I have the 5V plugs but the tune was altered to use 7V
I replaced one plug after 5 years
Consider yourself lucky.. buckle up for my story.
I had random glow plug faults for a long time with this car which I kept fixed via harness reseating. This eventually stopped working but my multimeter ohm test did not show them burned out. So I finally replaced the harness. No change in symptoms. I also checked that I was receiving voltage from the controller, but I received strange voltages that were neither 5 nor 7V. I have a fluke 187 true RMS meter, but no oscilloscope. Well, a real head scratcher I thought.
After running out of ideas I tried the splice all 4 wires together method that's mentioned in the big GP thread. The idea is that if one plug is bad you fool the computer into thinking they all have the same resistance. Don't do it kids, it does NOT work on the more modern BEW platform. This burned them out good and proper right away. I found afterwards with my meter that this has the effect of causing pure 12V to come out of the GP controller. My theory is that the PWM signal alternates plugs, and if you tie them together you get 12V constant signal. Wish I had a scope to verify this but suffice to say, it finally boogered plugs good and proper. Now all of them test bad with ohm check.
At my wits end with this confusing situation I put the wiring back to stock and purchased a new set of 5V plugs. The ones I pulled out were 5V Bosch, so I went and purchased identical OEM 5V Bosch. Threw them in thinking "new harness, new plugs" this has to work. Well, after 3 weeks the GP light is back on and two of my brand new plugs test bad with ohm meter.
Finally at this point I looked under my cowl to see if maybe my controller was faulty. That's when I find the revision D controller and it dawned on me that the 5V Bosch plugs were incorrect. I purchased the 7V plugs, and a new revision D controller for good measure (unknown if it was actually bad). No problems at all since.
I suppose I'm partially to blame for bad diagnosis not checking the GP controller or software revision before swapping plugs, but I blame the dealer for having the wrong plugs installed in the first place. The only two things I've ever had done at the dealer were the GP recall (which I assume was done right), and an engine swap a few years later on insurance claim (wish I just did it myself). I believe they forgot to swap plugs between the two engines and that's now I got into this mess.
