Old February 23rd, 2016, 06:21   #16
Pry_P
Long time no update on this. I've been working on it slowly since the end of summer.
I got the cab laying on the chassis and did some quick test drive around the yard. Very happy the way it ran
Meanwhile I scored this Samurai for 150$. I couldn't let it go.
It is still in good running condition, But I will part it out. Notice the custom Plywood top! It is also nicely covered with roofing shingles. Seller said it's 25 year rated !!!
Decided I would put the samurai Transfer-Case and Axles on the LJ. Will be tougher than the tiny LJ Transfer case and parts will be easier to find in the future. I also gain front Discs instead of drums. That said, I have to ditch out the custom drive shafts, T-case support & steering rods I made last summer and fabricate new ones again. This will be later this spring.
Lately I have been working on fixing rust and holes in the cab.
Look what kind of rust I am faced with... Pictures even make is look better than reality..!! Have to fabricate every body panel from scratch. Replacement Panels are VERY expensive and hard to get. Rust also goes beyond these available replacement panels.
Passenger Side Floor:
Driver side Floor cut, exposing rust in inner rocker panel:
Passenger Side front cab corner/floor:
Passenger Side Floor & outer rocker panel removed, ready for new sheetmetal:
Both new floors cut, bent and welded, made from 14ga checker plate.
Viewed from inside:
This is the front fenders and grille. I will be able to re-use the grille with some time and effort. The outer fenders I got this Idea from a guy in Edmonton. I bought a 60$ 16ga fender for a tandem trailer, cut it in half to have both sides.
With some trimming it will be 95% close to the shape of the original fenders.
Will need to repair existing / fabricate new inner fenders.
Still a lot of work to do. The worst is bodywork. Swapping Samurai Axle and T-case should go along very easy.
-2005 Mercedes E320 CDI
-1993 1st gen Dodge W250, Cummins, 5 speed.
-1981 Suzuki LJ81 TDI in progress
Pry_P is offline   Reply With Quote
Old February 23rd, 2016, 17:51   #17
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Nice job on the floors...
with the new front axle,you won't have to worry about the oil pan any more.
1.9ZOOK is offline   Reply With Quote
Old February 23rd, 2016, 18:16   #18
samuraitd
samuraitd's Avatar
If you don't mind me asking, how tall are you? It looks to me like anybody over 5'8"ish would be too tall to drive it. But it sure is awesome!
1986 Samurai AHU MTDI swapped, stretched, built
samuraitd is offline   Reply With Quote
Old February 24th, 2016, 06:46   #19
Pry_P
Yes of course that was another advantage. I even might be able to lower the engine by 1" or 2" and forget the body lift for the hood to clear the intake.
I'm around 6' and yes I am a bit too tall to be comfortable in it. In the summer it's ok, but when I was plowing with it during the winter, it was a challenge to get in and out with boots and winter suit.
Old September 1st, 2016, 09:16   #20
samuraitd
samuraitd's Avatar
Any updates?
Old September 5th, 2016, 10:55   #21
Pry_P
Any updates?
Nothing new this summer.
Ordered new front grill, windshield and window gaskets, ect.
Building a new 30x42 shop right now. Will continue to work on the truck this winter, when new shop will be all set and warm !
Old February 22nd, 2018, 04:12   #22
Pry_P
I re-started to work on this project 3 weeks ago. The new shop is built and all set. Here are some updates.
I have no picture of that, but last year I installed the samurai transfer case with a custom support, and samurai axles.
I tried to set up a little sandblast tent, but still too dusty inside the shop. I moved sandblasting to an outdoor anclosed trailer. Installed a 10k 2 post lift in the new shop. A joy to work with.
I finalized the cab mounts. For bushings, I used Dodge 1st gen cummins transmission tail bushings.
I installed the new fender, made from trailer fenders..
With a lot of trimming, the fit is perfect.
Old March 1st, 2018, 17:51   #23
A-man930
Subscribed. Cool truck!
A-man930 is offline   Reply With Quote
1981 Rabbit Truck TDI (afn) annieneff TDI Conversions 68 October 30th, 2015 09:37
feeler: MK1 81 AHU TDI CJansen TDI Cars for Sale/Wanted 3 September 9th, 2013 13:15
1981 Rabbit Pickup Truck--> Quattro TDI ALH Freestyle72 TDI Conversions 13 May 29th, 2013 23:20
1981 rabbit truck with a BRM tdi cam.tdi TDI Conversions 6 June 25th, 2011 19:29
tdi into 81 rabbit diesel (truck)? 8418 VW MKIV-A4 TDIs (VE and PD) 2 November 25th, 2001 00:55
Page generated in 0.14970 seconds with 10 queries
[Output: 90.63 Kb. compressed to 78.38 Kb. by saving 12.25 Kb. (13.51%)]
