Old March 4th, 2018, 10:12   #2341
TDIGAZ
TDIGAZ's Avatar
Fuel Economy: Of Course! 5.05 l/100kms or 56 mpg/47 USmpg over 316 fill-ups
Originally Posted by romad View Post
Only 62,136.5 more miles to go, I see.
Yep, 1/2 million kilometers would be nice to see
At my current pace that would be almost 3 years away. I guess time will tell.
"Life is a Highway"
Protected by an Evolution Atlas skid plate
Some handy 'How to's' : Troubleshooting Low Power (AKA Limp Mode)
TDIGAZ is offline   Reply With Quote
Old March 4th, 2018, 17:43   #2342
Elysian
TDI(s): 04 Golf
Replaced my belt tensioner and alternator pulley, tensioner still bounces a little bit, thinking maybe it needs a new serpentine belt, but not sure.
Also reset the airbag code, light is off for good now.
Elysian is offline   Reply With Quote
Old March 5th, 2018, 17:51   #2343
where2
where2's Avatar
Windshield washer pump arrived from Hong Kong, so I installed it and have working washer functions again.
If only it were this easy to fix the washer issue on my 2006 daily driver (company car).
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost... 155k
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 222k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old March 7th, 2018, 00:23   #2344
UhOh
UhOh's Avatar
Replaced the clutch slave on the wife's car. Hoping that this resolved a stench issue that has popped up a couple of times following her doing a lot of clutching: new clutch; when replaced I'd seen a dribble of fluid on the end of the slave but stupidly ignored it.
Installed a new front ashtray cover in my car. Old one was really yucky. The bottom trim piece on the dash cage is also yucky and I need to track down a replacement for that as well.
Old March 8th, 2018, 12:23   #2345
crashtested
crashtested's Avatar
Replaced the LF wheel bearing; RF went Nov 2016 - not bad for a car with 361k km on it!
MKIV
Outback
Last edited by crashtested; March 14th, 2018 at 12:16. Reason: Tardis was out for service!
crashtested is offline   Reply With Quote
Old March 9th, 2018, 19:43   #2346
wonneber
Originally Posted by crashtested View Post
Replaced the LF wheel bearing; RF went Nov 2018 - not bad for a car with 361k km on it!
RH bearing went 8 months from now??
You must know Dr. Who.
Old March 10th, 2018, 03:33   #2347
UhOh
UhOh's Avatar
Always good to be proactive!
Old March 10th, 2018, 23:10   #2348
Caddy 16v
Caddy 16v's Avatar
Stupid P0380 popped up, hope I can wiggle some wires. Doing head gaskets on my Duramax has me dreaming on how easy it is to work on the TDI instead.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old March 11th, 2018, 00:39   #2349
UhOh
UhOh's Avatar
Replaced the oil cooler in the wife's car. A while back I'd noted that it was leaking pretty good: limped it along until it was time for an oil change. The cooler was leaking when we got the car, at which time (about 65k miles ago) I'd replaced the seals. All seemed fine until recently. Not sure why it decided to start leaking, but I didn't want to take the chance of new seals not sealing up well so opted to replace the cooler. Interesting, though, how the top seals' alignment tabs no longer seem to line up (using them results in distorting the seal = leaks): seal manufacturer or oil cooler manufacturer? What a messy job this is.
Replaced the vacuum lines to the turbo and to the vacuum reservoir ball. Also replaced the hook strut (was getting pretty weak).
Old March 11th, 2018, 09:36   #2350
PB_NB
PB_NB's Avatar
Put some Michelin Pilot Sport AS 3+ tires (225 35 19) on the BBS wheels and mounted them on the car. Got rid of the crappy tires that came with the used rims when I bought them a few years ago.
Getting ready to go camping in a week!
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old March 11th, 2018, 20:30   #2351
dober
Removed my roof racks and the studs that hold them in place from my wagon of good. All 6 of the mounts have leaked at one point or another and the aluminum was starting to corrode also.
dober is offline   Reply With Quote
Old March 11th, 2018, 21:18   #2352
ToxicDoc
TDI(s): 2001 Jetta
Secured my air cleaner box with the correct hardware (thank you to Volk14).
Also replaced my rusty and streaking wiper arms with the aero arms and beam-type wipers. Driver's side excellent result. Passenger side now leaves a wide a band in the center. I'm hoping a different blade will fix the problem.
ToxicDoc is online now   Reply With Quote
Old March 12th, 2018, 03:25   #2353
red16vdub
red16vdub's Avatar
Pic of the 19” on car ?
Bajan
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old March 14th, 2018, 12:15   #2354
crashtested
Duh-Oh!! Nov 2016**
MKIV
Outback
Old March 19th, 2018, 08:28   #2355
Judson
TDI(s): 2001 Jetta
Pulled the battery and tray and wired in the ground clip. It hadn’t been included in my six speed conversion so the existing connection kept coming loose. Now it’s clipped on and will stay there!
Also, while the tray was out re-routed some ground wires to the factory location.
2001 Jetta TDI, converted to manual, black leather/red stiching, PP520s, rc4, franko6 cam, 11mm pump, VNT 17, PD150 intake, EGR/cooler delete, 2.5" Buzzken exhaust, PD150 clutch/flywheel, DRW six-speed, Eurojet intercooler, 3bar MAP, FIS Cluster, Cupra bushings, Koni Reds/stock springs, Alpine iLX-207, foglights, Indiglo boost gauge, Longbeach wheels, Euro wood steering wheel, lift pump, Gentex autodim/homelink mirror.
Judson is offline   Reply With Quote
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 18:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 15:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 06:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 05:19
Page generated in 0.19120 seconds with 10 queries
[Output: 134.80 Kb. compressed to 112.98 Kb. by saving 21.82 Kb. (16.18%)]
