Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old July 9th, 2016, 11:01   #1
robnitro
Default FS: 2001 VW Jetta TDI ALH w many parts BROOKLYN, NY area
SOLD!!!
Figure 2250 is the lowest I will go, otherwise I may do an engine swap w head trade with a local guy here and sell it as working or just part it out for more money and donate the rest for a tax break.
Here's a simple conservative breakdown based on prices of parts ALONE, if I parted it, so you see the body work doesn't lower the value:
-11mm pump 400
-Titan 764 (.234) Nozzles -100
-Injector Bodies - 200
-Head Ported by whitbread and Colt STG2, with new valves guides/lifters around 30k ago - easily 500
-PD150 intake and egr/asv- 150
-VNT17 - 250
-ECU 012CP tuned for vnt17/.764 plus many goodies we learned - 300
-Manual transmission 02j with smf g60 flywheel and vr6 clutch (trans has about 120k, clutch has 50k approx)- 500
-Engine, not counting it, that has the ring issue but many useable parts
-Aluminum evo skidplate- 150
-Koni reds with the lift kit - (new is 500 for konis and they have lifetime warranty) - 250
-ASR/ Traction control retrofit - 50
-Larger than stock auto fuel cooler (manual doesn't have one) and the carter lift pump - 50
-FMIC custom built by me, no cutting of crash bar- 150
-Ecodes with relay wiring - 100?
-Tons of extra parts, 6 oil filters, 2 air filters, extra maf- 100+?
So just part prices alone it's around 3050, and I may recall more things, so please don't lowball me and be serious. You can't say the body drops the price down when parting it and donating the shell I can get more! Donating, I can't sell the konis but that's fine.
I also am including many extras like 2 air filters, 6 oil filters, 4 new bosch gp's, 4 slightly used gp's and assorted extras that were barely used but changed for preventative maintenance
It comes with many performance parts:
-koni reds , 1.5" in lift kit, wagon springs which are a bit stiffer than stock jetta
-new windshield, replaced in April
-aluminum skidplate
-whitbread ported head with Colt Stage 2 cam
-VNT 17
-PD150 intake and PD150 egr (but I dont use the egr, I use the asv valve though)
-11mm pump
-764 nozzles
-Custom tuning with some very cool mods (see my post history) I can include the MPPS programming cable and software to edit/flash the tunes if you want to learn. I also have a vag com cable that works well with the older vagcom 3xx and vcds 1.x programs to do most troubleshooting
-FMIC with 2.25" pipes, 3 bar map, didn't have to cut the bumper crash bar
-VR6/g60 smf flywheel (no slip- especially when I retuned it to remove spikes and have smoother, cleaner power)
-carter lift pump which helps the IP prime and keep timing
-large fuel cooler with a special limited return setup to match the carter max flow
-2.5 inch exhaust past the downpipe flex pipe. 2.5 inch cat and 2.5 inch fake muffler (an older magnaflow cat gutted)
-Tow hitch with insert. Not stealth but very hard to see.
-I also have 2 sets of super light avus rims (almost bald tires) 6 of them are clean others curbed, good for snows I can include them for cheap! I also have a set of steelies, same thing- cheap to include if you prefer those
It's an either/or post... parts or the whole car. Not sure what I am going to do, but instead of procrastinating, I figure someone might have a project in mind, etc.
2001 ALH TDI with 190k, ring # 2 bad- causing excessive blowby.
Not sure if someone wants the whole car- but here's the post with the parts in the car and extras.
http://forums.tdiclub.com/showthread.php?p=5102295
More pictures below posts http://forums.tdiclub.com/showpost.p...20&postcount=9
http://forums.tdiclub.com/showpost.p...0&postcount=10
http://forums.tdiclub.com/showpost.p...0&postcount=11
robnitro is offline   Reply With Quote
Old July 9th, 2016, 11:22   #2
94cobra2615
TDI(s): 99 jetta tdi
I need engine wiring harness, ecu, guage cluster, and key fob
2003 blue wagon
94cobra2615 is offline   Reply With Quote
Old July 9th, 2016, 11:26   #3
robnitro
I don't think my ecu will work with your car and I don't have the time for all the work to remove those parts right now, sorry.
Old July 9th, 2016, 11:38   #4
94cobra2615
it's for a 2003. I see it is a tuned ecu. I just need an ecu for a factory engine. Thanks.
2003 blue wagon
Old July 11th, 2016, 19:01   #5
robnitro
Sorry, been busy. It's depressing because I loved the car and I moved on. You know that feeling of attachment?
I'm still not sure what I want to do with her. For now I'm thinking its best to sell it together because I don't have the time to take parts off, or I may do the rings. I'm not good for a clear decision now.
Old July 11th, 2016, 19:01   #6
robnitro
2003 is another ecu. I forget the model. Check car-part.com they usually have the part numbers.
Old July 27th, 2016, 15:29   #7
robnitro
updated with a price and possible plans
Old July 29th, 2016, 13:11   #8
hankymurphy
hankymurphy's Avatar
Fuel Economy: not 50mpg anymore
PM'ed
'14 A6 TDI - stock/"fixed"
'02 Jetta: Ported head, stage 2 cam, 11mmIP, VNT 17
'01 Golf: 287k+ miles, Stage 4 . 900 mile club - SOLD
hankymurphy is offline   Reply With Quote
Old August 1st, 2016, 12:56   #9
robnitro
Old August 1st, 2016, 12:56   #10
robnitro
Old August 1st, 2016, 12:56   #11
robnitro
Old August 1st, 2016, 18:51   #12
robnitro
Pending sale...
FS: 2001 ALH GOLF & 2998 Jetta ALU JETTA (Runs+Parts) Located: Rochester NY mazrik Private TDI Items for Sale/Wanted 10 December 22nd, 2015 16:02
FS: 2001 Jetta ALH Part out or Parts Car: Boston Bcohen Private TDI Items for Sale/Wanted 16 November 30th, 2015 05:35
FS:2001 ALH TDI engine parts storehouseassets Private TDI Items for Sale/Wanted 0 December 3rd, 2011 22:46
FS: 2001 Jetta TDI Parts jetta'd Ontario 7 October 31st, 2011 17:25
2001 VW Jetta TDI MK4 5spd parts car 0Silva1 Private TDI Items for Sale/Wanted 20 July 19th, 2008 20:33
Page generated in 0.15145 seconds with 10 queries
[Output: 116.20 Kb. compressed to 98.86 Kb. by saving 17.34 Kb. (14.92%)]
