Old October 25th, 2014, 15:38   #1
kajikidu
Default 96 Tacoma ALH TDI swap
Hi Everyone!!
here is a link to the swap I started this past summer
http://tacomatdiswap.blogspot.com/
kajikidu is offline   Reply With Quote
Old October 25th, 2014, 16:26   #2
jimbote
jimbote's Avatar
looks like you have two different kinds of mounts and two different pans... can you provide details on your approach to both? ....also can you post pictures of your diff to pan clearance and how much lift, if any, the truck has and what the diff drop is.... I don't see the diff installed in your pictures.... thanks!!
Old October 25th, 2014, 16:55   #3
kajikidu
jimbote
The motor mounts are stock Tacoma, laid down horizontal. The front diff is not in the pics but is in the stock location. I grafted the lower part of the 3.4v6 oil pan onto the upper half of the steel 2.0/1.9 oil pan.
I don't have pics of the diff and oil pan in at the same time. The clearance is the same as the 3.4v6 had to the diff.
The truck is not lifted, and the diff is not lowered.
I just discovered this truck has a 1" inch body lift.
Old October 25th, 2015, 06:03   #4
kajikidu
I added some pics http://tacomatdiswap.blogspot.com/
Old October 25th, 2015, 09:30   #5
JaysinSpaceman
TDI(s): Golf
Jim,
Was that truck parked IN the ocean for some time? Just kidding, you must live in the rust belt. I had thought it was a pain to fix the rust in the floor of my 83 Pickup but my frame was solid. Nice work repairing the frame.
Very nice engine mounts as well. Do the think the stock Taco mounts will absorb enough of the diesel vibrations? And last question, does your modified oil pan also give more volume as well as the clearance you need?
Jaysin
JaysinSpaceman is offline   Reply With Quote
Old October 25th, 2015, 10:22   #6
kajikidu
Jaysin, Thanks! the frame was terrible. I think it was in the ocean,sand everywhere. I'm hoping the mounts don't vibrate, I laid them down flat. I set the oil pan up at the same angles as it will be when it is installed in the truck, then filled it with liquid and it held 5.75 quarts, I also modified the pickup tube so it's in the lowest part of the pan.
Old October 25th, 2015, 10:32   #7
cumminsfromthecold
cumminsfromthecold's Avatar
Fuel Economy: TDIYota 28-30, always on B20-B99.9, R32 terrible, blue B4 TBD
Very nice frame cleanup. How long did that take?
What are you planning on keeping? AC? Cruise control? Do you have a donor car or...?
'84 Toyota truck 1Z TDI build thread, Frankentuned.
(Past - 1997 B4 (burgundy): 1999.5 Jetta TDI 5-spd:
2001 Jetta wagon TDI 5-spd.2001 W8 sedan: '00 Passault wagon.)
cumminsfromthecold is offline   Reply With Quote
Old October 25th, 2015, 10:49   #8
kajikidu
Cummins,
the frame rust repair, paint and reassembly took all summer. I'm keeping the A/C stuff in place, in case I decide to hook it up later. Yes I'm keeping the cruise control. The donor car was a 1998 New Beetle. You can see it in a earlier post on the blog.
Old February 25th, 2018, 06:44   #9
kajikidu
I added some more pics to the swap blog http://tacomatdiswap.blogspot.com/
Toyota Tacoma ALH Swaparoo!! jimbote TDI Conversions 551 May 2nd, 2018 10:42
Tacoma V6 - ALH bolt in swap alphawerks TDI Conversions 82 December 23rd, 2013 07:31
94 Tacoma Swap Candidate Ski in NC TDI Conversions 2 April 21st, 2012 20:52
2.0L TDI in a 96 thru 2004 Toyota Tacoma Pickup rrolsbe TDI Conversions 4 March 2nd, 2012 15:05
tacoma area ALH fuel filter on saturday? have one? evankanga West Coast Canada/USA 1 July 17th, 2005 00:26
Page generated in 0.17269 seconds with 10 queries
[Output: 87.71 Kb. compressed to 74.79 Kb. by saving 12.92 Kb. (14.73%)]
