Old December 15th, 2015, 12:29   #46
steve6
Originally Posted by pcjohnson_ohio View Post
Changed the oil. Tried to change the lower engine mount. Couldn't.
No amount of pounding or prying would break it loose.
If you mean the lower dog bone, most people break the bolts and just smash the aluminum around the bolts, and then the bolts will come out with vice grips or pipe wrench. The aluminum oxidizes and wont slide off the bolts.
steve6 is offline   Reply With Quote
Old December 15th, 2015, 13:38   #47
mrrhtuner
mrrhtuner's Avatar
I had the same thing happen.
One bolt let loose, the other...snapped.
Haven't got back under there to fix it :-(
mrrhtuner is offline   Reply With Quote
Old December 15th, 2015, 14:18   #48
PGM jetta
TDI(s): 05 Jetta BEW
Had that happen when I replaced my dogbone. I covered the new bolts with copper anti-seize. Hopefully they won't oxidize as bad
PGM jetta is offline   Reply With Quote
Old December 15th, 2015, 16:54   #49
Jake_S
Jake_S's Avatar
R&R the lift pump. Job was incredibly easy, and only took about 30 minutes.
Jake
05 Jetta Wagon, 09A, EGR delete, k0mpressed tune, VNT17
84 Chevy K20, 350/SM465/NP208
Specialized StumpJumper FSR
2012 GT Transeo 2.0 w/ carbon fork
KHS Flite 300 w/ Ultegra drivetrain
Jake_S is offline   Reply With Quote
Old December 15th, 2015, 20:19   #50
OlyTDI
TDI(s): '04 Golf
Aquapel on the windows...another 6 months of not needing wipers!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old December 16th, 2015, 07:16   #51
steve6
Its pretty standard, any regular TDI mechanic I talk to said this is the 'procedure' when they change clutches/trans work lol. dog bone and new bolts are factored in.
Old December 17th, 2015, 04:53   #52
mrrhtuner
mrrhtuner's Avatar
Steve/everybody else....when you were presented with this issue and used a hammer to loosen the dogmount bushing from the seized bolt(s), was the mount re-usable afterwards? I didn't understand if you meant that a new mount and bolts are needed or just bolts.
Old December 17th, 2015, 05:01   #53
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
No, I think it's pretty common practice to break the aluminum ears off around the bolts, thus the dogbone mount becomes scrap. I just removed one like this recently from a spare subframe that I bought. Both bolt heads snapped off, and the bolts were locked hard in the mount.
If you look closely at the mount, you may see hairline cracks down the sides of the bolt ears where it mounts to the subframe. The salt and corrosion can only expand so much in the holes, the aluminum will eventually crack anyway.
You can get a new dogbone for about $50 bucks. I think most people don't worry about ruining the old one because if you break those bolt heads off, it's usually because you're trying to replace the mount anyway.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old December 17th, 2015, 06:46   #54
mrrhtuner
mrrhtuner's Avatar
Great, thank you for the help!
Old December 19th, 2015, 15:58   #55
PGM jetta
Did both front wheel bearings, new brakes, and new rotors. No more groaning!
Sent from my XT1254 using Tapatalk
Old December 19th, 2015, 18:52   #56
where2
where2's Avatar
Changed out my locked up alternator clutched pulley, and potentially cleared up my P0671 CEL by dealing with my #1 glow plug resistance.
Got my parts from Kerma. If the original German pulley lasted 195k, I shouldn't need another German pulley anytime soon...
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost... 155k
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 222k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old December 19th, 2015, 19:24   #57
baggedmazda
Just starting to dip my toes into these cars I did a nice simple oil change lol next up will be a alarm and double din radio along with some new rear hatch struts
baggedmazda is offline   Reply With Quote
Old December 19th, 2015, 20:29   #58
giff
giff's Avatar
Just removed the "tree hugger" bumper stickers from the previous owner. My wife didn't even want to ride in the car until they were off! Cleaned the intake and turbo a couple weeks ago, timing belt is next, then she is going on the road.
giff is offline   Reply With Quote
Old December 21st, 2015, 00:32   #59
BluFalcon
BluFalcon's Avatar
TDI(s): 05 Golf TDI
Fuel Economy: 38 MPG Highway :-( Autotragic Tranny
Towed my Golf from Texas to my GF's house in Kansas in preparation for my upcoming relocation to Wichita.
Tried to drive in reverse to get the car off the tow dolly, and it wouldn't come off of it. Little to no power whatsoever. I eventually got the car off and took it for a spin around the block.
Car felt "weird" while accelerating and had a very hard brake pedal.
Poked around a bit and found a section of the brake booster line cracked completely through and another section with cracks starting. I "band aided" one section with a piece of rubber glove and some electrical tape (If it's stupid, but it works then it's not stupid anymore). The section that was completely cracked through got some heater hose and zip ties. Took it for a spin and everything works again.
Ordered the right parts and I'll fix it correctly when I go up again in two weeks.
05 VW Golf TDI-Has a Diesel Engine
99 Mazda Miata-Might Be More Fun With a Diesel Engine
06 Mitsubishi Raider DuroCross V8-Needs a Diesel Engine
BluFalcon is offline   Reply With Quote
Old December 21st, 2015, 13:15   #60
Davegsm82
Fuel Economy: 57MPG (Golf) + 42MPG (T25)
Drove 300 miles home with either a failed HG or cracked coolant jacket.
Not proud but had to be done. About 8 litres of water vaporised into the atmosphere.
Dave.
Davegsm82 is offline   Reply With Quote
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 18:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 15:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 06:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 05:19
Page generated in 0.21262 seconds with 10 queries
[Output: 129.76 Kb. compressed to 108.82 Kb. by saving 20.94 Kb. (16.14%)]
