Old November 23rd, 2017, 21:23   #61
altz1
TDI(s): Allroad, A8
I had 940 on mine also while under load high rpm, but yes i dont think it very good in long term. Didnt happen anything in 25000km tough and new owner now drives even harder. What is your EOI @5krpm?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old November 23rd, 2017, 23:00   #62
eddie_1
eddie_1's Avatar
I have 30 deg. advance SOI and just under 1ms duration full throttle.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old March 2nd, 2018, 13:43   #63
eddie_1
eddie_1's Avatar
Went for a more or less final Insoric Power Measurement today after bumping up fuel to max ~90mg/str and 2.1bar boost. Weight about 2007Kg with 2 people in the car.
With good cold dry weather today hit 343.4HP and 622.7NM. The power was probably a bit more wider to 5000rpm but I did not take it all the way to the rev limiter.
The clutch is sort of at the limit, especially with the cold weather. But car is running great. I will upgrade the clutch.
I also did a 100-200kmh measurement with VCDS and got another second less going to 90mg/str from 86mg/str. You really feel a difference between 86mg/str and 90mg/str. 90mg/str really feels solid. If you consider 13.xx secs for 100-200kmh and losing almost 1 sec shifting from 4th to 5th and the car being almost 2 tons. Then upper 12s is not bad.
I upgraded the boost gauge to Raid HP digital and to 3 bar since I am maxing out at 2.2bar. Much, much better to have digital gauges.
GTB2260VK what a turbo!!!
Old March 3rd, 2018, 06:17   #64
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
How accurate is this method of measuring compared to well calibrated non optimistic dyno?
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old March 3rd, 2018, 06:57   #65
eddie_1
eddie_1's Avatar
Talking
I am not an expert on Dynos and with all the endless dyno fudge factor discussions I am very glad there is a straight forward, transparent and uniform method that can be used anywhere and the evaluation is done in real world on the road measurement. Potentially you could end dyno discussions. Of course you can cheat with this device also, but there is no unintentional error. Essentially you need a reasonable flat road section (can drive both ways to check accuracy and use for correction), accurate weight of the vehicle. I checked 100Kg off gives 20HP error. Basically you floor it to rev limiter and let it roll. The sensor on the wheel very very very accurately at a high rate of sampling captures the vehicle speed vs time using an accurate measurement of the tire diameter. When we checked the log, it even showed up the speedo error at low speeds - rpm vs speed. After acceleration the roll down calculates the losses including wind resistance etc. The rest is in the physics formulas. It is a simple but great idea that a Prof in Switzerland came up with for precision. It is now widespread in Germany. The consensus is if it is done correctly it is very accurate. The key is to record the speed accurately at high sampling. There is a youtube video on the method (Insoric) from the Prof but is in German. The only time I can see it being an issue is if you have traction loss due to too much power - it will mess up the signature, whereas on the dyno you strap down etc. and prevent slip but in reality you would have traction loss anyway on the road - i.e. it is the power being transferred to the pavement - real world power. Unfortunately the price is quite high else i would buy the device. It is a fairly inexpensive device but like all the tuning stuff, they ask for a lot of money ~4000-5000€.
Mac, now i need a clutch upgrade. Any recommendations?
Old March 3rd, 2018, 07:53   #66
Macradiators.com
I hear the perfexpert also gives good results when calibrated well. Weight of the car, frontal section area and CX play an important role.
Dynomet is another similar tool to Insoric, a guy in poland tested it different time VS Vtech dyno and he got pretty similar results.
Price about 3000€
CP3 Upgrade
Old March 3rd, 2018, 09:05   #67
eddie_1
eddie_1's Avatar
Price about 3000€
Interesting. Thanks for the info!
Old March 17th, 2018, 03:19   #68
eddie_1
eddie_1's Avatar
Got the clutch upgrade done. Used the Sachs Race Engineering (SRE) Pressure Plate and the SRE Organic Disc without springs. I decided not to go with an SMF at this point - figured a bit smoother with the DMF, less noises and not going totally crazy on power. Goal is to hold 650NM-700NM. Also the SMFs are quite pricey. This setup is officially rated at 550NM but holding fine.
A bit grabby initially taking off in 1st and reverse is worse, also engine braking into 2nd some chatter, but even after 3 days it has gotten a lot better. As posts in the internet say after 500miles equivalent town running should be fine. The biting point is higher up on the pedal, extemely short travel distance, so shifts are quicker.
This time I got some local guys to do the job. I felt the tranny is too heavy to bench press or do in the 'driveway' as I have done in the past with the 4cyl. Young Serbian German chap opened up his own garage couple of years ago. Really knowledgeable, nice guy gave me a good price. One journeyman and one apprentice took 5 hours together.
Parts removed were: piece of the exhaust, axle joints, transmission crossbar, gear cables and connectors.
In summary I really want to thank all the eastern europeans (Poland, Estonia, Finland (not quite 'east' but kind of - lol), CZ, Bulgaria) who helped with this project giving tips on the tuning. Could not have come this far without their tips out of sheer generosity and solidarity.
Old March 17th, 2018, 09:20   #69
adamss24
Fuel Economy: 35-45mpg
Good job mate ! Clutch pedal will get better as you’re piling in the miles !
adamss24 is offline   Reply With Quote
Old March 17th, 2018, 09:21   #70
adamss24
Now get rid of the dpf !
Old March 18th, 2018, 10:52   #71
altz1
TDI(s): Allroad, A8
Good job! Now you can say car is finished.
Old March 18th, 2018, 13:20   #72
eddie_1
eddie_1's Avatar
Thank you!
Old March 18th, 2018, 23:29   #73
adamss24
Eddie, i can see you’re still on original brakes, are 320mm big enough to stop you ? I had same brakes on a c5 a6 before and 335mm on a c5 allroad and they were scary sometimes ! I moved to 8pot calipers after as the brakes did not inspire me with confidence after getting brake fade a couple of times !
Old March 18th, 2018, 23:38   #74
eddie_1
eddie_1's Avatar
You are right. I am on 321mm brakes and there is a 347mm system from gasser 3.0T etc which can be used. However a while ago I switched to Zimmermann Discs with holes and the braking improved alot. Before that as soon as I did high speed hard braking on the autobahn >200kmh the brake discs warped immediately. These ones are not bad actually, but something maybe to do when the weather gets better.
Old June 29th, 2018, 13:56   #75
eddie_1
eddie_1's Avatar
Well 3 months later, the clutch hasn't been the best. It took a long time to break in, still has a little shudder in 1st and more in reverse due to lack of springs in the disc. Currently with the 90mg tune it slips in 5th gear. But in a strange way. For the 1st, 2nd WOT runs in 5th it slips but then after that it grips. Not sure why, sort of opposite to regular clutch which gets glazed. So it may get better with time. At the beginning after some break in time when I tried to test it, it was slipping even more. But now it has gotten less with time.
I might go back to an upgraded stock clutch. May have been better in the end.
The other option is the B8 dual clutch would be neat, but needs someone to adapt it to my BPP. Any recommendations for someone who could adapt this clutch or offers custom builds? I believe the hub needs to be changed out on the B8.
just installed new turbo and no boost vinniehobart VW MKIII-A3/B4 TDIs 2 March 8th, 2014 21:35
New turbo installed question dchapman TDI Power Enhancements 1 April 12th, 2011 04:55
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 03:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 13:59
Page generated in 0.17099 seconds with 10 queries
[Output: 143.84 Kb. compressed to 121.86 Kb. by saving 21.97 Kb. (15.28%)]
