aneblanc
I was away for 11 months.
The cars hadn't been used and had been sitting under cover but not in a dry place.
I drove the '05 Golf and broke the front coil spring after a 500m. Also the brake calipers are seized. But I can limp to the garage to have that fixed.
Then I drove 200m with the '10 Golf Wagon and also broke the front coil spring.
I wonder why after sitting for a year the springs are brittle and break like glass. The lower end of the coil is sort of sitting between the shock and the vertical rod with a rubber bushing.
I am wondering if there is a way to turn the coil so it doesn't damage the rubber bushing because I'd rather like to drive to the garage 20km away.
The last turn of the coil is sitting askew on the side of the bottom receiving cup.
There is also more trouble: I can't engage the reverse nor the 5th gear. Where is the problem? What is the likely cause?
On the '05 Golf I can shift but the gears are also quite hard to shift.
