Old November 27th, 2015, 12:26   #16
pcjohnson_ohio
TDI(s): 2003 Jetta
Used my VCDS for the first time
Reset the ESC light which promptly came back on.
I guess I need to recalibrate it
pcjohnson_ohio is offline   Reply With Quote
Old November 27th, 2015, 20:03   #17
gots_a_sol
TDI(s): 00 Jetta tdi
Over the past few weeks: New springs/struts/lift kit, 205/70-15 Yokohamas, and mud flaps
-Joe
00 jetta tdi - 1" lift kit, heavy duty springs, yokohama geolanders 205/70-15
gots_a_sol is offline   Reply With Quote
Old November 28th, 2015, 09:33   #18
dirtride
TDI(s): 2003 Golf
Fuel Economy: mid to upper 40's
Nice bike! Glad to see that someone else here not only rides but rides a 2 stroke.
Mark
03 GOLF ~ GLS ALH EGR (turned it into a mutt)
00 F-350 ~ 7.3 PSD 4WD ZF-6 XLT LBCC (modified, not a mutt)
dirtride is offline   Reply With Quote
Old November 28th, 2015, 10:23   #19
dataflow
TDI(s): PD100
Fitted an audi a8 fuel cooler as a fuel heater. plumbed in off the oil cooler.
dataflow is offline   Reply With Quote
Old November 28th, 2015, 12:47   #20
catodd
TDI(s): 02 Jetta GLS
That is nice.....how many more inches of lift did this give you? Do you have part numbers.....I would like to do this to my 02' Jetta.
02' Jetta TDI GLS Manual, Profidiesel Exhaust, EGR delete, Malone eco-tune
catodd is offline   Reply With Quote
Old November 28th, 2015, 15:48   #21
guitarsail
TDI(s): 2001 Jetta
Finally got a RossTech Cable and discovered what my waining mileage and slow car was all about. My MAF is shot! Unplugged it and not a stinking thing changed in how it drove (slow) except it threw a default air measurement on VAGCOM and drove exactly the same. Well that explains why my mileage has been falling to 40mpg over that past year and it can't get out of its own way.
I'm hoping that brings some pep back to her step and restores to fuel economy.
guitarsail is offline   Reply With Quote
Old November 28th, 2015, 16:58   #22
gots_a_sol
Looks to have settled at 2". 1" from the springs, 1" from the lift kit. Without the trailer hooked up there is a bit of a rake to the front.
Moog 81134 (v6 front springs)
Moog 81055 (wagon rear springs)
Bilstein TC shock 19-029429 x2
Bilstein TC strut 22-045744 x2
Evolution 1" lift kit
Tires are 205/70-15 Yokohama Geolanders which are about 1.5" taller than stock.
-Joe
Old November 29th, 2015, 13:42   #23
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
Sand blasted and painted my spare Mk4 subframe today. Had to weld one of the sway-bar clamp nuts back in place, and then ran a tap through all of the threaded holes. Ugh...those old rubber mounts were a bear to remove.
It was cheap, and it cleaned up OK. I'll snap new mounts in, and then install this in the Beetle when I change the steering rack.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old November 29th, 2015, 19:10   #24
windyhill
TDI(s): '03 Jetta
Just finished the heater core😤
windyhill is offline   Reply With Quote
Old November 30th, 2015, 09:27   #25
Xenodraken
Installed
Eibach 8575.680 - PRO-SYSTEM-PLUS
Eibach 5.81340K - PRO-ALIGNMENT Kit
kit comes with springs damper, front and rear anti roll bars. The alignment kit allows camber/caster changes.
Everything went together nicely too.
It lowered the car about an inch all around. was a bit of work to get the stock FSB out, because you have to lower the sub-frame, and learn some yoga when doing the job on jack-stands, but after 200kms with the new setup its causing many
something to be said about a matched set of components, even though its more $$$. very happy with the handling thus far.
Alignment feels spot on still, but i think ill take it in just to be sure. Anybody know an alignment shop that's familiar with the Eibach setups in southern ontario?
...yes I'm pessimistic. When I am right, I already expected the worst, and it's no shock. When I am wrong, its always a good thing :P
*2005 Jetta GLS TDI* PlastiDiped "Black and Blue", Digi-PD, Eibach Pro System Plus Suspension
Xenodraken is offline   Reply With Quote
Old November 30th, 2015, 16:17   #26
fruitcakesa
Fuel Economy: 40's
Overdue oil/filter change in the 03 just in time for winter.
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old November 30th, 2015, 17:18   #27
to.tdi
I cleaned my manifold and the egr valve which i think i broke it. The shaft inside egr doeant move anymore?
to.tdi is offline   Reply With Quote
Old November 30th, 2015, 19:02   #28
pcjohnson_ohio
TDI(s): 2003 Jetta
Replaced rear wheel hub. Turned out to have a frozen caliper too. A bit more work than expected but went well.
Old December 1st, 2015, 22:13   #29
Caddy 16v
Caddy 16v's Avatar
Winter shoes for the Jetta (Michelin X ice xi3) and the Golf got a new windshield. The Avus wheels feel so much lighter than my Long Beach especially turning at slow speeds.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old December 4th, 2015, 13:04   #30
WolfgangVW
WolfgangVW's Avatar
Originally Posted by deejaaa View Post
installed a new grille block with access for the new 60w LED spotlight. getting ready for night driving and feral hogs.
What is your setup for night driving??
WolfgangVW is offline   Reply With Quote
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 19:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 16:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 07:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 06:19
Page generated in 0.21412 seconds with 10 queries
[Output: 126.35 Kb. compressed to 105.42 Kb. by saving 20.92 Kb. (16.56%)]
