Old March 24th, 2015, 19:25   #46
jetmoto3
so here's an updated vid its all finished other than the tach and now i need to paint it https://www.youtube.com/watch?v=tAFZ-fxOwnw
jetmoto3 is offline   Reply With Quote
Old March 25th, 2015, 04:42   #47
jimbote
jimbote's Avatar
drive video or it didn't happen !
Old March 25th, 2015, 07:35   #48
annieneff
annieneff's Avatar
^^^^^^^^^^^^ X2.
I like a nice boost gauge, engine revving, video session as much as the next guy, but add that to rowing through the gears and the wind in your hair and wow! Then you really have something.
Getting it running and all the bits working is a fun place to be. Congrats! Now consummate the deal and film it... Drive it down the road .
annieneff is offline   Reply With Quote
Old March 25th, 2015, 15:05   #49
jetmoto3
ok so here's my attempt of a driving video https://www.youtube.com/watch?v=HbRq2_-IxNk
Old March 25th, 2015, 16:00   #50
jimbote
jimbote's Avatar
awesome so far !... @ 3:22 finish it later
Old March 25th, 2015, 16:03   #51
annieneff
annieneff's Avatar
I'm officially impressed! Has some nice pickup and go. Doesn't seem to noisy in the cabin. Looks like you've pulled it off and have a great rig there!
If you get a scangauge and plug it into the obd port it'll give you rpms, and engine temp, and fuel economy and lots more. Nice to have verification that all the Dakota's gauges are really happy and actually doing what they say they're doing.
Thanks again for sharing, too cool!
Edit: I only made it to 2:16 in the video. Did I miss anything?
Old April 3rd, 2015, 01:13   #52
jetmoto3
does any one know what i need to change for the 1z glowplugs to work with the afn ecu do I have to get the whole gp wiring for the afn or can i just rewire it. i cant seem to find an answer. Thanks
Old April 5th, 2015, 21:37   #53
glenn1179
TDI(s): na
Nice swap! Can you share details on what you did for engine mounts? What starter is used? Is the AC pump the only accessory moved?
glenn1179 is offline   Reply With Quote
Old April 6th, 2015, 13:57   #54
jetmoto3
I modified the stock dakota engine mounts, the starter VW Passat TDI 2004-2005,Part # 068-911-024-HX, yes the tdi a/c compressor didn't fit, and i wanted to use the dakota one anyway, but im using the tdi alternator and p/s pump and there working much better than the dodge ones. i just barely panted it and the only things i need to get working are the tach and cruise control. does anyone know if the turbo return line fitting on an alh motor with work on the 1z block with the banjo bolt
Old April 7th, 2015, 14:18   #55
jetmoto3
Its badged now lol
Old April 22nd, 2015, 11:09   #56
jetmoto3
ok so i have an oil leak at the back side of the motor that i cannot figure out where its coming from, and I have replaced ther breather tube the oil cooler housing gasket, oil cooler gasket vacuum pump orings. does anyone have an idea its like someones pouring oil down the block and i cant see where its leaking Thanks
Old April 22nd, 2015, 18:27   #57
minis2003
Fuel Economy: 40mpg
Can you post a picture of the area you think where the oil is coming from?
Could oil be pudding on the backside of the head causing an oil leak via valve cover gasket?
minis2003 is offline   Reply With Quote
Old April 23rd, 2015, 11:01   #58
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Am I seeing RTV squeezing out around where the filter head meets the block? The gasket in this location doesn't need RTV and needs to be replaced every time. Not saying this is your issue just an observation. Other common leak locations on your motor would be the ccv tube where it mates with the block. Very common for the tube to deform and/or the oring to get hard and leak.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old April 23rd, 2015, 13:09   #59
jetmoto3
got it figured out. so it ended up being the crank sensor o-ring and the dip stick tube.
Old April 23rd, 2015, 16:29   #60
jetmoto3
took it out 4 wheeling, its a fun truck.
South Dakota TDI'S ?? TDISD Mid-west USA 0 December 26th, 2013 17:31
Moving to North Dakota. TDI Extreme Cold? golforfiesta TDI 101 33 November 14th, 2011 21:32
for sale:04 jetta tdi 5 sp.in S Dakota dljtruck TDI Cars for Sale/Wanted 1 September 18th, 2011 14:07
Is a TDI practical in rural South Dakota Bill in South Dakota TDI 101 28 July 19th, 2010 17:40
WTT: My 99 Dodge Dakota for a TDI. Smola67 TDI Cars for Sale/Wanted 1 June 13th, 2007 02:25
Page generated in 0.16316 seconds with 10 queries
[Output: 124.41 Kb. compressed to 103.62 Kb. by saving 20.79 Kb. (16.71%)]
