Old March 7th, 2016, 07:31   #46
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Originally Posted by turbovan+tdi View Post
Damn, did not expect that, shipping would be $130,
You would think shipping rates would fall with the price of fuel - wouldn't you? Fenders are light, but bulky. Thank you very much for checking for me. I will make some calls to places that show they have one on car-part.com. I just hate driving an hour to find out it's rusty/dented/wrong color, etc.
Originally Posted by where2 View Post
Time for a vacation in Florida, there are 3 different year MkIV Silver Jettas in my local u-pull-n-pay. They charge ~$50 per fender. For bulky items, check rates using the bus lines. One of the boating forums I used to frequent used "under the bus" shipping frequently for larger lightweight items that common carriers charge dearly for.
If I wasn't already running a rather full load on my trailer to Maine this summer, I'd offer fender delivery in return for a tank of #2. Do you cut the sealant attachment between the fender and the body with a wire?
Good idea... I will be doing some camping upstate soon... I will expand my search area to within driving distance of any vacation I take. My parents were just in Florida too... I should see if there are any in the Myrtle Beach area for them to bring home... hmmm...
I pull them off and carefully pry at that area with the sealer.
Same here - the sealer doesn't seem too hard to separate. I don't worry about reapplying because from the large amount of sand/mud behind the liners - they aren't sealed all that well anyway!
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old June 7th, 2016, 04:17   #47
gforce1108
gforce1108's Avatar
Buying a house and moving has really slowed down my work on this car! But - I did pick up a really nice, clean matching fender over the weekend and got it installed. Now that it's assembled, I'll get it inspected and then tear into the DMF and suspension to get it fully fixed up.
*hopefully this link works**
Old June 7th, 2016, 10:28   #48
deejaaa
deejaaa's Avatar
Fuel Economy: 59 latest mpg
looks good.
RIP Grams, 6-27-16
Originally Posted by stamar View Post
I am a tdi expert now.
A wise man told me "Cut Twice, Measure Nunce."
deejaaa is offline   Reply With Quote
Old June 7th, 2016, 15:57   #49
UhOh
UhOh's Avatar
I am trying to locate a driver's side (left) Mojave Beige fender for a wagon. And then there's my Golf... (hard to find nice green Golf fenders).
Old June 8th, 2016, 04:13   #50
gforce1108
gforce1108's Avatar
The wagon and sedan use the same fender even through the parts interchange lists them separate. www.car-part.com does is a good starting point (you'll have to search twice for both sedan and wagon), but craigslist and the vwvortex forums seem to be more useful. Try both the regional and generic MKIV Jetta/Golf classifieds. That were I found all the front end parts for this car.
Old June 8th, 2016, 10:59   #51
turbovan+tdi
turbovan+tdi's Avatar
gforce, car looks familiar,
Uhoh, I'll see what's around here, we have a few VW sources. If you need something painted, my friend does a good job for reasonable rates.
Old June 8th, 2016, 15:49   #52
UhOh
UhOh's Avatar
Yeah, I might take you up on that for the daughter's wagon.
Old June 8th, 2016, 16:00   #53
turbovan+tdi
I'll post up pics of the Golf front end he painted for my 04 blue Wagon. Its not perfect but its pretty good.
Old February 28th, 2018, 05:48   #54
gforce1108
gforce1108's Avatar
I guess I'm very slow at updating! I bought a house in 2016, built a garage in 2017 and had to run back and forth to where I was set up in a garage. But now that I'm almost settled in the new garage - I have the wagon mostly completed. With the pricing I've seen recently on these - it may end up being a good thing it took me so long! Two tires kept loosing air - took them in to have the beads cleaned and one stem replaced.
It had a check engine light for MAF out of range. VCDS showed no activity and stuck at 550, even unplugged. I swapped in a good MAF out of my parts Beetle and all is good with that, but I've had a couple of overboost / limp mode issues.
I drove it to work for the first time yesterday. When it's not in limp mode it pulls hard and runs nicely. Gotta check that VNT again and change that one last vacuum line between the N75 and the turbo (have spare actuator and N75).
I need to document what I did anyway for when I sell it so here it goes:
New from idparts:
ball joints
struts / mounts
shocks
sway bushings
tie rod ends
clutch/dmf/pivot ball/clip/throw out arm/hardware
shift tower rebuilt parts and bushings
upper clutch switch (was causing a RPM flare when shifting)
brake switch (wasn't bad - had multiple blown bulbs!)
trans fluid
engine cover bolt 'caps'
LCAs (audi TT version)
Cabin filter
I have fuel and oil filters to install.
New tail lights from ECS
good used Bosch MAF pulled from parts car, purchased from idparts
Replaced all vacuum lines
Old February 28th, 2018, 12:04   #55
Nevada_TDI
gforce, how difficult is it to replace the LCA's if a person doesn't own a rattle wrench or a large set of tools?
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old February 28th, 2018, 18:29   #56
UhOh
UhOh's Avatar
An air impact gun helps but isn't necessary. Not sure if it's better to do the front bolts with or without (air impact): that issue where the nut breaks loose inside (I've not run across that problem with the three cars I've done). That said, it can be a real battle on the passenger side. If I had a choice, though, I'd for sure want to use an impact. Oh! an electric impact would work as well (not real expensive; might be able to just rent).
Old February 28th, 2018, 20:24   #57
Genesis
Fuel Economy: 53/48/42
Depends on where the car has been.
Down here in the south (no salt on roads!) things come apart without any special care you'd think never would. Like rear diff covers on a 2002 truck that has been used to launch boats -- in salt water!
Same thing, up north? Hahahaha... get out the chisels and, for larger bolts, the AIR CHISELS!
Genesis is offline   Reply With Quote
Old February 28th, 2018, 21:46   #58
UhOh
UhOh's Avatar
Torches!
Nevada is probably OK there.
Old March 1st, 2018, 06:07   #59
gforce1108
gforce1108's Avatar
The other replies have great info but I'll add my own $.02 I've changed many of these over the years. I do use an impact, but with a little penetrating oil both bolts should come out easily - even here in the northeast. I do not remove the 3 bolts from the ball joint. I separate the ball joint from the hub so I don't affect the alignment. Once the LCA is out, I rip the old rubber center out of the large bushing and then use a hacksaw to cut through the outer ring. They pop right out. I clean the surfaces and had been installing them with a hammer/vice and a large socket, but now I have a 20ton press. I only ever changed the front bushing on one set and found it to be unnecessary - I only do the large ones and replace with TT units.
I've been lucky as well with that nut staying in place, but it's always in the back of my head!
VW did a great job with whatever rust/corrosion prevention they used. I get all sorts of rusted/rotted cars in my shop, but very few problems with hardware on VWs (fenders, etc. rust like crazy though!). I do have a 80 gallon compressor and a 3/4" impact if needed
Torches!
Wish I had torches One day....
Old March 6th, 2018, 19:18   #60
gforce1108
gforce1108's Avatar
I did the oil change yesterday along with the trans fluid (knew I ordered it, couldn't remember if I had changed it after fixing the shift tower). This thread will have to be my reminder! I bought new Bosch Icon wipers for my 04 and pulled the good used ones to install on this car and then noticed there were a pair sitting on the back seat (from when I did the exact same thing last year and never put them on!). Too many projects at once...
I replaced the one last vacuum line from the N75 to the turbo. VNT moves free. Ran N75 output test and the VNT cycles as it should. Didn't have my vacuum pump here to test if it's opening/closing at the right vacuum levels. I'll check that tomorrow (snow day!) but doubt I'll get any logs as there is a super duty with no alternator blocking that bay... Odd that I'm getting overboost if the VNT is operating correctly.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
KyleMillione, KrashDH
Fishing: f/s 03 Gretta Wagon 5sp 212k sswartz06 Private TDI Items for Sale/Wanted 0 June 28th, 2013 15:47
FS: EGR valve from '03 Jetta TDI Wagon (ALH, 5sp) Sideoiler Private TDI Items for Sale/Wanted 5 July 28th, 2011 15:11
FS: '03 Jetta TDI Wagon 5sp Transmission Selector Tower/Lever with Attachments Sideoiler Private TDI Items for Sale/Wanted 10 April 5th, 2011 20:03
'03 Jetta TDI GLS wagon 5sp. T. Red lilredjetdiwagon TDI Cars for Sale/Wanted 8 May 31st, 2007 18:07
03 Jetta Wagon TDI with 5sp on the way, getting cold feet, Help! mt_mapper TDI 101 43 November 18th, 2002 21:41
Page generated in 0.14595 seconds with 10 queries
[Output: 145.13 Kb. compressed to 122.88 Kb. by saving 22.25 Kb. (15.33%)]
