Old April 24th, 2015, 18:47   #61
minis2003
Fuel Economy: 40mpg
How did the engine hold-up in the dirt??
minis2003 is offline   Reply With Quote
Old April 24th, 2015, 19:21   #62
jetmoto3
held up just like any other engine, hard to not peel out with all that power. it can actually crawl now and cruise up things. that tdi is a fun engine.
jetmoto3 is offline   Reply With Quote
Old April 29th, 2015, 08:24   #63
minis2003
Fuel Economy: 40mpg
I mean did it feel under Powered or did it have power to spare?
I read on some of the Jeep forums that some of the people there recommends a swap with the BT4 than a tdi because they felt it would be under power
Old April 29th, 2015, 08:36   #64
jetmoto3
as i said it all my posts it is no way underpowered it has plenty of power and in 4 wheel drive it has more than enough torque to pull it anywhere even with my 3.55 gear set. it feels like it has more power than my 4bt ford ranger if you need a comparison its a mean motor.
Old May 1st, 2015, 08:19   #65
tophergrace
tophergrace's Avatar
TDI(s): Alh
That's truly impressive considering the 3 litter difference. I'd imagine you saved a few hundred pounds over the 4bt also
tophergrace is offline   Reply With Quote
Old May 1st, 2015, 13:21   #66
jetmoto3
yeah with the bigger injectors, turbo and the kermatdi custom stage 3.5 tune it really is a fun motor, it actually impressed me. also the dakota is 100lbs lighter from stock with the tdi.
Old May 30th, 2015, 18:07   #67
G60ING
G60ING's Avatar
Half of whatever it would realistically bring. A lot of people fear swapped vehicles especially when they are inoperable when purchased
G60ING is offline   Reply With Quote
Old May 30th, 2015, 19:05   #68
jetmoto3
it just started smoking like this
https://www.youtube.com/watch?v=gIH87XC42HM
and it doesnt use any coolant and runs just like it did before its weird
Old May 30th, 2015, 21:34   #69
G60ING
G60ING's Avatar
Default tdi dakota conversion
Check the timing with vag-com?
Old May 30th, 2015, 21:51   #70
jetmoto3
timings the exact same its right on, theres no codes. just leaking from the oil pan like it has been for a few weeks, it doesn't smoke when cold just when its warmed up.
thanks
after looking around the forums i think its my turbo(even though it was new) so I'll ether have to rebuild it or get a new one.
Old June 2nd, 2015, 14:54   #71
jetmoto3
so i pulled the turbo and found oil all over the compressor and intake.
Old June 3rd, 2015, 21:59   #72
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
where'd you get the turbo?
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old June 3rd, 2015, 22:45   #73
jetmoto3
I bought it off a friend and it was sitting for awhile, but the reason why it died so fast, was that i rebent stock return line and used it for awhile, so by the time i got the right return line the turbo was toast. It seemed like it worked just fine but found out that wasn't the case.
Old June 10th, 2015, 17:55   #74
yatzee
yatzee's Avatar
TDI(s): see sig
before it blew, how was the fuel economy?
2015 Passat TDi 6 spd, 2005 C230 6 spd, 2002 3500 6BT NV5600, 1991 405 mi16, 1986 and 1987 190e 2.3-16 [SIZE=1]
yatzee is offline   Reply With Quote
Old June 10th, 2015, 18:12   #75
jetmoto3
the turbos been rebuilt since then but i get a constant 28mpg in town i haven't taken it on the freeway
South Dakota TDI'S ?? TDISD Mid-west USA 0 December 26th, 2013 18:31
Moving to North Dakota. TDI Extreme Cold? golforfiesta TDI 101 33 November 14th, 2011 22:32
for sale:04 jetta tdi 5 sp.in S Dakota dljtruck TDI Cars for Sale/Wanted 1 September 18th, 2011 15:07
Is a TDI practical in rural South Dakota Bill in South Dakota TDI 101 28 July 19th, 2010 18:40
WTT: My 99 Dodge Dakota for a TDI. Smola67 TDI Cars for Sale/Wanted 1 June 13th, 2007 03:25
Page generated in 0.19720 seconds with 10 queries
[Output: 126.04 Kb. compressed to 105.19 Kb. by saving 20.84 Kb. (16.54%)]
