Old July 28th, 2016, 16:27   #16
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
Seems to smooth out the rail pressure a bit doesn't it? Project is looking good although you must be getting close to the limit of the clutch ?
Dannyboy is offline   Reply With Quote
Old July 29th, 2016, 03:19   #17
eddie_1
eddie_1's Avatar
Hi, i think that might be a logging inaccuracy. I was logging 3 parameters. Sometimes better to log 1 to get more points. Rail Pressure is adjusted just above 3500rpm to reduce duration.
Clutch seems to be holding up fine. I think they improved the clutches on these around 2007. There was a guy on here who had a 2006 A4 2,7 TDI BPP and his clutch slipped around 260HP. I looked into it earlier and found there might be different clutches being used. See post #6 from me in this Thread. Mine is 2008 vs his was 2006. I suspect I got a different part. I am pretty sure the newer ones are good to at least 600NM.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old September 12th, 2016, 03:43   #18
eddie_1
eddie_1's Avatar
Added Boost and Exhaust Temperature Gauges. Picked up the EGT kit from Auber while State Side this summer. The boost gauge is Raid HP sport. Bought an extra piece of A Pillar trim to make holes.
Last edited by eddie_1; September 19th, 2016 at 11:22. Reason: Pics didn't work first time
Old September 12th, 2016, 03:44   #19
eddie_1
eddie_1's Avatar
Last edited by eddie_1; September 19th, 2016 at 11:25. Reason: Pics didn't work first time
Old September 12th, 2016, 05:26   #20
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
Pics don't seem to be working
PD injector differences (click)
K.I.T.T. is offline   Reply With Quote
Old September 12th, 2016, 05:43   #21
xjay1337
Pics not working for me neither.
But good job never the less.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3” Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old September 12th, 2016, 06:22   #22
eddie_1
eddie_1's Avatar
Sorry about that guys. Google decided to change stuff around on hosting pics. Hopefully it works now.
Old September 14th, 2016, 03:13   #23
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
good work .
Lucian189 is offline   Reply With Quote
Old September 14th, 2016, 03:38   #24
eddie_1
eddie_1's Avatar
Thanks!
Originally Posted by Lucian189 View Post
good work .
Thanks Lucian!
Old September 19th, 2016, 07:00   #25
eddie_1
eddie_1's Avatar
did some WOT runs on the Autobahn to monitor IATs from VCDS log and EGTs and Boost from gauges.
IATs show peaking about 65C during high speed acceleration bursts on the Autobahn. See chart. Outside temp was 15C.
The GTB2260VK was boosting real nice. Here is a clip where I accelerated from stop through the gears. There is an occasional spike to 1.8bar but it settles quite well to around 1.7 bar WOT. Sorry the boost gauge numerals are not quite clear, but you can compare to earlier pics of it to know where the needle is.
https://www.youtube.com/watch?v=DC9aiyDoqy0
The EGTs are definitely climbing. lol. I took it up to about 257kmh and it maxed out at 1733F 945C. Decided not to push it any more. Car seems to have a bit more push to it after the last fuel up tick and the temps cooled to 15C. See clip. I read different opinions on what EGTs this Turbo can handle, sounds like it can handle 1900F or 1040C after some improvements. Probably true because I pushed it several times to over 260kmh before and it likely hit >1800F and it always runs effortless.
https://www.youtube.com/watch?v=bzG8iQhLgPI
In any case I got this double SMIC from KWE some East German guys, so I can log again after. Will put it in soon and report back.
Last edited by eddie_1; September 19th, 2016 at 11:28. Reason: problems with hosting site
Old September 19th, 2016, 11:29   #26
eddie_1
eddie_1's Avatar
Sorry about intermittent problems with pics. Switched from google drive to flickr now.
Old September 23rd, 2016, 06:02   #27
xjay1337
:-) yay.
I think one large front mount would have been a better choice than 2 smaller ones.
Old September 23rd, 2016, 06:21   #28
eddie_1
eddie_1's Avatar
:-) yay.
You are right. They have one for the A5 which could be made to work but the TÜV (MOT) guys will ask me to remove it. i.e. it is a bit too obvious in the front.
Old September 27th, 2016, 00:44   #29
eddie_1
eddie_1's Avatar
Installed the upgraded dual intercooler. When in pretty good. Couple of bolts holding the interconnecting pipe were rusted needed to be drilled out. Also the bumper needed some holes slits/holes cut out. The new cores were about 90mm fat compared to 60mm.
Well I got a bit of a Turbo lag with 85% more volume but when it comes on you can feel it is stronger. Will have to get the tune adjusted to fire up lambda down low and fine tune to remove spiking.
Will report back with IC related data.
Before:
After:
Old September 27th, 2016, 11:34   #30
Lucian189
TDI(s): 3.0 TDI CR
Again a nice work
Find a way to get more air to them.
just installed new turbo and no boost vinniehobart VW MKIII-A3/B4 TDIs 2 March 8th, 2014 22:35
New turbo installed question dchapman TDI Power Enhancements 1 April 12th, 2011 05:55
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 04:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 14:59
Page generated in 0.15314 seconds with 10 queries
[Output: 142.47 Kb. compressed to 120.00 Kb. by saving 22.47 Kb. (15.77%)]
