Old June 6th, 2017, 14:01   #16
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by Jetta_Pilot View Post
Of course the whole malware problem is moot if you use a dedicated older laptop running XP Pro for the VCDS and nothing else !
Don't we wish. If it never connects to the internet chances are better at remaining clean, but it can be infected if any device like a USB stick, flash drive cd, floppy are present.
A lot of folks still use XP and Microsoft no longer supports it.
The bad thing about the various malware is it floats thru the email chain, propagates and is hard to spot.
Best to create a bootable cd that can run an off-line (no windows) scan with an updated definitions file.
Old June 18th, 2017, 07:21   #17
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Read what I stated again !!!!!!!!
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old June 19th, 2017, 02:44   #18
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
That's what I do as well. I have an old single core XP laptop that I use. Never connects to the internet.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old June 22nd, 2017, 14:05   #19
BobnOH
not-a-mechanic
No I'm not gonna read that again.
Did I disagree? Didn't mean too, you were correct. Repeated info with a bit of background, so I thought.
For some nothing else doesn't necessarily mean sans interweb....
My "don't we wish" comment was in reference to Microsoft and their software policy.
VCDS computer? tinnmann Ontario 5 October 8th, 2015 18:51
Vcds psa tjsean0308 OBD Scanners 3 October 3rd, 2015 23:29
VCDS like software for Jeep Wrangler JASONP OBD Scanners 4 May 28th, 2015 05:21
Need someon willing to hook up there vcds software to my mkv ParaCAD South Eastern USA 0 March 13th, 2015 10:12
VCDS Software out of date SledDawg2 OBD Scanners 15 July 26th, 2013 12:04
Page generated in 0.13353 seconds with 10 queries
[Output: 68.88 Kb. compressed to 61.75 Kb. by saving 7.13 Kb. (10.35%)]
