Old December 22nd, 2015, 04:53   #61
mrrhtuner
mrrhtuner's Avatar
This weekend I did the following:
-Diesel Purge on my mk4 wagon (https://www.youtube.com/watch?v=feO5H62Ja3A)
-Fuel Filter change
-Oil change
-Install replacement driver's side engine cover (part of belly pan)
-Installed winter tires
-Installed my refurbished OEM headlights with GE Nighthawk bulbs
I did discover that my passenger front wheel has side to side play and up and down...everything was night and tight when I re-did my wheel bearings (removed the spindle) and got an alignment afterwards.
Seems I'll need to mend that and get another alignment again :@
mrrhtuner is offline   Reply With Quote
Old December 22nd, 2015, 06:47   #62
steve6
Make sure the bolt is tight mrrhunter, theres a hand full of threads that talk about using an impact gun or re-torqueing this bolt after initial drive. If its been loose its probably going to need to be changed again though.
steve6 is offline   Reply With Quote
Old December 22nd, 2015, 07:11   #63
mrrhtuner
mrrhtuner's Avatar
I will give that a check, thanks Steve
Old December 22nd, 2015, 18:15   #64
vlodster
Fuel Economy: 47
Ordered parts (shipping to Alaska)
New Tandem Fuel Pump to replace leaker: $290
Tandem Pump Bolts: $8.60
Triple square bits for Fuel Pump R&R: $41.50 (shipping is a $%^&)
another Coolant Sensor (My coolant heater fried first night I plugged in)$11
Alternator Pulley: $80
Adjusted new headlights (stock where way hazy)
2004 Jetta BEW manual 156,000
Rotella T6 5W-40
Repairs I've done myself so far:
Fuel Tank Lift Pump
Timing Belt @100,000 miles
Alternator wiring harness and battery fuse box module
New Thermostat
New Coolant Sensor
New Headlights
New Shocks and struts
New Passenger side outer tie-rod
vlodster is offline   Reply With Quote
Old December 23rd, 2015, 11:26   #65
lanorg
Fuel Economy: 5-6.5L & 7-9/100km
That youtube video on the diesel purge...... was automatic transmission fluid put in the fuel filter?
That freaked me out.
lanorg is offline   Reply With Quote
Old December 23rd, 2015, 12:41   #66
mrrhtuner
mrrhtuner's Avatar
What makes you think that? There is no image of auto transmission fluid anywhere in sight?
Old December 23rd, 2015, 19:50   #67
UhOh
UhOh's Avatar
Swept snow off mine
Oh, the other day I "repaired" a rear brake light on the wife's Golf. After determining that I didn't have a new spare bulb I pulled one out of my car so that she could get off to work. I then discovered that her bulb was fine! Seemed that the socket wasn't holding the bulb tight enough and it lost contact- compressed it a bit, pulled up the power contact, and all is back to relative peace (cars aren't asking much of me, and I'm appreciating it!).
Old December 24th, 2015, 01:41   #68
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
Did I see one of these on the floor in your garage? LOL
http://www.amazon.com/Justification-.../dp/B000EJRHDU
I haven't seen one of those posters in forever!
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old December 24th, 2015, 05:20   #69
laika99
Fuel Economy: 4.8L/100km on ALH Sedan, 5.2L/100km on BEW Wagon
Default 2006 BEW Wagon Turbo Replacement
Original Borg-Warner KP39 had problems controlling boost at high power. After some troubleshooting with inputs from tdiclub members, narrowed it down to the turbo ... so swaped in a new VNT17:
http://forums.tdiclub.com/showpost.php?p=4966956
Full thread under http://forums.tdiclub.com/showthread.php?t=450780
laika99 is offline   Reply With Quote
Old December 27th, 2015, 15:35   #70
Rembrant
Rembrant's Avatar
Dropped the subframe on the 2000 Beetle today.
This thing is so rusty...looks like the whole works is going into the scrap bin.
Old December 28th, 2015, 10:48   #71
454k30
TDI(s): 2002 Jetta
Fuel Economy: 35city- 48hwy
Default Vacuum Lines!
Not today, but within the last few days, I changed out every vacuum line under the hood. It wasn't as tough as I had feared. I purchased six feet of 3mm hose, 3 feet of 5mm hose, and another 3 feet of 3mm fuel line (for the injector return lines). I took each section of house out one at a time, cut the new hose to that length, and then reinstalled the new hose. I ended up with about 6 inches of left over hose for each type. I actually cut the lines 1/4 to 1 inch longer than the originals and still had leftovers. I read about the job here on the forum several times before attempting this. Most people said the turbo was the hardest part. I disagree. If you want to do this work just drop your skid plate and the thing is right there. It could not be easier. The toughest part (the part I broke ) was the nipple on the anti-shudder valve. The new hose is run to that valve and I'm waiting on the new part to arrive. Until then the car shudders a bit on shutdown, but it's not too bad.
2002 VW Jetta TDI, Timing belt done at 80k!
.216 JB Morrison nozzles, Malone Stage 1.5, Southbend Stage 2 Daily.
454k30 is offline   Reply With Quote
Old December 28th, 2015, 10:56   #72
steve6
finished timing job on the 03, 544,000 kms. Good to 700,000 hopefully now ehhh?
Old December 28th, 2015, 13:13   #73
Rembrant
Rembrant's Avatar
Of course! They show up here on Kijiji every once in a while with 700+ on them. A local GM dealer had a 2000 for sale last year with 768,000 kms on it...and they still wanted $4000 bucks for it...lol.
Seems the rust gets 'em before the mileage most of the time. My 2000 Beetle only has 208,000 kms on it, but it's so rusty it should have gone to the junk yard a couple years ago.
Old December 29th, 2015, 23:30   #74
Caddy 16v
Caddy 16v's Avatar
Installed some Hella Sharptone horns on the Jetta.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old December 30th, 2015, 05:34   #75
Black00Jetta
Black00Jetta's Avatar
Fuel Economy: 51.1/44.3/39.6
Installed a new cv axle on passenger side due to torn boot. First time doing this so it took me the whole day (with some stress breaks!). Got alignment done and then went on a 3500 mile trip and road fine.
2000 Jetta GLS TDI 5spd manual, 272k , chipped, Frost heater, metal skid plate, Metalnerd brake tool, ventectomy, VCDS(but need to learn how to use it). Scangauge
Black00Jetta is offline   Reply With Quote
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 18:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 15:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 06:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 05:19
Page generated in 0.17996 seconds with 10 queries
[Output: 131.37 Kb. compressed to 110.21 Kb. by saving 21.16 Kb. (16.11%)]
