Old September 3rd, 2014, 08:29   #61
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
So I tried pulling some DTC's yesterday... I'm rather new to VCDS (picked up my first cable and software a few months ago) and I'm not 100% sure which block to check out. I've tried all the ones that sound like it could be linked to the a/c, and so far most of them have said '' cannot communicate with controller '' or something like that. I will be fiddling around with some of the wiring. I know that I have spliced the wires that are color matched:
Black and Yellow and Black and Grey are spliced from BHW harness ---> Audi harness.
4. gn/bl (green/blue) going from A2 to the ecu. This appears to be the engine speed signal.
Perhaps if I spliced this one into the passat's rpm signal??? Which pin could that be on the T90 connector?
Wing_man is offline   Reply With Quote
Old September 3rd, 2014, 10:13   #62
Ifixit
Ifixit's Avatar
Any fault codes?
use VCDS button: 08-auto HVAC then fault codes
Maby someone else can chime in but I think some inst cluster also has rpm sq wave signal out..
EDC16 only has rpm out via can I believe
VW AUDI & TDI Repair in VT fullcircleauto@gmavt.net 802-496-9236
Vw Transmission, DSG Repair/Rebuilding
Petroleum Enthusiast
Ifixit is offline   Reply With Quote
Old September 3rd, 2014, 10:25   #63
jonlowe
I couldn't find that function on the BHW ecu. It may be there, but no clue what pin. My WAG is that the Passat gets rpm thru the CAN bus.
Are you using a genuine VCDS cable, or a generic cable and VCDS lite? If genuine, go to autoscan, and select your vehicle type, Audi A6, and do an autoscan. It will take maybe 10 minutes, and will give you all fault codes on each module in the car.
Sent from my Nexus 5 using Tapatalk
jonlowe is offline   Reply With Quote
Old September 3rd, 2014, 11:22   #64
jonlowe
BTW, what clutch, pressure plate, flywheel did you use? Any spacers required or other mods?
Jon
Old September 3rd, 2014, 11:55   #65
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Jon
MK4 1.8t clutch/flywheel/pressure plate. Remember to insert a pilot bearing into the BHW's crank shaft, the auto torque converter set-up dosen't require it...!
I'll re-scan the car tonight... I don't have a genuine cable so I have limited functionality... I'll keep you posted though!
Old September 3rd, 2014, 12:02   #66
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Originally Posted by Ifixit View Post
Any fault codes?
I'll could try plugging the rpm signal from the instrument cluster to the a/c control head...! If that was the missing link to the a/c control head (E87) kicking the a/c compressor into gear that would be pretty sweet... I'll have a look and see what wire that could be aswell.
Old September 3rd, 2014, 13:01   #67
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
So having trouble finding an rpm signal... Also, where are all the T10 connectors (audi A6 electronic box plenum chamber)?
Old September 3rd, 2014, 13:28   #68
jonlowe
If I understand what you are asking, the T10 connectors shown on the climate control wiring diagram are located behind the kick panel (called the lower A-pillar trim) on the drivers side. I'd attach a PDF of how to remove it if the forum would let me, but it is pretty straight forward.
Old September 3rd, 2014, 17:43   #69
nate0031
nate0031's Avatar
TDI(s): 96 B4 Passat
So you're using the single mass 1.8t setup? The Valeo kit? Does it seem to hold the stage 2 tune well?
2005.5 VW Jetta - 1.9 Turbo Diesel - 5 Speed
2000 Audi A6 - CJAA Common Rail TDI - Quattro - 01E
2005 Ford F-350 - 6.0L Turbo Diesel - Auto - 4x4
nate0031 is offline   Reply With Quote
Old September 3rd, 2014, 19:38   #70
96cali
TDI(s): Passat
Awesome thread. You guys are impressive.
96cali is offline   Reply With Quote
Old September 4th, 2014, 04:39   #71
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Yes Valeo kit, no issues, works as advertised.
So in other news, yesterday I played around again (after a 12 hr shift)... I attempted to make the ''sensor'' dash light on the information panel disappear by tricking the wiring with a resistor. No dice. I will have to buy the sensor from the 2.7 and find a way to install it into the tdi oil pan.
But wait! There's more!
Here are all the 08 air EVAP codes... I feel like I have a lot of work to do, but I have a lot more sense of direction... Good call on the VCDS!
Old September 4th, 2014, 05:27   #72
jonlowe
Clear the codes, drive it for awhile, try to use the climate control, rescan, and see what shows up. Those may be old codes.
Old September 4th, 2014, 10:28   #73
vwztips
vwztips's Avatar
Wing_man you need to hurry up and figure this out. My A6 should be arriving anytime now!
vwztips is offline   Reply With Quote
Old September 4th, 2014, 10:47   #74
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Its coming along. I have erased my dtc's and rescan tonight... I'm getting close, I think perhaps my ac system has a leak... That wound explain the low pressure sensor acting up. As always more to follow.
Old September 4th, 2014, 17:05   #75
Wing_man
Wing_man's Avatar
TDI(s): Allroad BHW
Okay, so after clearing codes, driving and re-scanning :
-00819 High Pressure sensor (G65) 07-00 - Signal too low
-01592 - Air Quality sensor (G238) 57-00 - Electric circuit Failiure
My question is, Would the G65 hi press sensor cause the A/C to go into safe mode and lock out the a/c? There is zero pressure in the system (I checked by depressing one of the fill valve stems, I must have a leak somewhere)...!
Getting the A/C to work would be amazing, I have go see THE girlfriend next week in Ottawa (3hr drive).
2002 Audi Allroad ALH Conversion Dirty_Al TDI Conversions 45 June 2nd, 2018 07:07
02 Allroad BHW swap w/ euro TDI 6MT Scott02 Other TDI/Diesel Picture Gallery 23 August 21st, 2014 09:13
Looking into an BHW swap into an 2001 allroad arjax TDI Conversions 7 July 14th, 2014 20:06
Audi Allroad Diesel Conversion Dirty_Al TDI Conversions 14 October 14th, 2013 21:41
Audi 3.0 TDi Allroad donDavide TDI News/Tech 20 June 20th, 2007 07:34
Page generated in 0.16253 seconds with 10 queries
[Output: 129.16 Kb. compressed to 108.33 Kb. by saving 20.83 Kb. (16.13%)]
