Closed Thread
Old September 18th, 2015, 11:56   #61
DSL HED
Fuel Economy: Better than a gas engine
And they would have gotten away with it if it wasn't for those medding WVU kids!
Would the 23o6 campaign be related to this? I still haven't had that done and am in no rush to get it done since it would involve a dealer visit. Maybe I will continue to wait although I read that the DSG shudder at low speeds is improved after that update.
Either way, VW(oA) seems to be in pretty big trouble. They really are their own worst enemy.
2014 Tempest Blue Jetta SE 1.8TSI, dual note horn mod (aka Bluebell)
2012 Candy White Golf wagon mit DSG und aspherical mirrors (aka Waggy)
DSL HED is offline
Old September 18th, 2015, 11:58   #62
road hog
I wonder how this will effect my straight pipe, egr/dpf delete?
Sent from my XT1094 using Tapatalk
road hog is offline
Old September 18th, 2015, 12:01   #63
ABS
ABS's Avatar
Fuel Economy: Fuelly
I mentioned in a PM that I am curious to see how deep this rabbit hole goes. However, at this point we have one-side of the story. Therefore, and although I am very concerned what this will do to the future of these awesome vehicles, I am anxious to hear details from VW, and will withhold judgement until then.
In Garage:
2014 Passat SE TDI, 6-m/t, Tungsten Metallic
2002 BMW E46, 5 m/t, Oxford Green Metallic
2006 Honda Odyssey Touring
ABS is offline
Old September 18th, 2015, 12:01   #64
dubStrom
dubStrom's Avatar
One other thing... we all just took a hit on the value of our TDIs.
How much? more than the reality of the consequences, I am sure.
But no doubt, we just lost $1000 trade-in value, and maybe something similar in sale by owner events.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline
Old September 18th, 2015, 12:02   #65
darrelld
darrelld's Avatar
This is not good, I was trading my Last VW in the household off for a 2016 Volt, now a 2017 Volt since I live in Texas.
Hopefully residuals won't take too big a hit till then.
darrelld is offline
Old September 18th, 2015, 12:02   #66
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Originally Posted by cevans View Post
Re: the dyno testing.
EPA does emissions compliance and efficiency ratings on a dyno. Regardless of the state inspection procedure, VWs had a switch that fooled the EPA test.
Originally Posted by evoblade View Post
Maybe if there was a device detected plugged into the OBD2 port. When I was in Indiana, our "emissions" test consisted of plugging a computer into the OBD2 port. I assume it was checking for emissions related error codes. There were no tailpipe checks.
This wouldn't have affected a state inspection, this would've only affected EPA certification tests. Per the EPA letter:
Each VW vehicle identified by the table below has AECDs that were not described in the application for the COC that purportedly covers the vehicle. Specifically, VW manufactured and installed software in the electronic control module (ECM) of these vehicles that sensed when the vehicle was being tested for compliance with EPA emission standards. For ease of reference, the EPA is calling this the "switch." The "switch" senses whether the vehicle is being tested or not based on various inputs including the position of the steering wheel, vehicle speed, the duration of the engine's operation, and barometric pressure. These inputs precisely track the parameters of the federal test procedure used for emissions testing for EPA certification purposes. During EPA emission testing, the vehicles' ECM ran software which produced compliant emission results under an ECM calibration that VW referred to as the "dyno calibration" (referring to the equipment used in emissions testing, called a dynamometer). At all other times during normal vehicle operation, the "switch" was activated and the vehicle ECM software ran a separate "road calibration" which reduced the effectiveness of the emission control system (specifically the selective catalytic reduction or the lean NOx trap). As a result, emissions of NOx increased by a factor of 10 to 40 times above the EPA compliant levels, depending on type of drive cycle (e.g., city, highway).
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline
Old September 18th, 2015, 12:03   #67
Got Haggis?
The switch (ecm software) senses whether the vehicle is being tested or not based on varoius inputs including the position of the sterring wheel, vehicle speed, the duration of the engine's operatoin, and barometric pressure. These inputs precisely track the parameters of the federal test procedure used for emission testing for EPA certification purposes. During EPA emission testing, the vehicles' ECM ran software which produced compliant emission results under an ECM calibration that VW referred to as the "dyno calibration" (referring to the equipment used in emissions testing, called a dynamometer). At all other times during normal vehicle operation, the "switch" was activated and the vehicle ECM software ran a separate "raod calibration" which reduced the effectiveness of the emission control system (specifically the selective catalytic reduction or the lean NOx trap). As a result, emissions of NOx increased by a factor of 10 to 40 times above the EPA compliant levels, depending on the type of drive cycle (city, highway)
from the epa letter
Got Haggis? is offline
Old September 18th, 2015, 12:04   #68
jhinsc
No affect at all.....
jhinsc is offline
Old September 18th, 2015, 12:06   #69
Good Ol' Boy
VeeDubTDI's Avatar
Angry No politics!
Originally Posted by phlfly View Post
Well I'm not embarrassing as VW , I'm embarrassing for this administration trying to increase cost to consumer!
I can't wait a day when Obama gone for the office and his stupid cabinet. These guys made more damage around the world than Bush with stupid wars. I'm sicking of him everyday more and more. EPA is Obama's instrument to kill private sector production.
This is your one and only warning. Anyone who attempts to turn this thread into a political debate will get banned for a month!
VeeDubTDI is offline
Old September 18th, 2015, 12:07   #70
learningneverends
Or its a great time to buy a used one.
learningneverends is offline
Old September 18th, 2015, 12:14   #71
jhinsc
read this story http://www.nytimes.com/2015/09/19/bu...ware.html?_r=0
I like this :
"Analysts said it was meant to send a clear message to automakers that they will be harshly treated for compromising federal rules."
They want to make it clear that they’re going to crack down on cheaters,” said Frank O’Donnell, president of the environmental advocacy group Clean Air Watch. “They’re cheating not only car buyers but the breathing public. They want to lay down the law, enforce the law, and show they’re not going to tolerate cheaters. The laws and regulation are only as good as the enforcement.”
Really, how about recreational marijuana, is Colorado state cheating on Federal regulation for using "drugs" ?
Double standards?
Oh, they care what we are breathing? Really, but don't care what our children is inhale drugs?
WOW, liberal bias!!!
I would think a tobacco smoking driver of a new vehicle emits more pollution than the vehicle itself. I lump marijuana and alcohol in same category - they both drugs and have similar effects.
jhinsc is offline
Old September 18th, 2015, 12:14   #72
Good Ol' Boy
VeeDubTDI's Avatar
Thumbs up
Hold onto those VEs and PDs!
Old September 18th, 2015, 12:15   #73
jollyGreenGiant
jollyGreenGiant's Avatar
Two sides to this story I'm sure... EPA has had the biggest hard-on for keeping light duty diesels fleet percentages low. Nearly unattainable federal NOX limits on certification ( much more stringent than the EU ones for NOX ) being the biggest hurdle, which is why TDI's prior to 2006 were so freaking rare... VW couldn't sell them in any quantity per EPA regulations, fleet percentages and all that craziness. The long time club members and early TDI owners know this all too well.
Remember that EPA is a government agency that doesn't necessarily represent their constituents so much as cater to their buddies: domestic automakers, the oil/gas industry and other folks with big wallets. Punches have been thrown back and forth, this is EPA using the high-ground, "you cheated", argument to gain public backing amongst other gains.
Having said this. it wouldn't surprise me a bit if VW actually did somehow "cheat", as I'm sure every other manufacturer has done as well, this is BIG business people, when I think of the word corruption. This, even if true, pales in comparison to SO many in-our-face examples, big banks, big-pharma, Halliburton war machine, fracking, etc. The fact that EPA didn't find cheating on some domestic high-volume gas powered pile of bolts first just proves my point. You know where they want to throw their punches and it's not at their friends, they're getting pushed into the ring by whomever is funding the big fight. Folks who are simply pushing monopoly pieces around.
The TDI CR diesels are insanely clean, the folks who actually own and drive them can all nod their heads in agreement. If everyone drove them solely, I'm willing to bet, bad air days would drop like a rock across the board and "non-attainment" areas would dissolve. I don't have data to back that up, I speculate. But I DO know what I'm talking about and worked 10 years as a professional in the emissions testing industry.
Before everyone goes and badmouths VW and throws them under the bus, I think it's smart to look at both sides first and put yourself in both sets of shoes to best understand how these things happen the way they do. It's like prohibition, people are gonna drink, if the powers that be say no you can not, well, then folks find ways around that ridiculousness.
This particular punch in this long drawn out brawl isn't an efficient campaign to combat climate change and pollution in my personal opinion, TDI's are some of the best examples of vehicles reaching for the aggressive EPA mileage and CO2 targets looming.
IDK, just my $.02, carry on...
jollyGreenGiant is offline
Old September 18th, 2015, 12:17   #74
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
If you are interested, I have just put my 2014 Passat SE TDI with 15K miles up for sale...make me an offer. BTW, it gets better MPG than the EPA ratings.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline
Old September 18th, 2015, 12:18   #75
Samcar222
Fuel Economy: 35-38 MPG town, 45-48 hw; {40 town, 51.6 hw w/ massive tailwind, 42.6/tank are records}
Well said jolly.
'10 JSW TDI-Moms-Salsa Red-DSG-rear side airbags-pano roof-mats/splash-buy back at 90k replaced with '17 Alltrack SEL, 23k, 25/36, tank in snow
'03 ALH Jetta Wagon 5mt 305k lots o' rust, will explode at any moment
'01 BMW 530iA-Dads-Anthracite-118k
Samcar222 is offline
Closed Thread
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Page generated in 0.52055 seconds with 10 queries
[Output: 135.57 Kb. compressed to 114.16 Kb. by saving 21.41 Kb. (15.79%)]
