Conrad -JSW
A little help needed with multiple faults. Rear bearing replacement.
2012 JSW TDI w/37k miles running perfectly, till last night. I had just filled up and stopped to grab a bite and then did some grocery shopping. On the way home the dash lights up like Christmas tree.
Low tire MIL
Airbag MIL
ABS MIL
I get home to my garage and check the messages on the MFD, 3 pages.
The car seems to be running ok and I interrupted a regen when I shut it off in the garage (second one today according to my wife).
1, Error: Airbag.
2, Fault: Stabilization Control (ESC).
3, Service in --- miles or in --- days. (I don't know why the numbers aren't displayed as I changed the oil and fuel filters two weeks ago and reset the service reminder then)
I scan with VCDS and here are the error codes.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492700FB880E06EA92200042B70000
Shop #: WSC 00066 000 00000
VCID: 7BDB1CC8FA2841E608-802E
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 118
Mileage: 59565 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 85
Count: 51202
Count: 1
Count: 257
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 59573 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 16390
Count: 49664
Count: 0
Count: 511
Count: 0
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0RD1%
Coding: 00003133
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 3FA3A8D8A6B09DC664-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00002G3J00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME0B520365ZZZP
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME14150465ZZZK
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME17533129ZZZC
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME3D1D3A29ZZZ-
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME05580629ZZZB
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME07470629ZZZC
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 119
Mileage: 59565 km
Date: 2015.11.05
Time: 07:55:00
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3449F7F457F64E9E89-8060
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 59565 km
Time Indication: 0
Date: 2015.11.05
Time: 07:54:45
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 28.0°C
RPM: 1510 /min
Speed: 77.0 km/h
Speed: 77.0 km/h
Count: 0
I'll be checking the right rear wheel's speed sensor this morn. Any other ideas?
TIA!
Low tire MIL
Airbag MIL
ABS MIL
1, Error: Airbag.
Revision: 00H31001
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 118
Mileage: 59565 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 85
Count: 51202
Count: 1
Count: 257
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 59573 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 12
Count: 12800
Count: 16390
Count: 49664
Count: 0
Count: 511
Count: 0
Coding: 00003133
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 119
Mileage: 59565 km
Date: 2015.11.05
Time: 07:55:00
Revision: 00H20000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 59565 km
Time Indication: 0
Date: 2015.11.05
Time: 07:54:45
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 28.0°C
RPM: 1510 /min
Speed: 77.0 km/h
Speed: 77.0 km/h
Count: 0
TIA!
