Old January 19th, 2017, 17:16   #31
3L3M3NT
3L3M3NT's Avatar
Originally Posted by sardo_67 View Post
ever think about selling it? I am looking for an already O2M swapped MK4
It had crossed my mind a while back when I was dealing with my pain management issues, but now that I have a pain pump implanted to help manage my pain. I'm actually looking forward to getting the car back on the road and going to a few track days to see what it can really do when there's no speed limit.
The car is actually at greengeeker's shop right now getting things sorted out for this spring.
Granted for the right price everything's for sale feel free to send me a pm if you're serious.
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old January 29th, 2017, 22:23   #32
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Default The saga continues
When I saw Eric's car at 2016 TDIFEST with very little progress having been made I told him to haul it over to my shop and we could get it finally finished. Having driven my TDI Ranger over to Sturgeon Bay I was ready to rent a trailer and just haul it back but we decided to wait.
Anyway, she's now at my place getting all the little odds and ends fixed so we can retune the car with a Malone tune.
The wiring is pretty rough and needed quite a bit of attention...
Once I'm done with that I'll need to address this ill-fitting charge air pipe kit which seems to be rubbing just about anywhere there is a chance to rub:
More to come.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old February 6th, 2017, 23:07   #33
greengeeker
Default wiring fun
Well besides fixing the mess under the hood my first order of business was to figure out why the N75 didn't have power to it. I tracked it down and the fuel pump relay wasn't being triggered (which sends power to a number of fuses and eventually to the N75). Whoever wired the swap initially knew this since they did several things to unsuccessfully get around it... They wired around fuse 34 (literal cut wires at the fuse block and strung new wires all over the car) and installed a new fuel pump relay in the back of the car going to what used to be an added in fuel pump (now missing).
Well to figure out the wiring I had to go back to the wiring diagrams and really understand how the BEW and BJS (3.2 VR6) connectors compared:
Surprisingly there is quite a bit in common between the the two harnesses with the only major differences in how the fuel pump and/or power relays are triggered.
Here are the two side by side with a color coded column between the two denoting where they are same (green cell) and where they are different (orange). Should be noted that for a few of the different rows, it doesn't matter since they aren't using the same wires for two different purposes.
After digging around and doing some research I figured out that I could install the same power relay(100) in place of the smart fuel pump relay (409) and it would operate perfectly.
So I guess that I've found out is that to swap a BEW into a mk4 R32, all you need to do is swap over the engine bay harnesses, plug them into the same color connectors and replace the fuel pump relay with a dumb relay.
Here are some shots I grabbed during the fun which I thought were pretty cool and as an engineer I can appreciate the amount of engineering hours went into the design of this part.
- Nick -
Old February 7th, 2017, 18:10   #34
Shenandoah
Greengeeker,
Excellent photos! I'm doing an ALH swap in to an Audi TT. I tried to get the fuel pump relay to act like the 109 on the VW diesels, but it just wouldn't trigger to turn on the 32, 34, and 43 fuses. I ended up wiring the 109 with the Blue wire going to the 87f Terminal and the Red wire going to 30. If I knew the 100 relay worked, I would have tried that! Thanks for the pictures of the open Micro Electronic. I was wonder how that looked inside.
Eric
Seven TDIs: 2005 Jetta Wagon; 2005 New Beetle; 2004 Jetta; 2002 Golf; 2002 Jetta Wagon; 2000 Audi TT; 1999 New Beetle
Three Gas: 2000 Golf; 2002 Jetta; 2003 Jetta
Four "parts" cars: 2000 Jetta; 2000 Beetle; 2002 Golf (two of them)
Shenandoah is offline   Reply With Quote
Old February 8th, 2017, 08:27   #35
greengeeker
Hey Eric,
Yeah, the 100 relay works but it truly is a dumb relay....meaning as long as the key switch is in the power position (engine running or not) it will be passing power to those fuses. The implication of this is that the fuel pump will run all the time - normal operation as you know has the pump run only for a few seconds with the engine not running. I can go back and rewire the trigger for it and may do that so that the ecu still commands its operation.
- Nick -
Old April 13th, 2017, 21:31   #36
greengeeker
Lots going on with the car. Had to spend some time getting this aftermarket bumper to fit somewhat well. Then dropped it off with a body shop to fine tune the fit, mount and paint.
Needed to get that done so I could drop the car off for exhaust. Then we can get going on the tune.
Fuel fill opening has been opened up and now working on the fuel sender(s). Apparently the car is only able to draw from one of the sumps and the fuel gauge is terribly inaccurate.
Gauge wiring is all back together. Another interesting endeavor where gauges were cross wires (three wires for a boost gauge...two of them going to the boost gauge and one of them going to a oil pressure gauge) and thermocouples were in the wrong pins for the gauge. That and it was an absolute rat's nest behind the gauges....untidy wiring stresses me out! Next is to find out if I can get the oil pressure and thermocouple adapter in there with the routing of the a/c lines and radiator hoses trying to occupy the same space. I'll snap some pictures of the gauge installation once it is all complete.
Rubbing boost hoses/pipes are fitting properly where I have room to make a difference. On the front of the motor it is just so tight there isn't much I can do to avoid the pipe from contacting something.
- Nick -
Old April 14th, 2017, 22:47   #37
greengeeker
And off to the exhaust shop.
More updates next week.
- Nick -
Old October 21st, 2017, 22:19   #38
greengeeker
So. Seriously lacking on the update front.
Here are a couple pictures of the exhaust being fabricated. Ended up using a vband clamp on the end of the downpipe and extending the 2.5" straight back to the rear subframe. Once past this expanded to 3" into an Aero Turbine series muffler.
Eric had a really good plan on the tailpipe to achieve two things 1) no drone in the cabin at cruising speeds 2) no soot accumulation on the rear of the car. #2 is best achieved by having some sort of turndown tip. The car originally had an R32-style twin tip setup which exited flush with the rear bumper. Well apparently this resulted in a completely sooted rear hatch in short order. The major drawback to a turndown tip is you often risk inducing a drone inside the car. To alleviate this the tip needs to be turned so it isn't parallel with the ground. You'll see in one of the pictures the tip has been rotated around 30deg to avoid drone.
I don't know how to embed youtube videos (would love it if someone could help me out here!)
Car at idle:
https://youtu.be/22fMMjfYr4I
Doing a WOT pull:
https://youtu.be/RzlbqTNdrdw
It does have a really nice growl as the vanes open but it is actually really tame when you are just driving normal.
Here is a picture showing the rear hatch after having not been washed after MANY tuning sessions (ie WOT pulls on a closed course )
- Nick -
Old October 21st, 2017, 22:37   #39
greengeeker
While this car is a compilation of OEM components when it comes to installing just about anything onto the car you end up having to modify or fabricate many things to get them to fit.
One such example is the skidplate. While this might normally take <1hr to install a panzer plate on a normal car, I had to fabricate a new mount for the right side since the FMIC had the pipe trying to occupy the same space as all the available mounts currently offered by the many vendors.
The car also has an 034 poly dogbone setup which also meant the skid plate did not clear that bracket without some delrin bushings on the rear of the plate.
- Nick -
Old October 21st, 2017, 22:59   #40
greengeeker
Default Tuning
As can be seen in the video posted earlier, with the help of jfettig I installed a dual gauge setup so we could monitor both boost and drive pressures. Using this, I had to make several stop screw adjustments as the car was driving like a BRM does with a worn vane mechanism (big hesitation off the line, huge smoke cloud and then she goes). Anyway, tons of tons of logs were done with many iterations of tune tried to work out the MAF-based smoke maps. (the video is showing a very early tune...final tune and stop screw adjustment were much better)
Oh, stop screw adjustments are really fun on a 4Motion car BTW. As you can see I had to remove the axle and swing the wheel assembly out to gain access to the stop screw and actuator.
I'll take the time to mention that owning a car this heavily modified will almost always guarantee you need to tinker with something...in other words, for the fun you are trading off some level of reliability. The car has left me or jfettig stranded twice and almost a 3rd time.
1) Because of the pushed back radiator and ill-fitting hoses the radiator fan eventually wore through a radiator hose, draining all the coolant.
2) I went for a test drive after installing the fluidamper to see if I could notice any difference in the vibrations. Well after only SIX miles with the damper installed (using the bolts provided, torqued per instructions) I started hearing a really gnarly clanking which was rpm-dependent. I immediately thought the worst and thought rod bearing. I popped the hood and noticed the damper was wobbling badly. I was luckily very near an Oreillys and was able to purchase the tools necessary to tighten the two bolts still remaining. Some longer bolts, loctite and lock washers and it hasn't come loose since.
3) With the front and rear locked differentials every bit of power is put to the ground. I haven't been able to get the tires to slip whatsoever. Well when testing out a particularly strong tune I noticed a very sudden change in engine vibration at certain speeds. I quickly limped back to the shop to find that the the car had ripped the threads out of the engine mount. Helicoiled and she seems to be holding strong.
I'm VERY HAPPY this occurred AFTER I had installed the Panzer plate. Another benefit of a skid plate...prevents your engine from dropping out of the engine bay.
- Nick -
Old October 21st, 2017, 23:11   #41
greengeeker
Default Misc
A critical step that needed to be completed was hood pins for the non-OEM, CF hood.
Since you are locking down the front of the hood with very little adjustment step 1 is to align your hood as perfectly as you can before starting! I nearly missed this step but caught myself before drilling the first hole (measure eight times, cut once applies here).
Eric also had me install some incredibly comfortable race seats and harnesses. I never imagined these seats would be as comfortable for someone bigger than a 32" waist but you can drive all day long in these Recaros. Worth the money IMO.
- Nick -
Old October 21st, 2017, 23:20   #42
greengeeker
Default Misc, 2
Well, I'm not covering everything that I did with the car. That was captured in very extensive build notes sheet shared with Eric. It was a very cool experience working on this car. It gave me some insight into the upper levels of TDI performance...how much $ it takes to get there, how you have to modify each and every subsystem of the car to stand up to the rigors, and how much you rely on a small circle of capable people to keep a car like this in tip top shape. And even then you have to be prepared to shell out big $ when something breaks.
I hope Eric enjoys the car and gets it out to as many track days and GTGs as possible.
- Nick -
Old February 7th, 2018, 20:36   #43
3L3M3NT
3L3M3NT's Avatar
My apologize for not updating this thread sooner
Photobucket embedded image fix inserted 2/7/2018.
Fix if you're using Chrome: https://chrome.google.com/webstore/d...giikdkpmcpkaon
Firefox Fix: https://addons.mozilla.org/en-US/fir...t-fix/?src=api
Anywho, on with the updates.
With the help of greengeeker and a couple of my friends were able to get the car back to me in Sturgeon Bay at the end of September and needless to say they all really enjoyed driving the car and let me know that if I needed a place to store it for the winter they were more than happy. For some reason I don't think the car would stay put if I left them with the keys.
I snapped a few pictures of it, since it looked 10x better than when it was dropped off by greengeeker a little less than a year ago.
I was glad I got the car back when I did, since 2 weeks later I had everything setup for a track day at Road America to see how it could do with no speed limit and in a controlled environment.
Sadly the forecast called for rain starting around 11am and since they run rain or shine we made the trip. We got to the track around 7:30 with a heavy fog in the air, but no rain yet.
My driver went to the drivers meeting at 8 and unfortunately had to sit through what had to be the longest drivers meeting ever, so by the time he got out around 8:45 we still had to remove all the loose items from the car, get strapped in, and put our safety gear on. With it being our first time taking the car to the track things took longer than they should have so we ended up missing our 1st session with the intermediate group. We even tried to talk our way into the 1st session of the beginner group, just to get a feel for the car, but that fell on deaf ears and they sent us back to the pits to wait for the 2nd session.
While waiting for the 2nd session my dad and a friend showed up to help with whatever we needed. So we start getting ready for the 2nd session when it turns from a heavy fog to a light drizzle. My driver and I are thinking great...we're taking the car out for it's first laps on the track and the track is wet. The first couple of laps we took it easy to get a feel for things, as my driver got more comfortable we were passing cars here and there on the straight aways with the track going from damp to wet. For those familiar with Road America, on the carousel we had the back end step out on us a couple times while we were out there.
Session 3 had rain coming down the entire 20 minutes we were out there.
By session 4 we pretty much had the track to ourselves, since over half the guys there had called it quits for the day. The track was still quite wet when we were out there and then half way through we lost power, which I thought at the time was due to oil pressure, since the McNally gauge read ZERO! Come to find out that I forgot that the gauge wasn't hooked up, so it wasn't the lack of oil that caused our loss in power, but the MAP sensor wires had the insulation melted off and were grounding out. The MAP sensor wires were ran too close to the intake manifold, so they are getting zip-tied to the strut brace to keep them away from the heat.
Besides the wires getting moved, the car is getting a roll cage added at the moment to help save us if the car were to ever get in a roll over.
With the rain blocking the lens at times the videos aren't the best, but here they are.
Looking Forward
https://www.youtube.com/watch?v=4fN6YUon5qI&t=1s
https://www.youtube.com/watch?v=LK3nxew5D7E
https://www.youtube.com/watch?v=Yoz-EItfchI&t=1s
The looking back view is going to be less than ideal at times, but it's some great shots of us rolling coal.
https://www.youtube.com/watch?v=BrEXrcuuTtA&t=2s
https://www.youtube.com/watch?v=ylpst6qxq-Y&t=3s
Again sorry for the delayed post, but hopefully in the future I'll do a better job of posting updates on the car.
Firefox fix
RTDI Build Thread
Old February 7th, 2018, 21:01   #44
greengeeker
Man...looks like fun. Wish I could have done a lap or two.
- Nick -
Old February 7th, 2018, 21:14   #45
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Cool stuff Eric - having RA to yourself, even in the rain, is quite an opportunity.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
RTDI Part 2 3L3M3NT Golf TDI Picture Gallery 111 November 28th, 2018 10:09
Full on RTDI build up. mtbr297 TDI Conversions 74 June 9th, 2015 06:43
Broke a part inside injector fuel pump. Can't find where to buy new part. Any ideas? 03TDIJettaWagon VW MKIV-A4 TDIs (VE and PD) 7 October 26th, 2014 12:06
2006 UK TDI Road Trip Part I: Wales Part 2 PlaneCrazy Road Trips 4 August 29th, 2006 19:19
2006 UK TDI Road Trip-Part I: Wales part 1 PlaneCrazy Road Trips 0 August 15th, 2006 19:39
Page generated in 0.20499 seconds with 10 queries
[Output: 162.74 Kb. compressed to 140.47 Kb. by saving 22.27 Kb. (13.68%)]
