fouillard13
Hey guys. when idiling, the car seems to have a big of a rattle/vibration coming from the front end somewhere, close to the firewall, right in the center it almost sounds like.. it kind of sounds like plastic. its not the valve cover. im sure its a pretty common rattle and it only happens at idle. if I give it 100 more RPM it goes away. anything I should check? sounds like it would be easy to fix, I just cant find where it could be coming from!!! any tips?
thanks.
thanks.
