Old April 11th, 2016, 09:48   #1
eddie_1
eddie_1's Avatar
Default Installed 3.0 TDI Turbo in 2.7 TDI
Just completed the upgrade. Finally put in the GTB2260VK Turbo from the 3.0 TDI 059145722R in my 2,7 TDI which has the GTB1756VK 059145721F. From the VAG EKTA data it looked like everything would fit if the Y exhaust collector 059131799L was also replaced with the 3.0 Y collector 059131799R. This Garrett 059131799R Turbo the has the matching DP flange. However the EGR flange turned out to be a bit bigger on the Y collector which meant I ended up doing a 5mm thick block off plate. Also did a small flux wire weld to add a small holder for the turbo oil return line, which was avail. on the old collector.
Overall not a bad job to do, except access to the collector is a bit tight. Removal of just the turbo itself only takes minutes. Once I removed the fresh air intake piping/air filter and the charge air outlet piping on the pass side and the coolant reservoir on the driver side access was much better. The lower driver side bolt on the collector had to be accessed from below. The M10 bit is your friend. Had 3 different versions of M10 in play 1/4 drive 3/8 drive and single bit. managed to lose the single bit on the driver side.
Did a log with the same old tune and despite it being a bigger wheel the lag is less (see chart)! The EGR block off at the collector must have helped I take it.
The 2260 feels solid. Just need a tune now.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old April 21st, 2016, 15:34   #2
eddie_1
eddie_1's Avatar
Put the new turbo to work today. With first tuning attempt with 2650mbar pressure and 75mg Injection Quantity was able to reach 260kmh.
https://www.youtube.com/watch?v=OkwA9nF3TkQ
Old May 7th, 2016, 02:24   #3
eddie_1
eddie_1's Avatar
Actually it turned out the youtube video tune was no where near 75mg. But I got my tune sorted out now including the accurate logging above 70mg. A bit tricky tuning this BPP. The chart shows 3rd gear acceleration time now with 73,7mg compared to youtube video tune. From 2000-4250rpm almost a whole second quicker! Have to do something about EGTs and then hopefully get it on rollers.
Old May 15th, 2016, 22:46   #4
eddie_1
eddie_1's Avatar
Got the downpipe in. The main challenge was to get off the axle heatshield. There is a top heat shield bolt which is tricky to access and needs a really long hex bit to go from the front driver wheel side to the top bolt. Of course I left that one out when putting back together. Once the middle hanger, the end of the dpf and downpipe/precat is released at the turbo (and all sensors detached: lambda, egt, dpf) the whole front exahaust system moves down several few inches down allowing unbolting of the precat from the rest (unbolting due to rust difficult otherwise). One precat nut was frozen and the bolt broke off. But no biggie. Normal for this area with exposure to the elements. The exahaust system bolts are actually pressed into the flanges. The precat downpipe can then be rotated so the top flange faces the opposite direction and lowered out. (This point is harder on some of the earlier 3.0 TDIs where there is a holder on the precat preventing this rotation and there the transmission was needed to be lowered. The Elsawin indicated the need for lowering the transmission but it was not necessary with this 2008 BPP). Originally I thought the procedure would need to be done on a lift but it wasn't needed either. On the rebuild attached the downpipe to the turbo first and then brought the rest of the hardware together from below. The German downpipe in itself was a work of art and a perfect fitment. Replaced all the nuts with copper nuts....feels like 30HP more from the downpipe. The dpf is freed up but an actual pipe in it would be better for flow.
Old May 16th, 2016, 00:15   #5
eddie_1
eddie_1's Avatar
Here is a picture of the holder circled in red right after the downpipe. On some cars this holder is on the downpipe/precat itself making removal difficult. As I said I went to someone with a lift but for mine ended up doing it on the floor anyway.
Old May 27th, 2016, 07:18   #6
eddie_1
eddie_1's Avatar
Started to get the software sorted out. Here is a 0 to 266 km/h pull - Fairly quick all the way up. Not bad for over 1900Kg and FWD? No smoke, clutch is holding fine. Summary: GTB2260VK working on 2,7 litre not 3,0 (10% less work), EGR blocked, catless downpipe, knocked out dpf, 3bar map, 73,7mg@2.65bar. Will get on rollers as final step, although looks like alot of people are doing Insoric type measurements these days.
https://www.youtube.com/watch?v=2JVWM0Ba-Sg
Old May 27th, 2016, 10:03   #7
mrrhtuner
mrrhtuner's Avatar
Very cool eddie!
I'd love to head out to germany sometime in the mid future myself.
mrrhtuner is offline   Reply With Quote
Old May 27th, 2016, 11:28   #8
eddie_1
eddie_1's Avatar
Originally Posted by mrrhtuner View Post
Very cool eddie!
Thanks! Definitely ping me if you come over.
Old May 27th, 2016, 12:11   #9
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
I miss the good old days down the A7, don't miss the Friday traffic on the A2 though. They still put up that speed camera off the 352?
Awesome project by the way , you still have tuv?
Dannyboy is offline   Reply With Quote
Old May 27th, 2016, 12:23   #10
eddie_1
eddie_1's Avatar
Yeah, If you go at the right time A7 is still good for a full trottle run. I did this one heading south on the A7, south of the A2. No chance on the A2, it is always jammed with Eastern European traffic. My earlier video in this thread I did on the A352 which is also fairly quiet but is only 2 lane. I prefer 3 lanes. As far as I know there is no camera on the A352. I have TÜV but will need to undo exhaust mods before going back. It's a bit complicated with TÜV but usually if there are no 'visible' mods you are ok.
Old June 18th, 2016, 08:40   #11
eddie_1
eddie_1's Avatar
I went for an Insoric Measurement today. Unfortunately there was some rain during the measurement but did get an ok result. The car reached 283BHP and 531NM (3rd gear measurement). Torque comes in a bit late but it was setup to save the clutch a bit. Might still try to crack the 300BHP threshold. Either way about 100BHP gain over stock for about €500. :-) Turbo and downpipe.
Old June 19th, 2016, 14:09   #12
Lucian189
TDI(s): 3.0 TDI CR
Fuel Economy: What's that for?
I am just curious what values for fuel temp did you have now ?
At 32 degrees outside i saw 90 degrees fuel temp...on my BMK
Lucian189 is offline   Reply With Quote
Old June 19th, 2016, 21:48   #13
eddie_1
eddie_1's Avatar
Actually I don't know. I am monitoring only pressure and EGT. I don't have additional cooler for fuel, stock one is quite good I think. I am not pushing the car hard for a long time, only occasional bursts so no issue here i think. Did you upgrade BV50?
Old June 20th, 2016, 02:12   #14
Lucian189
TDI(s): 3.0 TDI CR
No ,i haven't upgrade anything .
Actually,engine is a swap onto a b6 audi a4 ,with stock for now BKN ECU .
Values seems high to me ,for fuel temp. Fuel cooler is the stock one from ex engine 1.9 AVF.
Old July 28th, 2016, 13:21   #15
eddie_1
eddie_1's Avatar
Increased the IQ over wider range a bit after the Insoric power measurement. From 73.7mg/str to 75.7mg/str. Still hardly any smoke with same boost and clutch holding fine. Great having the IQ diagnosis in VCDS working. Might go for IC upgrade as last step.
just installed new turbo and no boost vinniehobart VW MKIII-A3/B4 TDIs 2 March 8th, 2014 21:35
New turbo installed question dchapman TDI Power Enhancements 1 April 12th, 2011 04:55
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 03:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 13:59
Page generated in 0.18227 seconds with 10 queries
[Output: 145.74 Kb. compressed to 123.50 Kb. by saving 22.25 Kb. (15.26%)]
