Old September 27th, 2016, 12:00   #31
eddie_1
eddie_1's Avatar
Originally Posted by Lucian189 View Post
Again a nice work
Find a way to get more air to them.
Thanks Lucian! I will let you know what happens.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old September 28th, 2016, 15:16   #32
Machineman
Can any of you guys from Europe comment on were the turbo drain port is on the older bkn asb bmk 3.0 tdi im bought oil pans from a bkn and im stumped my newer cata engine has the port on the passenger side of the pan .
Machineman is offline   Reply With Quote
Old September 29th, 2016, 03:40   #33
hatemi
Iirc it drains to the head or the block at drivers side. The pipe is attached to the exhaust y-pipe with one bracket and goes under the exhaust manifold.
Lähetetty minun PLK-L01 laitteesta Tapatalkilla
www.tdituning.fi
hatemi is offline   Reply With Quote
Old September 29th, 2016, 04:50   #34
eddie_1
eddie_1's Avatar
There are 2 setups. One is as Hatemi said and is also on this car, where the return line is attached to the underside of the turbo and goes through an opening in the exhaust collector which also acts to support the Turbo. But the older bkn etc. 3.0 TDI have the BV50 Borg Warner Turbo (not Garrett) which sits on a separate 'tripod' similar looking to the collector but not the collector. It appears the oil goes through this 'tripod' support and then through a line back to the block on the driver side as Hatemi said. I know it is on the driver side but personally did not follow it all the way back.
Old October 1st, 2016, 01:09   #35
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
It is on driver side ,and bouth turbous are interchangeble,except for acctuator..
Lets say an cdya engine with gtb2260 and a bkn with bv50 ,bouth engines have the drain in the driver side ,and use same drain pipe.
Lucian189 is offline   Reply With Quote
Old October 3rd, 2016, 15:00   #36
eddie_1
eddie_1's Avatar
Got the boost back quite a bit at low rpm with minor fueling changes. See Turbo lag after IC and then recovery in chart with retune.
1) NM2IQ map asked for a bit more fuel where the Turbo comes up (was lowered earlier to save clutch but now ok due to lag)
2) More important altered the Boost set point map which requests turbo pressure at lower IQ.
Did some other unrelated fueling changes to go to 77mg/str now and lowered AFR a bit. 3rd gear pull time got quicker, although turbo not coming up as quickly. Unfortunately got a slight haze now.
There are a bunch of N75 maps in the map pack I am using, but I am not sure which one applies. Will try to figure out which one and see if I can increase duty cycle a bit.
Old November 26th, 2016, 10:04   #37
eddie_1
eddie_1's Avatar
Increased the fueling gradually to ~85mg. Clutch still holding fine. FWD Wheels tend to break loose on stop light take off but great on Autobahn. I get an IQ limitation above 4000rpm. The MAF shows not enough air getting in. I dropped the AFR at high rpm in the lambda maps to cheat a bit and it is slightly better. But there could be some other limiters above 4000rpm too. Any ideas? Might try to get the BiTDI 313HP MAF and try that. Anybody know the part number? Is it from the 4G?
Also a plot comparison of the IATs after the intercooler upgrade. Quite good after intercooler. After adjusting for outside temp differences about 30C better even with much more fuel being injected. see chart. Peaks are full throttle locations on the Autobahn. The blue curve is shorter as I logged for 15 mins and before the red was for 45mins.
Old November 27th, 2016, 11:18   #38
Lucian189
TDI(s): 3.0 TDI CR
So you satisfied with the mods?
Old November 27th, 2016, 12:19   #39
eddie_1
eddie_1's Avatar
Hi Lucian, yes very satisfied. Good power in mid range now. 100kmh to 200kmh acceleration is much better at 85mg. I will try to post 0-200kmh video soon. I don't plan any further mods at the moment. Without quattro and tiptronic the clutch and traction will become a problem for further mods. Great car actually.
Old November 28th, 2016, 09:50   #40
altz1
TDI(s): Allroad, A8
Maf drop at higher rpm is probably cuz of ports/cams. It just doesent breath good enough. I had similar situation. You can try to increase boost at higher rpm if egp and egt allows.
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Allroad C6 under construction, 420hp goal.
BVN 4.2TDI project twin gtd2060vzk, 650hp goal.
altz1 is offline   Reply With Quote
Old November 28th, 2016, 10:17   #41
eddie_1
eddie_1's Avatar
Thank you very much for sharing. I will try it out. EGT is really good after Intercooler. EGP/EMP I am not monitoring but I expect it is ok with bigger manifold compared to 4 cylinder.
Old December 5th, 2016, 02:27   #42
parik
TDI(s): q7 4.2 tdi
swith to asmod, these values in damos 2.7tdi
AirCtl_swtMAirPerCyl_C
PFlt_swtASModOn_C
AirCtl_swtmAirDT1In_C
parik is offline   Reply With Quote
Old December 8th, 2016, 09:47   #43
eddie_1
eddie_1's Avatar
Thanks Parik. I located these switches in the bpp damos but still looking for them in my file. Need to do a bit more pattern digging with respect to nearby maps. Looks like they are all related to turning off MAF dependency.
In the mean time I raised the boost to 2,8bar from 2,7bar for the same 86mg max fueling. The acceleration time 2000-4000rpm improved slightly and got rid off smoke haze. Turbo overshoots a bit on sudden full throttle to 1,9bar then settles to 1,8bar. But Turbo still sounds smooth.
PFlt_swtASModOn_C
Old December 12th, 2016, 12:30   #44
eddie_1
eddie_1's Avatar
PFlt_swtASModOn_C
- I found the switches but I am not sure if it will help at the moment. It looks like I will need to go maybe ~2.1bar and up, to get real power out at 4000rpm due to VE constraints. Currently I am pushing the charger to 1,8bar with slight 1,9bar overshoot. I don't feel comfortable pushing it any more. For the air I have, I think the fueling is maxed out. Need to look at upgrade options, but not a priority.
- What's been really great is that the clutch has been holding up. Basically what I found with the FWD traction is, that the wheels tend to slip before the clutch slips. Next summer I will probably try semi-slicks. In any case I have the tq limiter set below 600NM. What's funny is that from reading around it seems the quattro with manual transmission and same clutch starts to slip earlier due to heavier 4 wheel load.
- One other thing I did was massage the SOI maps 4-5 degrees advance at higher rpm and acceleration time did show minor improvement. Also advanced part load area at lower rpm where the times are retarded for EGR purposes. I did note slight improvement in fuel economy.
Old June 1st, 2017, 14:07   #45
eddie_1
eddie_1's Avatar
Finally got around to making a VIDEO with 0-100kmh, 100-200kmh, 200-261kmh and 200-267kmh runs.
0-100kmh run with VCDS was 7.37sec.
100-200kmh run with VCDS was 14.62sec.
Nowhere near 11/12 club , but I have serious weight. Last weighing was 2007Kg.
Max EGTs at sustained 267kmh was 988C under 1000C and outside temp 20C.
Still need to do another Insoric Power meas. Any guesses for the power?
I might eventually upgrade the MAF to BiTurbo to improve power at higher rpm.
Did a butt dyno plot of power in 3rd gear but needs to be verified of course.
just installed new turbo and no boost vinniehobart VW MKIII-A3/B4 TDIs 2 March 8th, 2014 21:35
New turbo installed question dchapman TDI Power Enhancements 1 April 12th, 2011 04:55
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 03:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 13:59
Page generated in 0.17438 seconds with 10 queries
[Output: 140.53 Kb. compressed to 118.91 Kb. by saving 21.62 Kb. (15.38%)]
