Old January 24th, 2017, 11:33   #31
Rockwell
Rockwell's Avatar
Originally Posted by frambach View Post
Thanks jimbote. Your input is much appreciated.
Rockwell, here is a pic of the exhaust. It's kind of hard to tell from the pic but it comes out of the turbo as a 2.5". I immediately bump it up to 3" and start going downward and toward the bellhousing. The reason for the 'dip' before going up and over the bell is to give a little more clearance on the oil temp sensor wires and the hose I plan to send over to the heater core.
The other couple of exhaust pics can be found here:
http://imgur.com/a/GVYZI
Nice. The 1.6 I originally had in mine before had the exhaust going under the engine, like it crossing over behind the head better. Much cleaner install but was harder to do correctly. I couldnt quite fit 3" comfortably, I went with 2.25" and that gives a little room to wrap it or get it ceramic coated.
2003 Jetta TDI - 17/22 *RIP*
1986 Toyota pickup - VW 1.6TD swap, Giles IP, GTD nozzles. Soon to be TDI
2011 BMW 335d sport *sold*
1996 B4 Passat
Rockwell is offline   Reply With Quote
Old January 24th, 2017, 13:07   #32
Hasenwerk
Hasenwerk's Avatar
I can't help to think that you are going to run into issues with melting the plastic output flange. Needless to say that you exhaust can get HOT and that's really close to the plastic! I'd be looking at exhaust wrap to try to reduce that risk as much as possible.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old January 24th, 2017, 13:51   #33
Rockwell
Rockwell's Avatar
If there is no room for wrap, check out the white lightening coating at http://swaintech.com/race-coatings/automotive-coatings/ It's a thick true ceramic coating, not a thin cosmetic coating, and should help keep the temps down.
1996 B4 Passat
Old January 24th, 2017, 22:20   #34
frambach
TDI(s): 3 ALHs
Rock, behind the head is a neater looking install IMO. With that 2.25", you were at liberty to run that straight section. With the 3", it's a tight fit with NO room to run straight pipe. It took me quite a while to articulate those pie cuts to clear everything back there. I was pretty hellbent on running 3" though.
I'm very happy with the way it's looking so far.
As far as heat mitigation, I plan to ceramic coat it AND wrap it. DEI has some great wrap heat blocking products. I saw their display at PRI in Indy this year. That ceramic from Swain Tech looks very enticing. Thanks for sharing.
I'm hoping we can block enough heat off of that plastic housing. That 3" exhaust should flow well too. <finger crossed>
frambach is offline   Reply With Quote
Old January 25th, 2017, 13:10   #35
vtpsd
Fuel Economy: 45mpg avg
That 3" looks nice, I think it is overkill for the HP that the TDI can make. 2.5 should be plenty, but the hard work is done now! And it sure looks sweet.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old January 25th, 2017, 14:02   #36
frambach
TDI(s): 3 ALHs
It IS too much as it's built now. I was hoping it would help keep EGTs down and leave room for further power enhancements down the road
I had some 2.5" on hand and tried it. As crazy as it sounds, that extra .5" makes a huge difference in clearance AND, a v-band for 2.5" tubing WILL clear all the way around the back of the head/firewall.
Like I said, I was just hellbent on running 3"
Old January 25th, 2017, 14:14   #37
vtpsd
I have built several old audis and used 3" on all of them (big turbo gassers). There is a very similar pinch point on those cars where the exhaust goes over the rear axle and above the subframe. I did 2.5" on this car because I figured it would never be over 250hp. SOO much easier to fit the 2.5" As you said, v-band clamps fit so much easier too.
That 3" pipe looks good. I like this project, and dream of putting the ALH from my mk4 into a nice clean, early 90's 2wd SRW toyota when the mk4 body gets too rusty. I love the steering modification, I would do something like that if I go through with it.
Old January 25th, 2017, 14:22   #38
frambach
TDI(s): 3 ALHs
We should be in the 220hp range now. If we go with a 12mm pump, bigger injectors, and bigger turbo, we should be in the range where we would need 3".
That's a bit down the road but eventually, I'd like to get there.
Thanks for your feedback. I appreciate the compliments.
Old February 2nd, 2017, 15:37   #39
frambach
TDI(s): 3 ALHs
The BHW oil cooler / heat exchanger arrived from the folks at Cascade German (formerly Bora Parts) and I've got it on.
I cut one of the original coolant lines that went to the A/T cooler and this is what we're looking like:
Now, if I can get the coolant flange situated, I can move on to wiring
Here's what I'm hoping to do for the coolant flange. A simple, sleek outlet that I can weld whatever I want to. There's only one problem... I need to find someone to machine it. Any takers? LOL
(excuse the crudeness. Getting Google Sketchup to place nice with all the faces is not easy - at least it isn't for me)
It's machined to have a 1.5" OD outlet. Then, I could take a piece of normal aluminum tubing and make whatever I need. I went with 1.5" because that's what our radiator is going to have for an inlet.
I wouldn't want to go too awfully far with my 1.5" tubing. Just enough to clear the back of the head and have a bend in it moving everything away from the exhaust and firewall - I'm thinking 30*-ish.
Once installed, it has a flat on the top. I think that could be drilled and have an aluminum bung welded to it to receive the stock Toyota coolant temp sensor.
Old March 5th, 2017, 08:47   #40
Ranch
TDI(s): ALH
I see you are in NH.. which may be beneficial to using Swain. (close to you) I used WWW.jcmmachineandcoating.com for several large engine piston coating jobs. They are south of St. Louis Mo. (closer to me)
Slightly better pricing, but the main reason I used Jcm is they got it done quickly. At the time, Swain told me it was going to be a month lead time. Jcm had my pistons back to me at end of that week.
Keep in mind this time of year (March onwards) is racer prep, and everybody is busy.
Ranch is offline   Reply With Quote
Old March 6th, 2017, 14:02   #41
Rockwell
Rockwell's Avatar
Swain did take awhile, but so is my project. I looked at JCM, they seem to do good work too
1996 B4 Passat
Old March 12th, 2017, 16:36   #42
papasmurf
papasmurf's Avatar
Did you use the toyota brackets on the frame? I was about to cut mine out and start over from scratch with them. Do you have any pics of them?
papasmurf is offline   Reply With Quote
Old March 13th, 2017, 05:23   #43
frambach
TDI(s): 3 ALHs
I did leave the brackets on the frame. From there, I replicated the factory, engine side, mounts' pad and built out from there. I'll leave this tab open on my computer and supply pictures when I get back home.
Old March 13th, 2017, 20:22   #44
frambach
TDI(s): 3 ALHs
Hopefully these will help you see what I did.
This is the drivers side looking from the front toward the back:
& this is the passenger side. Again, looking from the front to the back.
Old March 13th, 2017, 21:27   #45
papasmurf
papasmurf's Avatar
Wow! Some of the nicest I have seen. Great job. Is there enough room on the passenger side for an a/c compressor?
'86 2WD Toyota, 1.6TD to AHU Rockwell TDI Conversions 64 October 13th, 2018 20:11
2001 ALH/1995 toyota tacoma 2wd swap Heathd TDI Conversions 151 August 28th, 2017 09:01
tdi to 1975 to 85 toyota pu transaxle 2wd vwdriver10 TDI Conversions 4 August 28th, 2012 04:12
Possible ALH into 1992 Toyota ????? Turbospool TDI Conversions 4 January 27th, 2011 15:58
2wd toyota tdi? Frog187 TDI Conversions 9 February 4th, 2010 21:40
Page generated in 0.15306 seconds with 10 queries
[Output: 132.73 Kb. compressed to 111.60 Kb. by saving 21.13 Kb. (15.92%)]
