Old March 4th, 2015, 12:53   #31
993er
993er's Avatar
TDI(s): None
Originally Posted by Digital Corpus View Post
Would you mind emailing it to me?
Just sent 2 files.
Alex
993er is offline   Reply With Quote
Old March 4th, 2015, 12:53   #32
TDIDaveNH
Left Lane Coal Roller at Large
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Yeah, use whatever images of mine you like.
Per cogo, non per mico (By compression, not by spark)
GLX conversion in Storm Grey- my first TDI engine rides again.
TDIDaveNH is offline   Reply With Quote
Old March 4th, 2015, 13:40   #33
Digital Corpus
Digital Corpus's Avatar
This here might work. It's a 15mm ID, 17 mm OD sleeve bearing. There are other alternatives available too, if you're one of many of us with the 15mm bushing.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | DC Stg IV Clutch w/ 14 lb flywheel | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old March 4th, 2015, 14:09   #34
TDIDaveNH
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Good find DC, but the hex end of the 15mm hub is only 17mm and responsible for holding the pulley away from the engine and would have only the points of the hex doing that job, which are also chamfered if you look closely. There are 40mm OD by 15mm ID bearings out there or a small-scale group buy here
I never like rigging stuff up baby-carriage stye...as a last resort, this is an option as well
Old March 4th, 2015, 14:13   #35
Digital Corpus
Or you can stack a washer against the hex side, no? I'll keep those links in mind since I've not had a chance to search for the odd-size bearings yet.
Old March 4th, 2015, 14:30   #36
TDIDaveNH
TDIDaveNH's Avatar
TDI(s): 1997 Passat
Yup, the simple solutions seem to elude me right away, lol. I edited my last post with a link for some 19mm hex stock to make these on a lathe.
Old March 11th, 2015, 14:43   #37
Digital Corpus
Here is some less expensive hex bar stock
Old March 11th, 2015, 15:47   #38
TDIDaveNH
TDIDaveNH's Avatar
TDI(s): 1997 Passat
I don't think I would use aluminum just on the basis of thread strength.
I guess the Gates version of 028145278A also has the 17mm hub. Abacus bought one recently through Amazon but when I checked on it a couple days ago, all there was was ones with the 15mm hub by other manufacturers So evidently they are still available but you do have to do some online digging and scrutinize photos closely.
I do know the ones made by Meyle are 15mm but have not researched others
Old March 11th, 2015, 17:28   #39
Digital Corpus
Well, for about 2x the cost, there is grade 7075 aluminum that can be use, fwiw.
At quick google search, since 0.75" = 19.275mm, yields several inexpensive options compared to your first link. All of those are 3' lengths for less than $20.
I've not had a chance to go over the rollers just yet...
Just finished doing an update for the carbon/graphite brushes a little while ago. It's hard to find anything not on eBay or produced in the US that isn't stupendously expensive, $60 ea., so I'm open to other sources.
Old January 12th, 2016, 11:59   #40
Digital Corpus
Updated prices and added the recent Dayco Roller. Come tax return season, I'm going to have some disposable income so I'll be picking up a couple of these to confirm dimensions and fitment for the sake of thoroughness.
Old January 30th, 2016, 02:34   #41
Digital Corpus
Boca just popped up a youtube ad for 15% off with the code 15GBBOCA13 and they state that it's good for any bearings. Just an FYI
Old April 4th, 2016, 05:58   #42
thechoochlyman
thechoochlyman's Avatar
TDI(s): 97 Passat
Fuel Economy: 47.5 daily, 51.4 highway
Is there any interest for me making some stainless steel idler pulleys? Or whatever material you like, for that matter. Dave - what exactly are you suggesting about getting a larger, stronger bearing and building a pulley around it? I can do exactly that with no issues. I was approached a while back about making the 17mm spacer sleeves, and I feel like revisiting it now.
1997 Passat 5 speed - No longer bi-tone
2.5" Straight-pipe exhaust CCV/EGR Deleted Malone Stage 3, 2.0 IQ Autometer Gauges Billet Stuff
Billet Coolant Flanges - Idler Pulleys - CCV plates - Window Guide Clips
thechoochlyman is offline   Reply With Quote
Old April 6th, 2016, 00:28   #43
Digital Corpus
Yeah, sorry for not following through about the hub ideal that long while back.
I myself wouldn't want an aluminum pulley unless it's heavier than the stock one. The stainless one is a nice idea, but what alloy would be used to help with cost? I don't know if I'm the only one who wants the inertia benefit from a heavier pulley.
Old April 6th, 2016, 05:08   #44
thechoochlyman
TDI(s): 97 Passat
Aluminum would definitely be heavier than the plastic one with all the speed holes in it. I'll have to check on cost for stainless roundstock that size and see how much it compares with other options. I won't be doing anything fancy with it, just turning it down enough to work without hitting anything. The more material left, the better - at least as far as inertia is concerned.
Old April 6th, 2016, 11:02   #45
thechoochlyman
TDI(s): 97 Passat
Page break
Bosch Alternator for sale roccman Private TDI Items for Sale/Wanted 8 October 18th, 2012 08:38
Alternator Rebuild autenje TDI 101 25 January 13th, 2011 19:33
Alternator, Replace voltage regulator or rebuild/buy rebuilt alternator? TDI Jim VW MKIII-A3/B4 TDIs 2 February 19th, 2008 15:37
bosch alternator jjstark VW MKIII-A3/B4 TDIs 3 November 24th, 2007 14:35
Bosch Alternator DGBrunet Private TDI Items for Sale/Wanted 0 July 31st, 2003 17:17
Page generated in 0.18400 seconds with 10 queries
[Output: 138.23 Kb. compressed to 115.60 Kb. by saving 22.63 Kb. (16.37%)]
