Old August 26th, 2015, 06:56   #1
thechoochlyman
thechoochlyman's Avatar
TDI(s): 97 Passat
Fuel Economy: 47.5 daily, 51.4 highway
Default 1Z/AHU Billet CCV drain plates, shift knobs, and custom machining
Hey guys, I'm Charlie from Legacy Mold and Tool. We're a small machine/tool shop located in Bardstown, KY and have been in business since 1997. Since I've been with this company, I've starting developing products to benefit my own vehicles - including my B4 Passat. I'm going to list a few things that I currently offer, and also discuss some things I'd like to bring to market later.
Updated 4/7/16
Billet serpentine belt tensioners. $125 for the whole thing assembled with a brand new bearing installed and ready to bolt on. Won't have a new bolt, so you'll want to keep that.
Updated 9/21/15 - We now very proudly offer our billet aluminum coolant flanges for the 1z engine. These replace the stock plastic part that tends to crack periodically - OEM part 028121132A. No more worries of reliability! We currently have NONE in stock. Please PM me directly if you want to place an order. You will need to source the following for installation:
1) Short 3/4 NPT pipe
2) Hose barb with 1/8 NPT threads for return line
3) Liquid thread sealant
More pictures can be found here, and installation details are here.
Originally Posted by Digital Corpus View Post
So there are 2-3 fittings you need to round out the billet flange and have it plug right into the system. As indicated in the first post, the flange have female threads for 3/4" NPT and 1/8" NPT barbs. The barbs should be 1" and 5/16" to mate to the stock hoses and the latter is best with a 45˚ or 90˚ angle, though only the former is practical with the flange.
Be aware that brass, zinc, and steel don't play nice with aluminum over the long term so if you can find straight aluminum fittings, that's perfect. If you're fine wit a little blue or red, you can pick up inexpensive 3/4" NPT to 1" barb fittings on Amazon in, well, blue or red. This matches a local surplus store giving me 2 blues with kinda crappy anodizing for $6 ea.
The 5/16" barb is a pain to find and the one Steve_Addy found here is your best bet for a 1 piece solution. If you want something more local, you can go with a 1/8" NPT to 1/8" NPT zinc plated steel 45˚ elbow from Amazon and add on a black anodized 5/16" barb too.
For the latter two use some sort of thread locker or sealant. From my research, Loctite 242/243 should be perfectly fine to use. Yes, you're dealing with an already oxidized surface, but if you run the threads of the fitting together, it'll scrap off the anodization and give you a more reactive surface. You can always pick up some primer too if you're more comfortable.
Billet CCV drain plate for the 1Z/AHU/AFN engine. This will replace the stock plastic drain tube which tends to break periodically. It comes with an O-ring, two mounting bolts, and a 1/2 NPT hole which can either be plugged or plumbed to your valve cover. Price is $35 shipped per item.
An installation example can be found here.
Billet shift knobs - all types available for $75 shipped. Standard engraving is included (shift pattern, TDI/VW logo, etc.) Custom engraving is available, starting at $25. Currently the only vehicle I can immediately provide a shift knob for is a B4 Passat or vehicle with an M12x1.5 stick thread. If you want a shift knob for a different model, please PM me - I'm willing to develop products for any generation.
Update 4/8/16
Billet aluminum window guide clips - the ones that always break and make you buy a whole new assembly. Buy one for $35, buy three for $100. Fix your regulator for good!
We are a fully-capable machine shop with:
Hurco CNC Mill
Prototrak CNC Lathe
Wire EDM
Sinker/Ram EDM
Surface Grinders
Heat Treating oven
We work with all kinds of materials, and are open to quote custom jobs. If you have a specific product you'd like to see us build in the future, please send me a PM for details.
Here's a link to our Facebook page: https://www.facebook.com/LegacyMoldandTool
1997 Passat 5 speed - No longer bi-tone
2.5" Straight-pipe exhaust CCV/EGR Deleted Malone Stage 3, 2.0 IQ Autometer Gauges Billet Stuff
Billet Coolant Flanges - Idler Pulleys - CCV plates - Window Guide Clips
Last edited by thechoochlyman; April 13th, 2017 at 06:23. Reason: Added information
thechoochlyman is offline   Reply With Quote
Old August 26th, 2015, 08:38   #2
john.jackson9213
TDI(s): 1996 B4V
Charlie,
Here is a plastic part on the B4 that just cries out for a metal replacement.
http://forums.tdiclub.com/showpost.p...postcount=4670
If you check out the "What did you do to your B4" thread around post 4670 you will find a discussion about this needed part.
The current replacement part is C.R.A.P.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old August 26th, 2015, 08:57   #3
Abacus
That helpful B4 guy
Abacus's Avatar
Oh man, make the right parts and you'll be a gold mine!
I'm liking that CCV base!
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old August 26th, 2015, 09:08   #4
thechoochlyman
TDI(s): 97 Passat
Coolant Flange... that's interesting!
Do either of you have a ruined one you could send me to prototype? I'm not really sure where this part is on my car, and I'd rather not have to remove it. haha I don't exactly recognize it, either. But I'm sure it would be easy enough to machine a flat plate at least, similar to the CCV plate.
EDIT: John, thanks for the shout-out in the B4 forum - I appreciate the added publicity!
Old August 26th, 2015, 09:10   #5
thechoochlyman
TDI(s): 97 Passat
Thanks! I recently sold three to another forum member after he saw my post in that thread. Mine is working out great so far, no leaks to be found - and sturdy as a rock.
Old August 26th, 2015, 09:20   #6
Abacus
That helpful B4 guy
Abacus's Avatar
I have one I can send you since it was just removed. But, would you be better off taking dimensions from a CRAP one or an OEM one? I just ordered 2 OEM ones from a dealer and most of the ones you find out there being sold are CRAP.
Old August 26th, 2015, 09:27   #7
thechoochlyman
TDI(s): 97 Passat
Most definitely, the OEM part would be the best candidate for reverse-engineering. Since you're willing to take a plunge with me here, I'd be pleased to send you a finished part free of charge once we're done. Of course, I may also have to send you a few prototypes along the way to make sure it's sufficient. Could you post some pictures of where this is located so I can get a better idea of its function?
Old August 26th, 2015, 09:47   #8
Abacus
That helpful B4 guy
Abacus's Avatar
Wow, that is nice of you to do that, thanks!
It's right between the 3 & 4 injectors, at the end of the upper radiator hose.
Here is the old one with the new one in place.
A different perspective:
And this is where is mounts on the head, just a flat surface.
Old August 26th, 2015, 09:54   #9
thechoochlyman
TDI(s): 97 Passat
Ah, it was right in front of me the whole time and I couldn't see it!
I think this could be done easily enough. May have to do some welding for the extra ports, but overall I think it's entirely possible. I'll be able to do more critical thinking about it once a part arrives that I can examine more closely.
Old August 26th, 2015, 09:57   #10
thechoochlyman
TDI(s): 97 Passat
It appears to have four ports:
Straight-through hole for the main radiator hose. That's easy, just bore a hole through the middle.
I'll probably drill and tap a 1/8 NPT hole for the coolant return line, as it's not an exceptionally critical feature.
The Lower hose and Sensor may require machined and welded bungs in order to work properly.
Old August 26th, 2015, 10:02   #11
Abacus
That helpful B4 guy
Abacus's Avatar
I can send you off the bad one now so you can formulate an attack plan and as soon as an OEM one arrives I'll send it off as well. I'd be curious to see the dimension differences.
Old August 26th, 2015, 10:04   #12
Abacus
That helpful B4 guy
Abacus's Avatar
I would think the lower hose could be oriented at a 90 angle and moved further out to fit better. The sensor bung would require some thought though.
Old August 26th, 2015, 10:20   #13
thechoochlyman
TDI(s): 97 Passat
That would be fine by me, sir. Really the only important thing will be O-ring size and bolt spacing. Everything else is kinda gonna be modified by me for easy of machining. Stand by for a shipping address.
Perhaps so, but from what I'm seeing it would probably put a kink in the hose to alter things very much. You know more about these cars than I do, though. haha
I don't think the sensor will be too much of a hard time. It will just need to be bored to a proper diameter to snugly fit the O-ring and have some slots milled in the side to accept the retaining clip.
Old August 26th, 2015, 10:48   #14
Abacus
That helpful B4 guy
Abacus's Avatar
I'm not machinist and don't play one on TV, so I have no concept of how you do things on that level. I'm just saying there is some variability with some of the connections that may make your job easier.
Old August 26th, 2015, 10:54   #15
thechoochlyman
TDI(s): 97 Passat
Sure, I gotcha. But that's good to know - I'll definitely have to make some design modifications in order to machine it more easily.
FS/ ahu 1z o2a shift tower short shift new parts muuurph Private TDI Items for Sale/Wanted 1 May 21st, 2015 10:57
WTB 1z/ahu ccv puck kooyajerms Private TDI Items for Sale/Wanted 3 November 16th, 2011 10:07
billet lightweight crank/ps pulley combo for the AAZ, AHU, and 1Z engines alexi TDI Power Enhancements 6 November 1st, 2011 07:21
Custom Billet Ve Race Cam Group Buy shortysclimbin Vendor & GroupBuy items for sale 101 April 21st, 2011 15:22
Dichroic glass emblems, gear shift knobs and custom work available also! Getta_TDI Private TDI Items for Sale/Wanted 3 May 24th, 2002 00:12
Page generated in 0.19529 seconds with 10 queries
[Output: 147.45 Kb. compressed to 124.71 Kb. by saving 22.74 Kb. (15.42%)]
