Old June 16th, 2015, 20:18   #1
Pry_P
Default Suzuki LJ-81, 1981 truck / TDI AHU
Here is my first build thread. I've owned this suzuki LJ81 pickup truck for 2 years now and i've been contemplated doing a frame-off restoration, along with a diesel swap. Well I started last week. I used this truck only off-road and for plowing snow, but I want to put it back on the road.
This little 4x4 is quite rare. The ancestor of the Samurai. It came from factory with a 42hp 4 cyl 4 stroke 800cc mated to a 4 speed trans. previous engines used in those trucks were 2 strokes. 2 and 3 cyl.
I got a AHU tdi for cheap, 505 000km. I am using an ACME adapter kit to adapt the tdi to a samurai 5 speed transmission and for engine supports.
I will have to work supports a bit, since this kit is designed for the samurai and not for the LJ. So far, a very nice kit. it makes things easier.
Truck will need a spring over axle lift for the oil pan to clear the centered front diff.
I found a 1.9td AAZ fuel pump at pick-a-part kind of scrapyard. 6.50$ +tx... I think it was a good deal.
Bolted that pump to the tdi. I heard different theories about using a straight TD pump on a tdi. Some say it wont work and needs the tdi internals, some say it works fine but not a powerhouse. I am not looking to go over stock tdi power either. I will try to bench start the engine later this week and see how it goes. I am waiting for a sidekick 1.6 starter.
The turbo is a T2 from the same 1.9TD AAZ
I must use an angled oil filter housing from a 1.8T Passat for the filter to clear the left engine mount.
Will need to adapt another steering box. The stock one is in the way of the bigger samurai transmission.
The biggest part of this project will be bodywork. Fabricating new floors, Fenders, ect.
Here is how it looked as of last week.
Engine/transmission bolted
Bed is removed, Body ready to be removed from frame.
Pry_P is offline   Reply With Quote
Old June 16th, 2015, 20:23   #2
Pry_P
Frame with old engine/transmission still
Cab ready for rust removal/body work
I will do my best to keep this thread alive for the lenght of the project.
Old June 16th, 2015, 20:37   #3
Abacus
That helpful B4 guy
Abacus's Avatar
I hate you.
I'd give just about anything for an LJ81 pickup down here.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old June 16th, 2015, 21:51   #4
samuraitd
samuraitd's Avatar
Finally!!!! I've been wanting to see a diesel LJ swap forever! I've been trying to pick up two LJ20v's for a couple years now, but I just can't seem to strike a deal with the guy
1986 Samurai AHU MTDI swapped, stretched, built
samuraitd is offline   Reply With Quote
Old June 17th, 2015, 05:38   #5
Rockwell
Rockwell's Avatar
I would so love to have something like this!
Abacus, not an LJ, but there is a Samurai project on Craigslist:
http://nh.craigslist.org/cto/5037419276.html
2003 Jetta TDI - 17/22 *RIP*
1986 Toyota pickup - VW 1.6TD swap, Giles IP, GTD nozzles. Soon to be TDI
2011 BMW 335d sport *sold*
1996 B4 Passat
Rockwell is offline   Reply With Quote
Old June 17th, 2015, 05:49   #6
Abacus
That helpful B4 guy
Abacus's Avatar
Wow, that's cheap considering what that adapter costs. I'd have plenty of time to finish it since I'd be divorced if I even broached the subject.
My old Zuk is still going strong locally, although it's sporting different tires and paint job. I do miss it occasionally but have to schedule time for myself so I know I don't have the time for something like that anymore.
I wish we had the LJ series down here, or at last be able to find a decent SJ410. The Canadians and Europeans got all the cool stuff.
Old June 17th, 2015, 18:35   #7
lews930
TDI(s): 96 passat
Fuel Economy: 47
That's what those trucks are called.
Awesome!
Too many diesels! But I love em all
lews930 is offline   Reply With Quote
Old June 17th, 2015, 19:44   #8
Pry_P
After a lot of injector bleeding, i got the engine to start hanging under the hoist
Happy to see that the bare 1.9TD pump is able to at least run the tdi.
-2005 Mercedes E320 CDI
-1993 1st gen Dodge W250, Cummins, 5 speed.
-1981 Suzuki LJ81 TDI in progress
Old June 17th, 2015, 20:34   #9
Bczuk
Bczuk's Avatar
Awesome
85 Samurai- ALH tdi equipped
2001 Jetta- 1852 Turbo, PP764, PD150 tip/intake, 2.5" turbo back exhaust, upgraded intercooler, Kerma piping, Malone tuned with coilovers and 18s
Bczuk is offline   Reply With Quote
Old June 17th, 2015, 21:39   #10
Whitbread
Whitbread's Avatar
TDI(s): Several
Get a land rover 300 TDI pump from england and never look back. Give Ryanp/darkside a shout. They're less than $200 and have an 11mm head.
Freaking awesome truck BTW.
02 Jetta TDI
Whitbread Performance Innovations
-Full TDI maintenance, performance and custom fabrication services. 248-755-8118, 10AM-5PM EST M-F. Please email or call only for business inquiries. PM's are not for business communication.
Whitbread is offline   Reply With Quote
Old June 18th, 2015, 05:09   #11
Pry_P
Thanks ! I will try to keep it this way for now, but might give it a try later. I want to concentrate $$ on frame and body restauration.
Old June 20th, 2015, 16:38   #12
samuraitd
samuraitd's Avatar
You should join here and throw up a thread as well. Lots of diesel zuki swaps here.
http://bbs.zuwharrie.com/content?board=48.0
Old August 11th, 2015, 15:13   #13
Pry_P
Here are some updates
Got the engine installed on the frame, along with other stuff over the past few weeks.
I tack weld everything for now. When the truck will drive on its own power and everything run and drive as it should, I will then strip everything down, finish welding, blast and paint before final re-assembly.
I used dodge 318 engine mounts. had to cut and angle the stock LJ lower mount bracket to corect some angle.
Did a spring over axle lift. In stock form, the oil pan was sitting on the diff. pumpkin.
To clear the piping from turbo to intake, The cab will need to be lifted 2"
I had to completely redo the steering system. The original steering box was in the way of the larger samurai transmission. I used a Toyota 2WD power steering box mounted forward and on the outside and converted to crossover steering, doing all custom steering rods from 1" bar.
I used the old suzuki engine mount and made a custom tranny support.
Had to lower and relocate the transfer case back. Mounted it on a plate welded between frame tubes. Was able to use the rear driveshaft as-is. I shorten the center driveshaft, and add lenght to the front one.
I use a ''performance'' aluminium radiator for honda civic. It is small enough to fit well. Did a custom support for it mounted to the frame.
I made a bumper from 2X5 HSS tube, reinforced the front part of the frame with 3/16" plate, and made new front shackle supports from square tubes.
here are some pictures:
Front end and radiator.
New steering links. not shown on pic, but the upper drag link is now bent to clear the oil pan.
Transmission tail support
Toyota steering box installed
Custom knuckle adapter for crossover steering
Picture before Transfercase and steering box new mounts finished.
I used a passat 1.8T oil filter housing. It is angled, and the filter now clear the frame and engine support.
Old August 14th, 2015, 16:20   #14
Bczuk
Bczuk's Avatar
Looks great. Its going to be an awesome little zuk
Old December 20th, 2015, 13:02   #15
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Nice!
Love those trucks,will be watching.
Glad you went with the toyota steering box,flat pitman arms are available
if the angled one hits the spring.
1.9ZOOK is offline   Reply With Quote
1981 Rabbit Truck TDI (afn) annieneff TDI Conversions 68 October 30th, 2015 10:37
feeler: MK1 81 AHU TDI CJansen TDI Cars for Sale/Wanted 3 September 9th, 2013 14:15
1981 Rabbit Pickup Truck--> Quattro TDI ALH Freestyle72 TDI Conversions 13 May 30th, 2013 00:20
1981 rabbit truck with a BRM tdi cam.tdi TDI Conversions 6 June 25th, 2011 20:29
tdi into 81 rabbit diesel (truck)? 8418 VW MKIV-A4 TDIs (VE and PD) 2 November 25th, 2001 01:55
Page generated in 0.18759 seconds with 10 queries
[Output: 132.35 Kb. compressed to 110.42 Kb. by saving 21.93 Kb. (16.57%)]
