Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old April 7th, 2015, 08:38   #1
leon10tagg
leon10tagg's Avatar
Default B5.5 Wagons
Been off the forum for a while as I'd sold my 2004 black passat high line anyway the sale didn't happen so the car was dispatched to the body shop for 2 new front wings. Also in the mean time I've also bought a 2005 silver passat trend line which is one owner from new with a full service history. So far for it I've bought coil overs, a stubby ariel and a nice set of 18" BBS alloys........pictures to follow.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old August 27th, 2015, 13:48   #2
leon10tagg
leon10tagg's Avatar
Recent picture of my silver wagon with BBS and rear coil overs fitted.
Old August 30th, 2015, 09:03   #3
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Nice!
-George Bernard Shaw
Old August 31st, 2015, 13:06   #4
leon10tagg
leon10tagg's Avatar
This mornings work....setting the FK coilovers to the final height....
Removal of the top arm pinch bolts took a while as the bolts had never been out before in 126K miles.....so the only solution was a bit of heat and a new set of top arms on both sides....
And as I had no new pinch bolts available I ended up doing this as a temporary measure.....
The next job is to get my black highline Passat back into my garage to finish the engine, sort out the brakes and get it back on the road hopefully with around 230whp....
Old September 1st, 2015, 09:45   #5
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Nice looking wheels. Are they RXs? Just picked up some RGRs for my passat.
2.0 ALH, GTB2260, 12mm, etc, etc.....
www.nashimporters.com http://louisvillevw.org/
TDI Repair Available, TBs, Clutches, Manual Swaps, BSM, etc..
PD Cam tools, BSM tool, VE & PD TB tool rental available.
Nash_TDI is offline   Reply With Quote
Old September 1st, 2015, 10:09   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Looks good. I just lifted my B5V. Installed Rough Road suspension springs, and Bilstein HD struts. It is a 4mo, though.
oilhammer
www.cardocautomotive.com
Old September 7th, 2015, 12:48   #7
leon10tagg
leon10tagg's Avatar
Purchased an aftermarket window regulator kit for the passat......what a waste of time. Anyway an oem unit will be ordered tomorrow. Also fitted a ported inlet manifold and Allard EGR delete pipe, carried out an oil and filter change and fitted new wiper blades.
Old September 19th, 2015, 01:16   #8
leon10tagg
leon10tagg's Avatar
Fitted the oem regulator what a difference compared to the aftermarket one.
Also fitted a Tdi-tuning box to the car.....the increase in power is very linear making the car drive better.
Old October 9th, 2015, 09:22   #9
leon10tagg
leon10tagg's Avatar
Ordered a newmans pd camshaft for the car today. It has slightly more lift over the one i have fitted in my black passat. So it should provide a bit more power����
Old October 14th, 2015, 14:08   #10
leon10tagg
leon10tagg's Avatar
My new PD cam....its a 9.5mm lift version compared to the old one of 9.31mm lift. This one will be fitted to the black Passat so that its 9.31mm cam can be sent back for repair, as there appears to be a small piece of chilled iron missing from the injector lobe. Then the returned 9.31mm lift version will be fitted to the silver Passat along with the uprated smic and hybrid turbo. I'm also looking to purchase a set of +80 DSSR nozzles from United Diesel to finish the engine off on the black passat.
Old November 29th, 2015, 03:50   #11
leon10tagg
leon10tagg's Avatar
Recently I've been spending time working on my black high line b5.5 estate refitting the gtb2260vk turbo and 9.5mm Newmans camshaft. So not much has been done on my daily silver B5.5 but it now needs a bit of work as the alternator belt tensioner has started to chatter and there is a small leak at the bottom of the rad. So both parts are on order to sort these issues. When I'm sorting these issues I'll fit the hybrid cr1756 turbo.
Old December 22nd, 2015, 22:18   #12
TDIno
Hope you can update us about the progress of your build. have you fixed the leak problem?
TDIno is offline   Reply With Quote
Old June 21st, 2016, 21:48   #13
leon10tagg
leon10tagg's Avatar
Been a while but so far I've been able to source an allroad front strut brace, new drivers side door frame trims as the existing ones have spots of corrosion and 2 new wings are to be fitted. Also had to fit a new alternator clutch pulley.
Old June 30th, 2016, 15:39   #14
leon10tagg
leon10tagg's Avatar
Complete set of StrongFlex bushings ordered for my silver passat to rebush the front suspension before this years Mot. Also hopefully I'll be ordering an Eibach 32mm front anti-roll bar for the car this month and then the rear beam will be braced to reduce roll at the rear.
Old July 7th, 2016, 13:24   #15
leon10tagg
leon10tagg's Avatar
Eibach anti-roll bar ordered so I've a bit of work now to do on the car for its annual mot test.
Pros/Cons - Passat Wagons, B5 TDI vs. 1.8t sunvalleylaw VW B5 Passat TDIs 26 November 21st, 2014 22:29
Brake Upgrade <312mm , Audi A4 B5/Passat B5 Dankemp Upgrades (non TDI Engine related) 1 June 29th, 2013 08:12
Steel Wheels for B5 & B5.5 platform 100.00 LoneLIPumpeDuse Private TDI Items for Sale/Wanted 1 December 26th, 2007 08:52
Dealer in VA can get A5.5 pkg2's and B5 GLS Wagons ADW_squared TDI Cars for Sale/Wanted 7 September 5th, 2005 16:54
Page generated in 0.16035 seconds with 10 queries
[Output: 134.84 Kb. compressed to 112.31 Kb. by saving 22.53 Kb. (16.71%)]
