Old August 24th, 2014, 19:53   #1
vwman2
Default Dpf clogging?
Hello all,
Last few fill ups I have been noticing lower fuel mileage. Always was over 40mpg and now I'm seeing 36 37 mpg. Our golf tdi has 159k on it and seems to run ok otherwise. Would like to know the soot levels but don't have access to one. Is the dealer my only option for a new replacment?
vwman2 is offline   Reply With Quote
Old August 24th, 2014, 19:56   #2
fdizz
TDI(s): '10 Golf 6MT
My dpf fell off, now I get a constant 53/55 mpg. ..
Originally Posted by amstel78 View Post
I don't normally replace fuel filters, but when I do, I don't use vagcom.
fdizz is offline   Reply With Quote
Old August 24th, 2014, 20:21   #3
vwman2
That option crossed my mind but being in nynj area that may be hard
Old August 24th, 2014, 21:17   #4
yatzee
yatzee's Avatar
TDI(s): see sig
best to find someone local with a vcds to check the dpf load
2015 Passat TDi 6 spd, 2005 C230 6 spd, 1991 405 mi16, 1986 and 1987 190e 2.3-16
yatzee is offline   Reply With Quote
Old August 24th, 2014, 21:20   #5
JSWTDI09
JSWTDI09's Avatar
Originally Posted by vwman2 View Post
Hello all,
Last few fill ups I have been noticing lower fuel mileage. Always was over 40mpg and now I'm seeing 36 37 mpg. Our golf tdi has 159k on it and seems to run ok otherwise. Would like to know the soot levels but don't have access to one. Is the dealer my only option for a new replacement?
There are TDIs out there with well over 250k miles on the original DPF. It appears that the primary cause of DPF clogging is failed sensors (either EGT or differential pressure sensors) that do not get immediately replaced. With failed sensors, a regen will not take place - this is what clogs DPFs. Dealers are probably the main source for replacement DPFs, but don't jump the gun and assume that that is you problem. Find someone near you with VCDS and look at all of the DPF related measuring blocks. As long as regenerations are occurring regularly, the main this to look at is the ash load. This is the factor that will eventually lead to DPF replacement if a sensor doesn't fail to clog the works.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old August 25th, 2014, 06:21   #6
vwman2
should I be seeing engine codes if there is a failed sensor?
Have Fun!
Don
Old August 25th, 2014, 09:42   #7
JSWTDI09
JSWTDI09's Avatar
Yes, there should be a stored fault code and a CEL and/or DPF light. As long as regens are occurring, you should be OK. There are many possible causes for reduced mileage and your emissions system is only one possibility.
Have Fun!
Don
P.S. A VCDS autoscan never hurts, just in case.
Old August 25th, 2014, 11:00   #8
redpup
Man, what a bummer. I live in the rust belt so it's only a matter of time until I start her up one day and find the dpf magically eroded away.
redpup is offline   Reply With Quote
Old August 27th, 2014, 15:10   #9
vwman2
I have no idiot lights on the dash, filled it again today and still way off. It's about 100 miles less that it normally gets.
Old August 28th, 2014, 15:02   #10
meerschm
meerschm's Avatar
first thing I would check is brakes and bearings and tires (oh my)
and if there is a fuel leak, or thermostat problem.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old August 28th, 2014, 16:28   #11
vwman2
I spun the rear wheels and you can def feel some brake dragging so I'm hoping that's where the problem is. They do seem very hot just after normal driving and I can now hear brakes dragging while driving. Where should I start with this rear brake issue? E-brake cables not releasing or caliper problem?
Old August 28th, 2014, 17:03   #12
JSWTDI09
JSWTDI09's Avatar
Can you lift the rear wheels off the ground and get under the car? You could try to disconnect the parking brake cable and see if that frees up the wheel. If this does free up the wheel it is a cable adjustment. If the brakes still drag without a parking brake cable attached, it might be a problem with the caliper.
Have Fun!
Don
P.S. I have never done this on a newer car, so I do not know how easy or hard it might be.
Old August 29th, 2014, 05:15   #13
meerschm
meerschm's Avatar
one thing to note is that the parking brake operates by screwing in the piston on the caliper. if you never use the parking brake, it can get loose (meaning the part that screws in is not close to the hydraulic part of the piston) and cause trouble.
If you decide to work on the brakes yourself, there are good DIYs around. the piston has to be turned in to provide more room. you cannot just push with pliers or a c clamp.
Mike
Old August 29th, 2014, 05:59   #14
vwman2
always use the parking brake every time car is parked.
thanks for the help
Old August 29th, 2014, 07:30   #15
AlcoC420
AlcoC420's Avatar
TDI(s): .
The DPF is an emissions component, so enjoys an extended factory warranty beyond 60K Miles in the U.S.. I forget what the emissions component warranty is, but ours failed somewhere beyond 60K Miles and was replaced under warranty.
2010 Jetta Sportwagen TDI 6M
AlcoC420 is offline   Reply With Quote
DPF Delete vs DPF replace Costs ESFlash TDI Power Enhancements 14 March 23rd, 2014 19:56
manifold clogging? kyote321 VW MKIV-A4 TDIs (VE and PD) 14 February 1st, 2004 19:39
Page generated in 0.15995 seconds with 10 queries
[Output: 127.47 Kb. compressed to 105.89 Kb. by saving 21.57 Kb. (16.92%)]
