Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old November 8th, 2014, 15:49   #1
bulletmoose
bulletmoose's Avatar
Default Glow plug light
I got a 2012 jetta TDI with 28k miles and my glow plug light is flashing. I haven't got a chance to pull codes, and without codes you can't tell what's wrong. But what have people seen as the problem ?
bulletmoose is offline   Reply With Quote
Old November 8th, 2014, 16:44   #2
Savageman69
Savageman69's Avatar
your not suppose to drive it when it flashes...its a major issue if the glow plug light flashes
2012 Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
2006 Jetta TDI 5pd
2010 Jetta TDI DSG
Savageman69 is offline   Reply With Quote
Old November 8th, 2014, 17:11   #3
bulletmoose
What kinda issues we talking ?
Old November 8th, 2014, 17:26   #4
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Let's hope not but sounds like infamous fuel pump imploding
Sent from my SM-G900W8 using Tapatalk
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old November 8th, 2014, 17:37   #5
Savageman69
VW Mk6 glow plugs warning light - the glow plugs dash light has dual meaning, so be sure you read this carefully.
CONSTANT - if the light remains on and constant, it means a fault in the glow plug system. You should not start the engine until this light has turned off, and will generally take a few seconds longer to turn off in colder conditions.
FLASHING - if the glow plug light is flashing it means there is a fault in the engine management system and needs to be diagnosed & fixed accordingly
2006 Jetta TDI 5pd
2010 Jetta TDI DSG
Old November 10th, 2014, 12:55   #6
TDIx2
TDIx2's Avatar
Location: Saginaw Mi ~ looking out for deer and dangerous people!
TDI(s): 2014 Jetta
In 2001 the glow plug flashing in my golf tdi meant a tail light was out... In my 2011 Jetta the glow plug flashing meant a brief failure of the barometric pressure sensor.... Car ran fine otherwise.
2014~Jetta TDI premium/nav
2008~EOS Eshmier Blue LUX:
TDIx2 is offline   Reply With Quote
Old November 11th, 2014, 11:14   #7
mhouck
mhouck's Avatar
LOL, so basically they give you a heart attack to let you know your light bulb is out.
Mychael
'12 DSG Jetta TDI w\ Premium
'10 DSG Jetta TDI
mhouck is offline   Reply With Quote
Old November 11th, 2014, 11:26   #8
Good Ol' Boy
VeeDubTDI's Avatar
On a new car, the glow plug light flashing indicates a serious engine malfunction. Possibilities include, but are not limited to, a failed turbocharger and a failed high pressure fuel pump. It could be any number of things, so step one is to scan with VCDS and find out what it is unhappy about.
Old December 3rd, 2014, 23:48   #9
bulletmoose
I forgot to give an update... After I pulled codes it was P045F EGR Intermittent stuck closed. After I cleared the codes and restarted the car I haven't seen any other lights
Old December 4th, 2014, 18:38   #10
TDIx2
TDIx2's Avatar
TDI(s): 2014 Jetta
On my 2011 Jetta it meant the barometric pressure sensor was on the fritz.
Old August 13th, 2015, 13:39   #11
nivlasol
my light GP light is flashing and CEL are on. codes that popped up was the same code 2x at exactly the same time interval. after scanning it turns out its my EGT sensor port 1 is faulty.
apparently there are a lot of different meanings to this mysterious flashing GP light haha
nivlasol is offline   Reply With Quote
Code 17057 - cyl 3 glow plug and glow light on for half sec gone postal VW MKIV-A4 TDIs (VE and PD) 3 October 21st, 2014 12:16
Where to plug in the wire to feed the glow plug light bbob203 TDI Conversions 5 November 19th, 2013 13:54
Low oil pressure, check engine light, glow plug light??? thomps33 VW MKV-A5 Golf/Jettas 2 March 21st, 2011 18:01
Installed Bully Dog Flashing Glow Plug Light Engine Light On! Please Help! kartracer35 TDI 101 5 August 26th, 2008 17:52
HELP! Check engine light (solid) glow plug light (blinking) no symptoms TDI Steve VW MKIV-A4 TDIs (VE and PD) 16 December 18th, 2001 09:50
Page generated in 0.16451 seconds with 10 queries
[Output: 105.11 Kb. compressed to 88.75 Kb. by saving 16.36 Kb. (15.57%)]
