Old March 14th, 2017, 04:11   #46
frambach
TDI(s): 3 ALHs
Thanks for the compliment.
Unfortunately, there isn't enough room to mount the VW A/C compressor down low on either side.
For that reason, I've ditched the stock U.S.A. injection pump bracket in favor of an imported, non-A/C bracket.
I'd really like to have A/C & plan to try to figure something out at some point down the road.
frambach is offline   Reply With Quote
Old March 14th, 2017, 14:48   #47
papasmurf
papasmurf's Avatar
Yeah i was hoping with the passat/audi a/c compressor bracket would work. Being in Florida I'll have to see how to make it all fit
papasmurf is offline   Reply With Quote
Old March 14th, 2017, 15:44   #48
frambach
TDI(s): 3 ALHs
I'm in for more info on this if you get to it before me. I've made sure to not disturb the condenser or any of it's mounting points or lines when mocking up our intercooler (which I put behind it - in the location of the stock radiator).
I plan to put the radiator on custom mounts that actually bolt to the frame rails (and not the core support or intercooler) back behind the intercooler.
I used our Sprinter for reference on what order the atmosphere should hit: condenser, intercooler, & lastly, the radiator.
Old March 19th, 2017, 16:52   #49
papasmurf
papasmurf's Avatar
Would still love to see a side shot of your truck bud. I've seen a 4 door tacoma dually just not an extended cab
Old March 26th, 2017, 20:23   #50
frambach
TDI(s): 3 ALHs
Here's how it's sitting in the shop. The front is on jack stands since I'm working above and below to get the exhaust routed out of the engine bay and down the inside of the driver's side framerail.
Other items in the pic:
- factory VW Jetta radiator
- my sweet Femi bandsaw (for cutting the exhaust tubing so perfectly)
- the wiring harness (hanging - look just behind the cab and up. It's suspended from above to chase wires and remove nonessentials.)
- 3VZ sitting on the rear of the frame rails
Old March 26th, 2017, 20:28   #51
papasmurf
papasmurf's Avatar
Looking great man!
Old March 30th, 2017, 07:13   #52
vtpsd
Fuel Economy: 45mpg avg
I am enjoying following your project. I am planning on building a 2wd single rear wheel pickup with extended cab and an ALH when the body on my jetta gets bad, so this is a great resource. I've been wanting to build one of these for several years, but keep talking myself out of it for some reason, or I end up building other projects. I may have said this a few pages back, but your solution for the dropped steering link is great. Something that is totally achievable in a home shop. Thanks for sharing that.
Do you know if a stock ALH vnt15/manifold would fit in the truck engine bay? I would like to swap over my ALH from the jetta in as-close as possible to stock form.
Again, great fab work.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old March 30th, 2017, 16:42   #53
frambach
TDI(s): 3 ALHs
Getting the VNT15 into the engine bay does not appear to be the problem. However, getting the starter bolted up is the issue. The starter hugs close to the TDI's block - right where the turbo resides. Perhaps a 4cyl Toyota's starter location is different but I don't think it is.? I started with a V6 truck and stuck with the R150 (2wd, V6 manual 5spd) trans for our swap.
Thanks!
Old March 31st, 2017, 05:05   #54
vtpsd
Ahh, that makes sense. Looks like I would have to re-work the turbo to a more top mount configuration. I would likely start with a v6 truck as well since the trucks I am trying to buy are the optioned out versions with extended cabs, and it seems like most of those are v6 powered.
Old April 1st, 2017, 14:39   #55
papasmurf
papasmurf's Avatar
Bhw turbo manifold from a b5.5 passat if you're willing takes care of the space issue
Old April 6th, 2017, 06:53   #56
jimbote
jimbote's Avatar
this ^^
Old April 6th, 2017, 07:58   #57
Rockwell
Rockwell's Avatar
That's what I'm using in my Toyota
2003 Jetta TDI - 17/22 *RIP*
1986 Toyota pickup - VW 1.6TD swap, Giles IP, GTD nozzles. Soon to be TDI
2011 BMW 335d sport *sold*
1996 B4 Passat
Rockwell is offline   Reply With Quote
Old April 6th, 2017, 10:28   #58
frambach
TDI(s): 3 ALHs
That's the manifold I'm using as well.
However, looking from the rear forward, my turbo is shaped like a 'p' whereas yours is shaped like a '9' which gives you way more clearance than my setup.
Old April 6th, 2017, 20:31   #59
baggedmazda
Wow cool build I happened on trying to research swapping a alh into my little b2200 look forward to following progress
baggedmazda is offline   Reply With Quote
Old May 29th, 2017, 22:58   #60
papasmurf
papasmurf's Avatar
Any more updates? Can't wait to see this running!
'86 2WD Toyota, 1.6TD to AHU Rockwell TDI Conversions 61 January 29th, 2018 15:19
2001 ALH/1995 toyota tacoma 2wd swap Heathd TDI Conversions 151 August 28th, 2017 08:01
tdi to 1975 to 85 toyota pu transaxle 2wd vwdriver10 TDI Conversions 4 August 28th, 2012 03:12
Possible ALH into 1992 Toyota ????? Turbospool TDI Conversions 4 January 27th, 2011 14:58
2wd toyota tdi? Frog187 TDI Conversions 9 February 4th, 2010 20:40
Page generated in 0.16362 seconds with 10 queries
[Output: 128.34 Kb. compressed to 107.15 Kb. by saving 21.19 Kb. (16.51%)]
