDI Power Enhancements 2 September 14th, 2008 03:57
Fuel Gauge isnt reading correct level cfm56 VW MKIV-A4 TDIs (VE and PD) 6 June 20th, 2007 05:26
SOOT LOADING LEVEL IN TDI OIL SkyPup Fuels & Lubricants 27 November 24th, 1999 11:19
Page generated in 0.17784 seconds with 10 queries
[Output: 134.87 Kb. compressed to 112.81 Kb. by saving 22.06 Kb. (16.36%)]
