Old February 8th, 2016, 11:46   #1
tikal
Fuel Economy: 37 MPG (~ 45% city)
Default Cerium based diesel fuel additives
I think this topic came out some time ago but I did not see any links with some explanation about it:
https://en.wikipedia.org/wiki/Cerium
One of the products that uses this technology to reduce particulate matter and potentially clean DPF and catalytic converters:
http://www.cdti.com/content/americas...technology.htm
Specifically formulated for use with DPFs, Platinum Plus DFX-DPF delivers benefits at multiple levels.
  • Passive and controlled regeneration are made possible at temperatures in the low 300C range, easily achieved by the bus operators in their regular route, by either driving the bus at highway speeds or by loading the engine on uphill grades for 5-10 minutes. This activity will either dramatically reduce or eliminate cleaning requirements.
  • Controlled regeneration without fear of run-away heat production, which might otherwise damage filter integrity or create tailpipe flames
  • Complete regeneration of even dry soot from the EGR engines dropped backpressure from 5 psi to 0.5 psi.
  • Platinum Plus increases the rate and completeness of combustion, thereby lowering the amount of engine-out soot by as much as 25%. This helped maintain a cleaner DPF longer, based on decreased loading; even five months after passive regeneration, backpressure did not exceed 3 psi.
  • More complete combustion and less backpressure also improved fuel economy (although specific amounts were not measured in the course of this program).
Complete passive regeneration initiated by loading the engine between 2250-2450 rpm.
Another company using this technology is Xenum in Belgium:
Cerium Oxide in NEXGENTM
http://www.xenum.com/technology/tech...fuel-additive/
As far as I know this technology is not widely used in North America but in Europe. Maybe because of EPA regulations?
I am posting this in the spirit of discussion and I am not endorsing any of these products.
tikal is offline   Reply With Quote
Old February 8th, 2016, 12:28   #2
South Coast Guy
Fuel Economy: Good
Another additive. Sigh.
South Coast Guy is offline   Reply With Quote
Old February 15th, 2016, 08:44   #3
wensteph
googled it and cerium oxide is used as a polishing compound so that pretty much takes it off the list of things I want to put in my engine.
It is used as an agent in self cleaning ovens and as a less expensive replacement for platinum in cats so it does do the items listed in the first product's bullet points, but each of those items are something is, or may, already be done. As the consumer, the ability to replace platinum does nothing for me, but it does look good when attached as a bullet point.
wensteph is offline   Reply With Quote
Old February 15th, 2016, 11:17   #4
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
A lot of the reason why cerium oxide-based DPF additives didn't fly in the US was because the EPA was really leery of any emissions additives altogether.
No reason why they couldn't allow it now, though, now that AdBlue is OK.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is online now   Reply With Quote
Old February 16th, 2016, 13:00   #5
tikal
I agree with bhtooefr. I am sure there are pros and cons but it is a technology that it is staying and possibly increasing in usage worldwide:
Evidences of the cerium oxide-catalysed DPF regeneration in a real diesel engine exhaust: http://rua.ua.es/dspace/bitstream/10...l_TopCatal.pdf
Take this company which is mainstream in Europe, Wynns which is using it:
http://www.wynns.eu/wp-content/uploa...07/prof_EN.pdf
Sometimes we are technology adverse if it was not initiated in America.
Old February 18th, 2016, 00:43   #6
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
yes, we've talked about it before; both the factory fitted injected system used by PSA (Eolys) as well as that Wynns stuff. I've used the Wynns additive and it did extend the period between active regens...
DPM is offline   Reply With Quote
Veggie Based Oil, Fuel Additives, Grease and Cleaners 01greenjetta Fuels & Lubricants 13 September 13th, 2012 21:55
Ferrous picrate-based diesel additives? Craig_PD130 Fuels & Lubricants 14 January 4th, 2011 16:02
Cerium-based additives and the DPF? DPM TDI (Diesel) Emissions 6 April 14th, 2009 14:39
Bio Power Soy Based Diesel Fuel Conditioner Winterizer Improves Fuel Economy 13.6% Dennis P Roth Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 4 April 1st, 2006 13:58
Canola Oil Based Diesel Fuel Conditioner - Canada Couleetdi Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 23rd, 2004 05:42
Page generated in 0.16381 seconds with 10 queries
[Output: 76.95 Kb. compressed to 67.53 Kb. by saving 9.43 Kb. (12.25%)]
